Question about Acer AL1916W 19" LCD Monitor
I have two AL2216W acer monitors on a very powerful custom built machine for around two years now ... the machine was recently reloaded and now I have a constant "no signal" problem ... never before this has happened. I have read now somewhere there might be some problem with Windows XP and that some fix need to be run. (Also with Vista but I choose to stay with XP for the moment). The problem seems to sort it out by itself before with a few reboots and unplugging of random wires but it has since yesterday refuse to respond positively. I have tried the 30 seconds thing described above but no luck. Maybe the pavement is the answer ...
  • 11,361 Answers
When you get no signal problem , you should find out if the correct video card driver is installed, reseat the video card, RAM. I guess you already try this monitor with other PC and it is OK.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 11, 2010
  • wjprins Oct 11, 2010
    Thank you for the response. I got it going again (ok but has done so before) it seems however that the screens refresh rate was set to low and that possibly caused that the monitors did not "understand" the signal from the PC.
My acer al2216w screen flashes black and white every few seconds. power light is on with no flashing
hi. check out put voltage of supply board. if it was correct check inverter and lamps.
Apr 26, 2015 | Acer AL2216W LCD Monitor
I have an Acer Monitor AL2216W and it will come on, the Acer name appears, then no signal and then the green light goes to orange. Is this the power supply or what?
It will go into sleep mode if it does not detect the signal from the PC. Try is with other PC first, also make sure the cable is seated properly.Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Here is the inside of your monitor:
http://s807.photobucket.com/albums/yy352/budm/ACER/Acer%20AL2216W/
Dec 22, 2011 | Acer AL2216W LCD Monitor
Acer AL2216W 22" LCD monitor. DVI input apparently
Not Good..
After you've checked that the video cable is connected properly, make sure that all the pins in the video cable plugs are straight and not broken off. Then test on another PC. Make sure your CMOS battery has not gone flat, as some PC's will fail to load basic drivers if CMOS memory is lost. The battery should show no less than 2.5v, if it's marked 3 volts when tested on a multimeter. If you can't test it, just buy a new one at the supermarket or hardware, usually around $4.00.
Next thing to try is your Video Card . If it is an on board one like most are now, there isn't anything you can do but try another card in an expansion slot or fit a new motherboard. At this point, I'm sad to say, you're better taking it to a PC shop where they will have a few things at their disposal to try.
Jan 30, 2011 | Acer AL2216W LCD Monitor
You may have problem in the logic board, it uses surface monted components no much chance for DIY repair.
Service manual; http://elektrotanya.com/?q=showresult&megnev=Acer&megnev2=AL2216W&kategoria=monitor&kat2=all
The cases these days are hard to open, they use plastic finger hooks types, they go in easy but real hard to remove without damageing them.
Use thin flat blade to crack open at the bottom edge so the scratches will not be so noticeable, and work your way around, look out for cables attached to the front bezel also.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
My Acer AL2216W Black LCD Monitor all of a sudden is wavy & flickering!?!?!? Is there anything I can do about it?
Hello,i think your LCD monitor is faulty and you should consider replacement.but first take to a qualified service personnel.
Dec 22, 2010 | Acer AL2216W LCD Monitor
Why do I have to re-start my Acer AL2216w monitor several times before it will stay on?
Slow starting, no power or a flickering display are all indications of a failing power supply. Check out this article on our web site at: http://www.ccl-la.com/blog/index.php/repairing-the-acer-al2216w-lcd-monitor/ The power supply board in your monitor should be the DAC-19M010. To correct the problem you will need to replace the capacitors that are failing. You will need to replace 7 capacitors on the board. This does involve a bit of soldering but is an easy thing to do. If you don't want to do the repair yourself we do offer a repair service, you can get the details of that here: http://www.ccl-la.com/blog/index.php/service-request-form/ If you have any questions just let us know.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Aug 05, 2010 | Acer AL2216W LCD Monitor
My Acer AL2216W won't power on
This sounds like it could be your inverter or backlight. I would recommend taking it into a local computer shop and having it checked out.
Nov 06, 2009 | Acer AL2216W LCD Monitor
Same problem, acer sucks imo
I think I may have fixed it but I haven't rebooted my computer yet. I uninstalled the latest ATI driver version 9.3 and then installed an older driver version 7.3. Monitor now turns on and off and gets signal every time so far. I'll post back if it the problem comes back after I reboot.
Apr 08, 2009 | Acer AL1916W 19" LCD Monitor
AL2216W LCD monitor "Power status Green blinking" & No display.
LOOKS LIKE A BURN SOLDER !! , open the monitor , check the PC BOARD around the transformer area , look for burn spot or cold solder , RE solder it , try again , hope this helps please rate solution and thanks AJ
May 06, 2008 | Acer AL2216W LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
54 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
