Question about Microsoft Windows XP Home Edition
QVGA video driver for Windows XP
I have a Single Board Computer ECM-3512 from Avalue that has a TFT LCD connector for display. I also have a 4.3" QVGA display from NEC. The Windows XP I intalled in the SBC have base Video of VGA. How I should do if I want the SBC drives QVGA display ?
Thank you.
  • Rory Biggs
    Rory Biggs May 11, 2010
    Have U checked with the manufacter for XP drivers?
  • 859 Answers
Go to this location and select the XP driver. Once installed your should get xga resolution.
NOTE: You will have to sign in and or register first to download the drivers.
If you need additional assistance please comment back to me and I've be glad to help you.
Posted on Jun 02, 2008
Neither picture is displaying on moniter nor sound is coming (DELL TFT moniter)
Which is a dell tft or compaq crt monitor ?
The Dell 1504FP is a flat panel LCD monitor that has a viewable area of 15 inches.
The monitor, which uses TFT technology, is designed to be used in a home or office and displays video at a resolution of 1024 x 768 pixels.
Over time, you may encounter problems using your Dell 1504FP monitor or it may cease functioning altogether.
Fortunately, there are variety of ways that you can repair the monitor to get it back up and running.
Shut down your computer and press and hold the power button on the side of your Dell 1504FP monitor if your monitor has a blank screen.
Unscrew the VGA video cable that connects the monitor to the computer.
Power the Dell 1504FP monitor back on and wait as it launches into the Self-test Feature Check.
During this period of time your monitor will make settings changes to ensure that it functions properly with your computer.
Firmly screw the VGA cable back into the rear of the monitor to ensure optimal video quality. Power both the monitor and computer back on and wait for your computer's desktop to appear.
Power off your Dell 1504FP monitor if the screen is dirty.
Wipe down the monitor using a dry microfiber cloth to remove any dust particles or smudges that have accumulated on the screen over time.
Power the monitor back on when you are complete and resume using it.
Press the "Auto Adjust" button on the right side of your Dell 1504FP monitor if the display is blurry and images appear out of focus.
Unplug the monitor's power cord for thirty seconds if the problem persists.
Plug the monitors power cord back into the rear of the device and power it back on.
This will reset the monitor and your display should now be focused properly.
Troubleshoot a TFT Monitor
TFT monitors can suffer from many potential problems, ranging from simple screen brightness issues to disconnected inverter or LCD cables.
These can cause video- and backlight-related failures on your TFT monitor.
Fortunately, you can attempt to repair these problems, even if you have no experience fixing a TFT monitor.
The only tool you will need is a Phillips screwdriver, although opening your TFT monitor will likely void its warranty.
Check the brightness settings on the TFT monitor.
There are dedicated adjustment keys on the bottom face of the TFT monitor.
If it is a screen incorporated into the design of a laptop, you'll find monitor adjustment keys on the top row of the laptop's keyboard.
A TFT monitor that has its brightness turned all the way down will appear to be almost completely dark.
Ensure the TFT monitor's power cable is still plugged in, if it is an external monitor. In the case of a laptop, make sure that the power cable is plugged in or that the battery is properly charged.
Disconnect the TFT monitor from the power source. If the TFT monitor is an external model connected to a computer tower, disconnect the video cable as well.
Remove the battery from your computer if you are using a laptop.
This is an important safety measure.
Turn the laptop over and slide the battery release mechanism over.
This mechanism is just below the horizontal outline of the battery on the underside of the laptop.
Remove the screws on the bezel of the TFT monitor.
The bezel is the plastic piece surrounding the TFT screen.
The screws will likely be covered with plastic seals for aesthetic purposes, so pop these seals off with your fingers and remove the screws using a Phillips screwdriver.
Pry up on the bezel gently and remove it.
Start at one corner and work along the bezel's perimeter with your fingers.
There will be small plastic latches between the bezel and the rest of the computer you'll need to disengage.
Check the TFT monitor's inverter cable.
This black cable lies at the bottom center of the monitor and should connect to a socket on the inverter board, which is the green color horizontal strip that lies just below the inverter cable.
If the cable is loose from the board, the TFT monitor's backlight will fail. Pull up on one side of the socket and slide the cable back in, then press firmly down on the socket to lock it down.
Remove the metal brackets on either side of the exposed TFT monitor if the inverter cable fix does not solve your issue.
There will be two to three screws in each bracket that must be removed using your Phillips screwdriver.
Pull the TFT monitor carefully away from the rear casing of the display to reveal the LCD cable. This cable runs from the back of the TFT screen and should be connected to a socket in a similar fashion to the inverter cable. If it is disconnected, lift up on the socket, slide the LCD cable back in, then press down on the LCD socket to lock it back down.
if you can get a screen
Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers
If your computer came with a motherboard disk the drivers could be on it
or you might download slimdrivers.
Rather doing a driver hunt
Windows XP/Vista/7/8
Note: it will find all of your outdated drivers
This is a free driver solutions
which will automatically search for and find the correct driver
You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
It might take some time being free
Aug 09, 2013 | HP COMPAQ 7540 CRT Monitor
R 51 video controller driver for xp
you download the drivers from
thank u,a rating would be pleasurable
Jul 10, 2012 | IBM ThinkPad R51: R51 P M 745 1.8GHz,...
I have vertical lines on my monitor and cannot make them disappear through any settings ? can anyone help
When does it appear on windows or before
If in Windows then uninstall the drivers of Display Adapter
Steps :-
Right Click my computer -> Manage -> Device Manager -> Display -> Uninstall -> Restart the Computer
Still Nogo
Update the Drivers of Video or display from Internet
Check if u can see same lines in BIOS Mode
Steps to go into BIOS
Restart Computer -> Keeping tapping F10 Key its a single Key on First Row of Kayboard
Check in that mode if u can see same lines over there contact View Sonic Hardware Problem
Jun 01, 2010 | ViewSonic Monitor Lcd 22in Wide Va2216w...
Resolution problem with AOC TFT 185W80PF
Monitors don't need drivers to function. Either you need to configure it or it's dead.
Mar 16, 2010 | AOC 19" LCD HDTV Monitor
Colors are off on various web pages--red links are blue--pictures and game screens are okay though --Windows XP Pro--TFT LCD Color Computer Display
install the drivers of display new if persist then insert AGP card in AGP slot of grade 8X because that is not problem inbuilt display card does not support games and movie
Mar 05, 2010 | Sony SDM-HX73 17" Flat Panel LCD Monitor
Just plugged a Dell E193FP monitor into my emcahine - running XP - turned it on and video display said ''cannot display this video type''
The computer is not able to communicate with the hardware properly. It can be solved installing the Video drivers (The video card drivers AND the display drivers).
Check for updates with the manufacturer of the video driver.
To determine what Video card your computer has, just right click in MY PC - MANAGE - DEVICE MANAGER and click Video, check properties.
Good luck.
Mar 27, 2009 | Dell E193FPp 19" TFT LCD Flat Panel...
Drivers for the Acer LCD monitor X193W under Windows XP Pro.
The acer LCD monitor is plug and play.You don't need a driver.But unless you have a graphics card that supports at least 1440x900 you have problems. Also if your card has a div connection, use that instead of the analog connector, The monitor comes with that connector. Use the old one to connect a second CRT monitor if you want. Don't connect both to the lcd monitor and to the computer unless you are using a second monitor. Like everything these days, every purchase seems to need an upgrade of sorts, On board graphics **** anyway. Buy at least a 128 MB graphic card with a digital connector and more RAM never goes astray.....
Nov 09, 2008 | Acer X193W LCD Monitor
Power light steady green but monitor goes dark after 4 secs of video
The video card in the computer could be going bad too or the driver for the video has corrupted. Try reloading the video drivers in the PC first.
Mar 29, 2017 | NEC MultiSync LCD1770V - Flat panel...
Samsung SyncMaster 510N LCD TFT Monitor
Does the monitor remain on does it switch off?
Problem seems to be hardware related ie monitor itself is defective.Try connecting to another known working system.If monitor is defective it could be a power/inverter related issue or panel could be defective.
Please provide feedback and rate the solution.
Jun 13, 2008 | Samsung SyncMaster 510N (Silver) 15 inch...
I would check the cable and connector pins first. Then I would suspect there's a problem with the video signal board inside the monitor. It could be the LCD panel controls, too. That would make the unit beyond economical repair unless you got a used one.
Jan 18, 2007 | Dell E171FPb 17" TFT LCD Flat Panel...
Microsoft Windows XP Home Edition Logo
372 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
