Question about Samsung SL202 Digital Camera
When I turn my camera on it beaps opens, then closes.
    Brigadier General:
  • 3,006 Answers
Your camera most likely has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Samsung service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the speedy and free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 11, 2010
Video will not work on ps3
It may be stuck in the opposite mode of what you are using on the TV like HDMI output or S-Video. To check this press and hold down the power button, you will hear the initial beap once and shortly followed by a double beap. After the double beap immediately remove you finger. You may have to do this once or twice to get the right beap because this is a service menu they do not want you to get into. Once this is done you will have prompts on the tv to change settings to what every output you want. Make sure you change it to the right one and you should be all set.
Feb 13, 2011 | Sony Playstation 3 (PS3) Console
My Eee pc monitor can't power on(dark),i tried to remove HDD &RAM and returned but nothing worked help me please i need to take my classes online.
when you start your pc then any beap is hear how many beaps are there
5 beaps - processor problem
3 beaps - ram problem
continues running - ram problem
2 beaps - hdd problem
no beaps - motherboard problem
firs you clean tour ram whith eraser.the try.
Jun 07, 2010 | ASUS Eee PC 900HD Netbook
Cannot turn off beap sound after every hour
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all PULSAR watch manuals. Rate me, please
Mar 15, 2010 | Pulsar PF3293 Wrist Watch
How do i turn off the beap on a dxg 567v camcorder
Refer to the manual, or download the manual off the internet. Most camcorders have a setting for turning the beep on or off.
Feb 20, 2010 | Video Cameras
Want to format ps3 hard drive does anyone know how ??
put the ps3 into standby (thts when you see the red light) then hold the power button till yuh hear three beaps and the system turns off, then take your finger off and hold the power button again till you hear two more beaps and two quick beaps when you hear the quick beaps release your finger and put it back on thn you will be in recovery mode and there is an option where you can format your harddrive
Nov 02, 2009 | Sony Playstation 3 (PS3) Console
When i turn on the camera the shutter closes, when I turn it off, the shutter opens
I dropped the camera and now the shutter opens when turning off & closes when I open the camera. But when it is open, the shutter will open a bit making it impossible to take pictures. What should I do or where do I take it for repairs?
Tks, Ruth
Sep 11, 2009 | Sanyo VPC-S500 Digital Camera
KM-450MAB making beaping noise-compressor will not run
The cleaning valve must be closed duing the ice making mode. If it is open, the machine will not make ice. The beeping you hear is the alarm which is present on the machine. Remove the front cover and read the included text. This will tell you what alarm you have.
Oct 07, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
Model KM-450MAB--Ice Machine Making Beaping Noise
Keeps on beeping? Every 3 to 4 seconds? Try putting the thermostat wires together. An open bin thermostat will cause this problem and the board see it and starts beeping.
Pairing
With the microphone closed, push in the call button. It should turn purple within a second or two. When it does release it and as quick as possible flip open the microphone. The light should stay purple and it is now in "pairing mode"
Jul 10, 2008 | Motorola Mobility H700 Wireless Headset
Door indicator prevents microwave from starting
This is usually an indication of a bad door interlock. Take resistance readings with the power turned off on the primary and secondary interlocks. You will need to remove the control panel to access them. There should be a wiring diagram somewhere inside the control panel to assist you in determining if the interlock is normally OPEN, or normally CLOSED. As you open and close the door the interlock should change states. Additionally, double all your connectors to make sure they are plugged in correctly. I had a similar problem once and it turned out to be a loose connection on one of the interlocks. I hope this helps you.
Aug 04, 2007 | KitchenAid KBMC140HSS Convection/Microwave...
Open Questions:
See all Samsung SL202 Digital Camera Questions
Samsung SL202 Digital Camera Logo
73 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
