Question about Vacuums
My vacuum makes a wierd sucking and blocking sound when turned on and when you put the extension tube on the suction decreases...but when just the wand handloe is on the suction is excellent...we replaced the barrel thinking it was broken but that hasnt fixed the problem
  • amiefountain Oct 11, 2010
    fixed the problem after reading other posts!
  • 377 Answers
You did not list the make and model of your unit, so it is difficult to hunt for problems.
Check to see if any of the tube vents might be open. They should be closed when in use. Also check to see there are no holes in the hose and that all attachments are free of obstructions.
Posted on Oct 11, 2010
Central vac not sucking
Check for a plugged tube in the wall by listening to the motor when it's running. If it sounds like it's running too fast then there's an obstruction. If it sounds ok, then there's a disconnected tube somewhere in the system.
Sep 11, 2014 | Broan-NuTone CV353 Central Vacuum
I have a hoover Dust Manager DM6200. actually it is my friend's. She said it wasn't working well, so I took a look. It wasn't picking up, and seemed to be spreading dirt in fact. I emptied...
Hey Julie,
Hopefully we will get this solved together.
To me, this problem sounds like either the filters are choked up and cannot breathe, OR.... the bagless cannister is not quite sitting in the machine properly.
Honestly, I am more leaning towards the cannister not quite in properly, that is assuming that everything is out of the suction hose.
Start with the process of elimination. Remove and clean the filters with a paint brush or other brush. Get as much dirt and debris off of them as you can and replace them into the machine.
Turn on the machine, and using only the hose attachment, feel if the suction is there. If not, try a re-alignment of the cannister and check the hose. a small coin or marble running through the hose will tell you if there is still a blockage in there.
Where the attachment hose connects to the bottom of the machine could also be blocked up as well. This will also give the same effect of the dirt blowing out the bottom of the machine.
Lastly, it is also quite possible that the belt has stretched or worn out. This too will contribute to it not picking up.
Let me know if this helps, and we will go from there.
Good luck,
Mark
Jan 24, 2012 | Kirby Ultimate G Bagged Upright Vacuum
Dust bag was full and have changed it but not getting proper suction since bag change - why?
The extension tube is probably blocked. Check for suction with all the tubes off - if there is suction now then the tubes are blocked - be carefull not to damage them if you poke things in the unblock them.
Feb 13, 2011 | Miele Revolution 600 Bagged Canister...
The suction is only coming through the handle for using the attachments and i can't get it to suction from the bottom.
Hi its Darran at Dyson.
Sounds like you have a blockage in the extension tube or floor tool. With the extension tube removed from the wand and floor tool hold it up to the light. you should be able to see if it is blocked.
We have online support at www.dyson.co.uk which you may find useful, or if you are still experiencing difficulties, please call our Helpline free on 0800 298 0298.
Kind regards
Darran
Dyson Customer Service
Apr 14, 2010 | Dyson DC05 Cylinder Bagless Canister...
Decreased suction and high pitch whine in motor
clean out suction tubes ther is something caught in them
Dec 13, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC 14 lost suction to beater bar/ suction to hose/stick
My Dyson DC14 had no suction...see if this works...turn the Dyson upside down...there is a length of hose that connects the bottom of the vacuum to the top, careful remove one end of the hose and check for debris...mine was clogged. Removed the clog and voila...it works. Thanks for the above info on checking the hose for cracks.
Apr 11, 2009 | Dyson DC14 All floors Bagless Upright...
Won't ****
there is what they call an intake.disconnect the hose and see if it make the same sound.if not then its clogged up in the hose.if it still makes the same sound with the hose off then here is what you have to do.on the top of the base there are 2 slide buttons ,slide them outward to unlock the cover.remove the cover and you will see where the suction intake begins.it will be on your left side as your facing the vcuum.the tube sets into a slot just raise it up and look inside and see if theres anything in there.take a coat hanger with the end bent so it is round and work it down into the tube where you disconnected the hose.if theres anything in there you should be able to push it out with the coat hanger.you can take the bag cover off and remove the bag then you will see the outlet tube that dumps the dirt into the bag.see if there is anything there..see if you can blow into the hose if not thats where the clog is.if so take the hose off completely and put it in the sink and run water through it,better yet take it outside and blow it out with a garden hose
Jan 04, 2009 | Kenmore 35912 / 35913 Progressive Upright...
I have a dyson that is picking up just fine when on vacuum mode, however when I try to use the suction tube there is no suction at all. It is not blocked and the canister is empty. Help!
Hi, I have an upright DC03, brilliant machine. Mine wouldn't **** and had the following symptoms;
- it sucked ok from the top hole where the canister joins the unit - with the canister the dust didn't spin aroun inside the canister like it normally does and there was no **** at the hose end or brush end. - with the top of the canister attached (the cyclone) but not the bottom it sucked through the cyclone - the small valve on top of the cyclone unit was sucking heaps
this indicated to me the machine was sucking through the cyclone unit but when the canister was put on it was blocked - hence the tremendous sucking through the valve on the top of the cyclone. As far as I could see the cyclone wasn't blocked so I poked some wire down the tube inside the machine that runs from the bottom of the unit (where the hose sits) up to the bottom hole where the canister joins.
The DC03 has 2 holes where the canister attaches, it seems like it sucks air through the top hole, through the cyclone and through the lower hole sucks the dust up this inner tube into the canister. Check that tube, shine a torch from the top hole and you should be able to see the light at the bottom. Make sure you clear it completely.
Mine was very very blocked. I kept poking and removing dust until I could see light at through the tube. Works fine now.
Hopefully this helps someone as it took me awhile to work it out.
Good luck
Aug 12, 2008 | Vacuums
Loss of Suction
Thank you for this solution, it saved me $$$ and a trip to the repair shop.
Feb 23, 2008 | Kenmore Progressive Bagless Upright with...
Dirt devil mvp not sucking
Could be bad filters, is there suction at the end of the hose. That will tell you which direction to start looking. If no suction at hose end, then filters could be the problem. If you have suction, then the problem is down lower, dirt inlet is clogged, if belt has never been changed, then I am sure it has stretch to the point that under load it doesn't turn like it should. Could even be that although the motor is running, it may be running at a slower speed, in which case it would have to be replaced.
Oct 14, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
