Question about HP Compaq nc6220 Notebook
My hp compaq laptop screen is black after installing vga but when i connect it to another monitor it works
  • 97 Answers
problem with your resolution.
Restart your Laptop press F8 key select safe mode press enter to continue follow the screen instruction. Go to my computer properties in that remove the display driver than restart the Laptop.
Don't do anything it will open in normal mode and windows will install VGA driver automatically.
Posted on Oct 11, 2010
    Scholar:
  • 89 Answers
Go to hp.com, put in the service tag and install the drivers for motherboard and video.
Click here to know the common causes to black screen error
I connected a HP Compaq Monitor Q2159 to my Dell laptop. But the monitor does not copy that of my DELL laptop. How do I make a correct connection?
If it is connected with a standard VGA lead and you use win7, right click on the battery icon and use the mobility centre to switch the screen on.
Jan 31, 2014 | Computers & Internet
How can i fix my hp 210-1041NR mini laptop black screen problem,
Time for a trial and error.
1.connect your laptop to a monitor or tv that has a VGA connection.Use a vga cable and connect it to your laptop then to your TV or monitor.If the screen shows display and works on your TV or Monitor ,Then its likely that your Laptop screen is faulty which can be replaced.If it does NOT SHOW on your monitor or TV then it means your GPU is faulty which then you will need to replace the motherboard on your laptop.
Sep 14, 2013 | HP Mini 210 210-1041nr Wp055ua 2gb 16010.1...
Laptop
No blinking cursor either?
{ If there is a blinking cursor, you would then use the Restoration Disk, IF you have it.
When asked choose Repair. (Non-Destructive Installation)
If you do not have it go to HP Support Worldwide, your country, and obtain the disk. (HP bought out Compaq. On the HP Support page for your country, go to the Top Right, click on the - Connect with HP - icon.
When you hover your mouse cursor over it, Connect with HP will briefly show)
The disk is free. The shipping and handling is not.
USA example: $17 for a 5 to 7 day ship, $24 for a 2 to 3 day ship. Call 1-800-474-6836. 24hrs a day, 7 days a week.
Have your Serial Number handy, to give to the nice representative on the phone. Bottom of the laptop in white Service Tag. S/N = Serial Number }
However no blinking cursor was stated. This means to me that it is a graphics problem.
The problem can be;
1) Graphics chipset
2) Video Cable. (Compaq/HP = Display Cable)
3) Screen Inverter. (IF used. Model Name and Model Number was not stated. This is the Product Number. P/N in white Service Tag, on bottom of laptop.
GENERALLY, if a CCFL is used for a Backlight, a screen Inverter is used. (Cold Cathode Fluorescent Lamp)
IF LED backlighting is used, GENERALLY NO screen Inverter is used. (Light Emitting Diode)
Does depend on what model we are talking about here.
There are some models that have used a screen Inverter, along with LED Backlighting.
4) LCD screen
A) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA connector, on the laptop.
Usually on one of the sides, or back.
Here is a general example of a VGA connector (port), and a VGA Cable,
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for VGA Cable example.
You can use a CRT type of monitor (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable. (You can also use a VGA to DVI adapter, if the laptop has a DVI port on it,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
You can click on any photo to enlarge. Sometimes you can enlarge twice )
B) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external VGA monitor.
IF not;
You have at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Hold the Fn key down, and at the SAME time tap once on the F4 key. The F4 key is the Display Toggle-Over key.
Still no display on external VGA monitor?
Hold the Fn key down again, and tap once more on the F4 key.
NO display on external VGA monitor, means a problem with the graphics chipset.
Most of the time it is the MOUNTING of the graphics chipset TO motherboard.
The solder connections is the problem. Graphics chipset is reflowed to the motherboard, using an SMD/BGA Rework Station. Specialized shops have them.
Otherwise it means replacing the motherboard.
Good graphics on external VGA monitor means the problem is;
1) Video Cable
2) Screen Inverter (IF USED)
3) LCD screen
A Video Cable cost ranges from $9 to $22, with $9 being the norm.
It also just may have a loose connection. Loose at the motherboard side, or LCD screen side. May be screen Inverter cable connection, from Video Cable; is also loose.
So, you are looking at perhaps a loose connection of Video Cable.
Or a damaged Video Cable. (Replace then)
Problem may be the screen Inverter. (IF used)
They range from $9 to $22 also. (Again, $9 being the norm, or less)
LCD screen ranges from $60 to $245.
Just depends on what Compaq laptop it is.
Point?
Better to diagnose.
May find loose Video Cable connection, or bad Video Cable.
May find bad screen Inverter, if Video Cable is not the problem.
Some people jump the diagnostic flowchart, wind up spending $60 to $245 for an LCD screen, ONLY to find the problem was a $9 Video Cable, or FREE if the connection was loose.
Wish I could guide you from here. I step by step guide people, and this means replacing a motherboard in a laptop, if needed.
I have over 10,000 solutions, and many of them are for laptop repair. According to feedback from the asker's of the problems, I seem to have a very high ratio of accomplishment at this, because they repaired their problem/s.
(Brag, brag, lol!)
However it would seem a recent site development change, has rendered replies back from the problem asker, USELESS.
Haven't had a reply in two weeks, or more.
(Neither have the Top Experts)
Regards,
joecoolvette
May 20, 2013 | Compaq Computers & Internet
When i turn on laptop screen goes all black no display
A) Shining a flashlight at the screen at various angles, do you see faint images?
No? Go on.
B) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port on the laptop.
Compaq Presario v3000? Left side towards the rear.
This is an example of a VGA connector (port), and VGA Cable,
Scroll down a little for VGA cable example. Note color of connectors does Not matter.
You can use a CRT type of monitor (Looks like a small TV ), or a flat LCD screen monitor if it has a VGA cable.
http://www.wisegeek.org/what-is-a-crt-monitor.htm
Turn the laptop on.
IF not;
There are at least 3 display options;
1) Internal display of laptop monitor ONLY.
2) Internal display of laptop monitor AND external VGA monitor.
Press, and hold down on the Fn key, and at the SAME time tap once on the F4 key.
Still no display on external VGA monitor? (It takes a second)
NO display on the external VGA monitor, suggests a problem with the graphics chipset.
Most of the time it is the Mounting, of the graphics chipset TO motherboard.
The graphics chipset is mounted to the motherboard, with a BGA surface mount.
Ball Grid Array,
http://en.wikipedia.org/wiki/Ball_Grid_Array
Nvidia GeForce Go6150 graphics chipset,
http://www.ebay.com/itm/HP-COMPAQ-PRESARIO-V3000-V3200-LAPTOP-MOTHERBOARD-/390287984982?pt=Motherboards&hash=item5adefa0956
http://www.ebay.com/itm/1PCS-nVIDIA-Geforce-NF-G6150-N-A2-BGA-chip-north-bridge-Chipset-for-laptop-/190695516885?pt=LH_DefaultDomain_0&hash=item2c6656aad5
View an SMT/BGA Rework Station at work, and learn more about the Solder Balls, and BGA surface mount,
http://ersa.com/art-ir-pl-650-346-1472.html
Scroll down a little, and click on the Red -
Take a few minutes to view the IR 650 demo video.
http://www.youtube.com/watch?v=JEpnqhRYGLw
Uploader comment;
"HP Pavilion DV6000 Blank screen fix BGA rework video problem
This BGA rework fix also works on the HP DV2000, DV6000 and DV9000 there are a couple more HP's with this BGA video issue.
This is a design flaw that we solved with our upgraded copper heat sink and thermal compound.
Also effected by this issue are a couple Compaq models. The Comaq Presario V3000 V6000 and a couple of the Pavilion models."
Not showing for advertising of repair. Showing for adding extra copper sheeting material, to the graphics chipset.
A BGA Rework Station is the best method.
The problem, is inadequate cooling for the graphics chipset.
Bad design by HP.
As you can see in the above information, the bottom of the graphics chipset has Solder Balls.
These Solder Balls match up with Copper Pads on the motherboard.
(The Copper Pads are also gold plated)
The graphics chipset is set into place on the motherboard, with the Solder Balls lining up on the Copper Pads.
Heat is then applied at a specific temperature, and length of time.
This action melts the Solder Balls, and solders the graphics chipset TO the Copper Pads.
Which in turn of course, solders the graphics chipset TO the motherboard.
The solder connections made are called Solder Joints.
When the graphics chipset repeatedly overheats, the solder connections partially melt again.
Then the laptop is turned off, and the graphics chipset cools down.
This causes Cold Solder Joints, and a bad contact of graphics chipset TO motherboard.
If this is a problem with your laptop state back in a Comment.
Going on............
IF, the display shows on the external VGA monitor, and is good; the problem is the Video Cable, or inside the Display Assembly.
(screen Inverter or LCD screen)
Let me know after your diagnosis what the outcome is.
1) NO display on external VGA monitor.
2) Display on external VGA monitor.
Post back in a Comment.
Regards,
joecoolvette
Service Manual,
http://h10032.www1.hp.com/ctg/Manual/c01035667.pdf
(The above is a direct link to a PDF file.
The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the link it may take up to 30 seconds, before the first page comes up.
The PDF file will not show until the file is fully downloaded.
IF the link does not work let me know in a Comment.
I will link you the HP Support page it came from )
Mar 03, 2013 | HP Compaq for Presario V3000 Motherboard
HP pavillion dv9000 has black horizontal lines across screen and looks like a snowy background
Sounds like the screen is going bad. Isolate the problem by plugging an external monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker to plug to the laptop. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the Borrowed monitor does not show the black lines and snowy background, that proves your video card is ok and the problem is your lcd screen. If the borrowed monitor shows the same black lines ans snowy background it means your video card inside the computer has the issue.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 18, 2012 | HP Compaq Business Notebook nx7000
My HP Compaq 6730b screen isn't coming on. All the
Does it seem like the laptop booted up all the way except the screen is black? If so try the steps below:
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 16, 2012 | Compaq Computers & Internet
My laptop hp have problem monitor giving mesage ''monitor going to sleep''
hi you will need to reinstall the vga of the system to enable it not to write that again
May 19, 2010 | Computers & Internet
Start up
Hi, try to connect the system to another monitor. If this doesn't work, check if the VGA card is properly installed. If this doesn't work, then reload the operating system.
If any of this work out, please rate my solution on fixya. Thanks.
Dec 03, 2008 | HP Compaq Presario V2000 Notebook
Black screen on start up hp dv6600
have you check the display on external monitor, check it by connecting to vga port of your laptop,
if there is a display then its the problem of your laptop screen
Oct 14, 2008 | HP Compaq Presario V6000T Notebook
Vga drivers for hp laptop
It's not possible to connect your Monitor to the Laptop as the Pre Installed LCD Pannel of the Laptop reserves the Resources for Display Unit.
For more information on this, you may contact HP Customer care.
Goto www.sahajayoga.org to attain your Self Realization and find a Sahaja Yoga Center to goto.
Jun 22, 2008 | Computers & Internet
HP Compaq nc6220 Notebook Logo
295 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
