Question about Samsung SyncMaster 753S 17" CRT Monitor
While booting windows the screen become bluish and it lasts for hours????/
    Guru:
  • 452 Answers
Check the posistor maybe the degauss circuit is not working properly
Posted on Oct 16, 2010
My laptop has been preparing to configure windows screen its been doing this for over 2 hours not sure what is going on with it
Bobby,
Please press F8 at boot up and boot in Safe Mode. Once booted, right click on the desk top and select Properties->Settings. Here Reduce the resolution of the screen display one notch and let it reboot normally after that.
If the problem still persists then Press F8 at boot up again and boot up in Last Known Good Boot. option.
Dec 27, 2010 | Toshiba Satellite L455DS5976 Notebook
I have a Mitsi WS-65807 65" Played Wii for about two hours. Lost sound then picture. Now it wont turn on. Just get a warped bluish screen with lines. Any Suggestions?
Well i need more info. have you tried unplugging the tv for around 60 seconds? Was the "warped bluish screen" right before it died. Or is this when you turn it on it happens?(Bluish screen)? Because if no power at all and no picture at all. Could be Power supply. If you have some sort of picture with blue lines that are stable? You have a convergence problem. Get back to me with info i can help.
Dec 26, 2010 | Mitsubishi WS-65807 65" Rear Projection...
I have a dell latitude d610 it was virus infected i install the avast anti virus after installation it automatically restarted and its screen become blue no window boot it just show the dell logo and...
It sounds like the virus did something to the boot sector of your hard drive. Once you have been infected with a virus, it's usually too late to install an anti-virus program to clean your computer.
If you have your Windows installation CDs or a recovery disc, you could attach your hard drive as a second drive to a computer that already has a good anti-virus program installed, and wipe the hard drive and reinstall Windows.
May 29, 2010 | 1992 Plymouth Voyager
AMD Puma-based Asus M51Ta stalls at power up, screen is blank.
Have you tried booting and pressing F2 to get in the bios?
If that works you can check the boot devices and order of usage. Make sure the HDD is first.
Apart from that you can reboot and press F8 to get in the Windows boot menu, where you can try the Safe Mode.
If all this fails, the Windows configuration is somehow corrupt. You can try booting from a Windows CD and run the Repair option in the setup.
Oct 20, 2009 | ASUS M51Ta-X1 NoteBook
Hi i have a bluish tinge on screen?
clean the entire optics of your projector.
Oct 09, 2009 | Hitachi Performa CP-RS55 Multimedia...
Bluish image appearing on screens
It sounds like the projection lamp is beginning to show its age. How many hours of use does the unit have on the bulb? The bulb are typically rated for about 800-1600 hours of use before they go bad. The bluish image on the screen image is a typical tell-tale sign that the bulb is going to need replacing.
Most of your better projection units will have an internal time counter of the bulb life from the time the unit is first used or when a bulb is replaced. Check to see if your unit has this feature, if so it will show you on the screen display what is the total number of hours on the bulb and the estimated remaining hours of life.
Be aware that the replacement bulbs are NOT cheap and usually will cost you several hundred dollars, I have seen bulbs for professional projection units used for large convention/presentations have bulbs costing as much as $500.00 USD.
One other last thing to check is to clean the lens of the unit both inside and outside. To clean the inside, you will need to remove the bulb (be sure to wear a rubber glove as the oils from your skin will cause the lamp to blow, (causes a hot spot)). Then using a cleaning wipe, just as one used for cleaning microscopes or glasses, wipe the lenses. The discoloration might also being caused by dirt and oils on the lenses.
I hope this shed some light on your church's projection problem.
Sep 19, 2009 | Panasonic Office Equipment & Supplies
Vostro 1500 does not boot
hi
dear it is not note book problem it is windows problem
insert boot cd of your desire windows repair it
thanks
Jul 19, 2009 | Dell Vostro 1500 Notebook
Booting repeatedly at compaq window itself,it is not takes up WINDOWS OS.
Solution 1:
When you start the system, press F8 and then select "Last known good configuration". If it does not work the first time, try at least three or four times.
Solution 2:
You can try installing the OS again but you will lose the data in your c drive.
Solution 3:
Check with the BIOS configuration, Take a note of the original configuration before you make any changes.
Jan 15, 2009 | HP Pavillion ZV6000 Notebook
Samsung SyncMaster 753S 17" CRT Monitor Logo
29 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
