Question about Panasonic WORKiO DP-2330 Copier
Canon IR 2270 have erro E002-0000,how i can clear this erro or which part have problem
5 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: Canon iR-2016 System erro E007
check code here under canon
http://www.copier-help.com/copier-help/ecs/canon/eccgp215.html
Posted on Dec 04, 2007
Cogz
  • 1326 Answers
SOURCE: HOW TO CLEAR ERROR E350-0000
Did you recently clear RCON and tried to due a CCD adjust? The problem could be the that the left side glass retainer changed or mared or has a doc feeder been added or removed. There is a bar code on the under side of it. The part number for the 1000/3100 is FF5-4662-020, the 2400 FF5-8802-000
Posted on Feb 11, 2008
Cogz
  • 1326 Answers
The erreor code E007 has to do with the fixing ***'y upper film ***'y or roller. It is saying that the film is not moving in and out of "HP" Most of the time it means that the fusing film is torn and not moving properly. If you are getting paper jams in the fusing area and or unfixed or smeared copies. You most likly need to have the fusing film ***'y replaced. It could also be that it is out of place and needs to be readjusted. The only problem is that it's a little tricky to get to and not a bad idea to have a new film to replace the old one while you have it out. Good Luck
Posted on Mar 16, 2008
redzventures
  • 149 Answers
SOURCE: IR2270 copier displaied error code E000020-000
It's concerning the toner level in the dev unitor drum unit. Try entering service mode and selecting 'install' this will stir toner and try to feed toner through. Could be a dirty or faulty toner level sensor. Cuuld also be the drum life over - check drum life in the service mode. Check my other posts to see how to enter service mode
Posted on Jul 06, 2009
How to Clear Error- 000716-0010 in Canon IR2870 Copier?
E716 - There is an error in the communication with the pedestal.
After the presence of a pedestal has been detected, the communication fails to be normal for 5 sec.
1. Check the cable. Replace the DC controller
2. PCB. Replace the pedestal drive PCB.
http://www.smoothprinterservice.com/
Sep 22, 2014 | Canon Ink Cartridge GPR15 for iR 2270, iR...
IR 2270/2870g photo copy machine ,paper jam at the time of double side copy
Clean the vertical path rollers .they are located in the right door. check for obstructions. inspect your right door for broken parts and missing pressure springs that keep pressure on those vertical rollers. Make sure the right door is shut firmly.
Apr 11, 2014 | Canon Ink Cartridge GPR15 for iR 2270, iR...
E000716-0010
The error you are giving isn't a toner error. It relates to a loss of communication with the pedestal. Canon's service manual says to check the cable leading down to the pedestal. If still properly seated, replace the DC Controller Board or Pedestal Control Board.
Reference: Canon Service Manual Page 694. You may be able to locate the manual by a Google search. Search for "Canon iR4570/3570, 2870/2270 Series Service Manual"
Dec 08, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Hello , i have cannon IR 2270/2870g photo copy machine ,paper jam at the time of double side copy
There might be an issue with the feed clutch or fuser. It depends on where it jams in the machine.
Sep 27, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Open your developer unit and check sensor , refix it an close unit see........your problm solved
Apr 22, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Can the memory of ir 2270 copier be up graded?
there are 2 slots populate the other slot 128mb
Dec 03, 2009 | Canon Office Equipment & Supplies
Panasonic WORKiO DP-2330 Copier Logo
91 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
