Question about Hoshizaki F-1001M Flake Ice Maker
Hello, i have a hoshizaki ice flaker, when i turn on in to ice mode, the compressor run for a few second then it shut off. what could be the problem. thanks
    Sergeant:
    Novelist:
  • 193 Answers
There are several possibilities. The most common is probably low refrigerant. Are you sure the compressor is actually running? If it just humms for 2 or 3 seconds, it may be a burned out compressor. That would be bad news. Take the side panel off and turn the unit on. If the compressor comes on and runs, the small line coming from the compressor to the condensing coils, (the thing that looks like a radiator) should be hot to the touch if it is not you are probably low on refrigerant. There is a safety switch that shuts the compressor off if you are low on freon. The compressor would "short cycle". That is it would come on and off and not every minute or so. That is bad for the compressor and won't make ice either. Also if you don't get a constant flow of water it might do the same thing. There is very little the average person can do to an ice machine as complicated as this one. Check your water flow, check the air flow throught the radiator like coils near the compressor. Other than that you need a refrigeration mechanic to check the freon pressures.
Posted on Oct 11, 2010
  • ARTUIRO Oct 10, 2011
    also you need check the capacitor too
I have a Hoshizaki F-800MAF flaker ice machine an it keeps flushing an we have to clamp off the flush tube to make ice, what could the trouble be
There is a "Dump Valve" that is stuck or has trash in it. Follow the small tube from the pump to the white plastic valve that looks kinda triangular with 3 screws. Remove the screw carefully as this is spring loaded. There should be a black rubber piece that is a seal. Pay attention to how it assembles. The spring presses the seal against an opening. Look for something that may be allowing this not to seat.
Oct 01, 2017 | Hoshizaki Freezers
Does a Hoshizaki Model F-1001MWH have a Defrost cycle? As far as I know the "Defrost" is the harvest cycle correct?
flakers usually make ice continually. It utilizes an auger that rotates in a freezer barrel. It scraps the ice of the insides of the freezer barrel and forces it to the top and out. No harvest cycle is utilized.
Jun 10, 2010 | Hoshizaki F-1001M Flake Ice Maker
Hoshizaki KM-900MAH Ice Maker it sounds like it is making ice and is freezing it but its not dropping ice any solutions?
when the machine first starts, it begins it's cycle in the harvest mode. If the float switch is stuck, it stays in the fill/ harvest mode. Compressor runs and water circulates but no ice is being made. I'd start looking there. Turn the machine on, let it run for about 3 minutes, they very lightly tap the float switch. If it starts making ice, bingo, theres your problem. Let me know if I can be of any more help.
May 12, 2010 | Hoshizaki Freezer Commercial Ice Machines...
WHAT IS THE CAPACITY OF MODEL F-450BAE FLAKER
It is to produce 450 pounds of ice in 24 hours under ideal conditions. Manual says anywhere from 345 to 440 depending on factors of water temp., ambient temp., and system pressures.
Hope this is what you are looking for.
Mar 03, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Model kml-450mah seral mo2237b Hoshizaki Ice machine
start at looking for a stuck float switch. this keeps it in defrost till it senses water level full enough to make ice.
Aug 12, 2009 | Hoshizaki Modular Cuber 680 Lb. with 550...
Km 500 kae hoshizaki 3 beeps every 4 second compressor not coming on
put an amp probe on common wire at compressor and see what amps are when it tries to start. 40 to 60 is mechancially locked up compressor. kill power and test start and run capacitors. there is an thermal temp over load on the compressor that opens when comp gets hot from trying to start. gently remove and look for cracks or burned looking. . i saw one this week doing exact same and i have ordered the oem compressor start cap realy and run cap and drier and will put in all new gas. be sure to allow sufficient time when switched to ice for it to get to ref cycle, it may take 5 minutes starting with water purge, then fill, etc. good luck, call hoshizaki dist they are usually pretty helpful if you need a auth service rep in you area. i think they are three years warrantied!
Oct 25, 2008 | Hoshizaki Freezers
Machine turns on makes one or two batches of ice and then shuts off
Try cleaning the condensor coils. Check the fan blowing across them. When the compressor is running the fan should be too.
Jun 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki KM-500MAH not making ice
Look at water solenoid valve when the unit is running in ice mode. Check to see if the water is shuting off completely. If the water valve does not close properly it will keep adding a little bit warm water to the ice a slow down the ice production.
Sep 21, 2007 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki F-1001M Flake Ice Maker Logo
183 people viewed this question
Top Hoshizaki Kitchen Appliances - Others Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Hoshizaki Kitchen Appliances - Other Expert? Answer questions, earn points and help others
