Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
I have a Briggs & Stratton Intek V-Twin 20 on my John Deere riding lawn mower and it just started smoking and has a lacked power and died. Upon closer inspection I found that it would only run when I use starting fluid. I took off the OHV covers and discovered that one of the push rods was not in place and functioning to open and close the valve. I put the rod back in place and adjusted both valves on both sides and tried to start the motor. Once again the engine would only run when starting fluid was used. Do I have a blown head gasket? If so, where can I find help to repair it myself? Thanks.
  • 4,339 Answers
This does not sound like a head gasket issue. Your description indicates fuel flow issue. Items involved are fuel filters, fuel itself, and the carb.
Posted on Oct 11, 2010
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 188 Answers
Push rods don't just become loose! It sounds as if either something has broken or come undone. A smoking engine means that oil is leaking into the combustion space. So my guess is something is wrong with the valve gear. You will need to remove the cylinder head and verify that all is as it should be. You will need a cylinder head gasket set to be able to replace the cylinder head.
Posted on Jul 13, 2016
Just got used john deere riding mower model L118 with briggs 22 hp v-twin,runs rough and spits back through carb
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 07, 2017 | John Deere Garden
Have a John Deere lawn tractor with 20HP Briggs V Twin. Engine ran great four 4 years (200hrs.) then started having fuel problem. Changed filter didn't help, changed fuel pump didn't help, cleaned...
You could try sending your question to the Customer service on the Briggs & Stratton Website. Maybe they will be able to explain and suggest a good solution.
Sep 21, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Changing oil in Biggs and Stratton engine
Use 10W30 weight oil. The capacity is 1.5 Quarts (48 ounces) with filter change. I highly recommend you use 100% synthetic oil in an air cooled engine. Change the oil and filter every 50 hours of use.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engine smokes . is it worth fixing
Hi and welcome to Fixya. The smoking can be stoped with a new set of rings and some hand lapping of the valves and seats with grinding compound. If your a fair mechanic it would be worth the effort. A new 20 HP v-twin will set you back a good bit of money. The parts can be ordered either on line or you can get them at a local lawn mower parts supply. Rings are about $35.00 per cyl and the the gaskets are relatively cheap. Valve grinding compound you can get at any automotive parts store. Buy a new set of valve stem seals also if you do fix it.
I have seen new LT120's listed in the $1999.00 - $2299.00 price range.
Your call as to fix it or... not purchase the unit. Depending on the asking price.... and the condition of the Lawn Tractor it might be worth the time and effort.
Kelly
Apr 18, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical engine 24hp,48in riding lawn mower,keeps smoking.
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Oct 21, 2009 | Briggs & Stratton Briggs Stratton Intek V...
I have a John Deere L120 riding mower with a 22 hp Briggs & Stratto v-twin with approx 260 hrs on it. It has been smoking & using around a 1/2 quart of oil for about the last 100 hrs. of use.Would...
IF IT WAS MINE , MIKE ,I WOULD USE A HEAVIER GRADE OF OIL-----20--60 OR THERE ABOUTS PLUS PUT A SEAL SOFTENER ADDITIVE IN AS WELL,THERE ARE ANUMBER ON THE MARKET,I USE REDEX INTHIS SITUATION. THOSE TWO THINGSWILL GIVE YOU A COUPLE OF YEARS TO THINK ABOUT IT. "YOUDOIT"
Sep 21, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
1,527 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
