Question about Sony PlayStation 3 40GB System
Is their a way to open a PS3 counsole, my kid might of put a couple of dvd movies in it, it turns on but then shuts down and red light flashes
  • 597 Answers
To open your ps3, you need to first shut it down and disconnect all the cables connected to it, wait for about an hour for the high voltage in it to dissipate. The you get a screwdriver that matches the screws on it.
Pull the warranty sticker off of the bottom of the PS3. This will void your warranty, so make sure that the problem you are addressing is not covered by your warranty. Note that taking your PS3 to be repaired by someone other than Sony will still void your warranty. You are not losing anything by taking apart your PS3 yourself. Under the sticker will be a small piece of rubber that hides a single screw. Remove the rubber piece and unscrew the screw.
Slide the faceplate off of the PlayStation 3. After the faceplate is removed, you can now separate the two halves of the plastic covering. Remove and set aside the top piece of the plastic case to expose the internal components of the PS3. On the underside of the top plastic covering, there will be a memory card slot at the bottom-right corner.
Locate and remove the Bluetooth circuit board. Remove the four screws to lift the Bluetooth board free. This is located at the bottom-left corner of the main body of the PS3 if you have the system flat on its side instead of standing up straight. This will look like a green rectangle with a tan metal covering.
Locate the small circuit board that controls the power and eject functions of the PlayStation 3. Remove the four Phillips-head screws in order to separate this piece from the body of the system. This is located at the bottom-right corner of the PS3, directly in front of the disc box.
Locate and remove the Blu-Ray/PS3 player. This is the large tan metal box that is located in the top right corner of the PS3. Unscrew the player and flip it upside down to expose the circuit board that controls it. If you want to remove the circuit board, there are five small screws that hold it in place.
Remove the power supply from the inside of the gaming system. This is located at the top-left corner inside the PS3. To remove this component, there will be two telephone-like plugs that have to be unplugged, one at the top and one at the bottom of the power supply. Additionally, there will be 13 screws that hold the power supply in place. The back and front plastic coverings of the PS3's shell will now easily slide free.
Remove the final internal component, which is the PS3's motherboard. In order to do this, remove the metal covering the rests on top of the motherboard. There will be 11 screws that border the metal covering as well as four screws in the very center, two from each of the rectangular center pieces. Once the screws are removed, the metal covering will lift off and the motherboard will be able to be removed.
But before you get to all these parts you must have gotten your DVD movies out.
Take care
Posted on Oct 12, 2010
  • coolguy973 Apr 21, 2011
    lol dume *** kid sucks man
My ps3 is a first gen and yesterday while watching a movie with my kids it shut off. Now every time I try to turn it on itjust flashes red and shuts down again. Any idea whats wrong?
Its called the Yellwo Light Of Death. I have a step-by-step instructions on how to fix the problem.
http://www.fixya.com/support/t8396931-ps3_turns_ok_but_turns_itself_off_after
Mar 06, 2011 | Sony Playstation 3 (PS3) Console
My ps3 shut off and I tried to turn it on again and it beeped 3 times, the power button went red,yellow and blue then shut down. After all that it still flashes red and does not turn on. I also have mw2...
Make sure that your PS3 is not put in an air tight space, direct sunlight, or heated room where it overheats. Put it in an open space, and make sure that there's sufficient air flow. Otherwise, You'll get the 'yellow light of death' Hope this helps.
Aug 24, 2010 | Sony Playstation 3 (PS3) Console
Turned off while watching a movie.When you try to turn it on,you get a green light,then a blue light,then a red flashing light.
"When the power status light flashes red after using the PS3 system for some minutes and shuts off, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked."
"If this happens:
• Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
• If the PS3 system is in an enclosed area like a bookshelf or entertainment center, move it to a more open area.
• Leave the PS3 system off for 30 minutes to let it cool down.
• If you continue to have issues, you will have to send the system in for service."
Good luck..
May 31, 2010 | Sony Playstation 3 (PS3) Console
While playing a game console turned off and game disc is stucked inside, turn power on and light turns green for couple seconds then flashes red and turns back off, no chance to eject game disc.
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked.
The blinking red light is infact a general hardware failure message. In this particular case, his hardware failure is with the blu-ray drive, that's why the system does not shut down until the drive is accessed. if the system is overheating, it will tell you so in the top right hand corner. It will say the system has overheated and is shutting down to avoid further damage.
Provide a proper vent for the system...
Hope this will help...
May 28, 2010 | Sony Playstation 3 (PS3) Console
My playstation just shut off an the red light flashes
do you get a yellow light? i bet you do..
1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work
Send your playstation back to Sony
May 09, 2010 | Sony Playstation 3 (PS3) Console
Flashing Red Light
take of the top then take out the disk drive and pull the game out. Then send it to Sony to have them fix it.
My Playstation 3 won't stay on. When I turn it on, it shuts itself off immediately and flashes a red light. It is not overheated. What can I do?
Mine did the same thing yesterday. I called PS3 tech support and they said to fill out a service order request, they will send a prepaid box. When I get the pre-paid box send it back and since it is out of warranty, it will cost me $150.00. Will take from the time I fill out the request online to getting my fixed PS3....about 4 weeks. Mine did not overheat, in the middle of a movie...shut down. Nextflix DVD is stuck and they said that they will return the DVD in another mailing. Can not believe that as advanced the PS3 is, there is not an emergancy DVD release like on PC's. Good luck and hope this helps!!
Dec 16, 2009 | Sony Playstation 3 (PS3) Console
System shuts off and turns to red light standby
Hello. You may want to double check your connections and cables. The only time I've ever heard a clicking before a system shut it's self down was when a kid had stuck the battery cover from a TV remote into the disc drive.
Also, if the PS3 keeps acting like that, Sony will repair/replace the unit for free including shipping since it's under a year old. Thanks and good luck!
Jan 09, 2009 | Sony Playstation 3 (PS3) Console
PS3 Turns Itself off and wont turn on
sorry mate i cant fix it but my buddy has a problem with his also
his ps3 freezes even in the menu screen and during video chat it shuts off
Jul 10, 2008 | Sony Playstation 3 (PS3) Console
Open Questions:
Sony PlayStation 3 40GB System Logo
125 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
