Sony bravia klv-32s550a give me an "unsuported signal adjust you devise out put" am using a gt 240 ddr3 to connect to the hd tv via hdmi. I can hear the sound of windows loading via the tv speakers but the image remains blank i tried configuring the resolution to 720p but no luck what could bee the problem
SOURCE: HDMI connection not working
I have a DCT6416 which is essentially the same unit but with a bigger hardrive. I just had the same problem and was able to fix it.
First connect your DVR to your TV with the composite RGB cables and disconnect the HDMI. Then power your unit on. Then power it off (using the power on the DVR not a remote) and immediatly press the menu button on the DVR (not the remote). A white screen with black writing will come up. Using the down arrow buttons on your DVR go to the bottom line where it says "reset factory default" Toggle down to that and then use the right arrow key and your settings will be reset. Then exit out of that by powering off. Now remove your composite cables and replace the HDMI. You should be back up and running.
Posted on Feb 19, 2009
mjjdesigns
  • 98 Answers
SOURCE: sony bravia klv-32t400a hdmi input through x-box
The problem is that, according to the specs for that TV, it doesn't support 1080p.
That's a 720p television you've got. (Specs here)
While the specs say that it supports 1080p, the resolution says it supports 1366 x 768, which is only 720p, not 1080p or even 1080i.
You may want to contact Sony for clarification, because their specs for that tv are contradicting each other.
Posted on Mar 19, 2009
Big Hev
  • 64 Answers
SOURCE: PS3 wont go 1080i/720p
I don't think there is a way to set your resolution manually, bro. They do it all by auto. If I may make a suggestion... Turn off both the TV & PS3. Unplug your HDMI, then make sure both your TV & PS3 are turned ON. Now re-connect your HDMI. A TV tech once told me that these units "communicate" through the HDMI. This can only occure whilst they're up & running. This may help get you going on to 1080i.
p.s. PS3 games only output 720p, max! This isn't always the case for Blu Ray movies, but it is for games. Good luck!
Posted on May 23, 2009
  • 125 Answers
SOURCE: trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Posted on Aug 25, 2009
Testimonial: "very fast, thanks for the help!"
SOURCE: i hooked my ps3 up
hdguru.com/setting-up-your-new-hdtv/35/
Posted on Aug 02, 2010
My Sony Bravia model KLV-32S550A, can i watch movies there using USB? is there any usb port that can put an external or harddrive. thank you
If there is usb port on the set you could use a usb stick, or a external drive with its own power supply, go into settings and activate from there.
Nov 13, 2016 | Sony KLV-32S550A 32 inch Multi-System LCD...
LED TV double omage Sony Bravia KLV-32S 550A
If you wish to get some details; check the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size
Aug 21, 2016 | Sony KLV32S550A 32 LCD TV
Sony KLV-32S550A LCD TV double image.How to fix
Aug 21, 2016 | Sony KLV-32S550A 32 inch Multi-System LCD...
Sony 32 inch TV keeps shutting down on BBC 1 ? why
Hi
at HDMI may be some signals are disturbing the tv at BBC1 so please try to change the HDMI setting if the problem goes then ok other wise you may connect your tv box through AV
Feb 14, 2015 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Ps3 doesnt give out a surround sound output
Hi
In this configration you will not get surround sound. Because tv is not able to reproduse the surround sound through its out put from the HDMI input. You have to connect the HDMI of PS3 to the Onkyo receiver and the HDMI Monitor Out of the Onkyo to the TV. This can only done if the Onkyo AVR Have HDMI IN/OUT option.
If not the connect the Optical out of PS3 to any one of the optical input of the Onkyo receiver.
After that you have to goto the setup Menu the Onkyo and assing the optical input in wich you have conncted the PS3.
Aslo the following setting in PS3
Menu>>> Settings >>> Sound Settings >>> Audio Output Settings >>> Select the connector..= DIGITAL OUTPUT (OPTICAL)
Ajin
May 21, 2012 | Sony BRAVIA KDL-32S2010 32 in. LCD...
I have a Sony bravia 32" (KLV-32T400A) and have just bought an xbox.. On trying to connect it using the HDMI input an error comes up saying that it's not a supported signal. I also tried plugging my laptop...
All hd-ready tv's only support max 1080i and not 1080p. The default setting on the Xbox is 1080p, that's why you get that message. There is a way to fix this, just follow the steps below:
Connect TV and X box via HDMI cable with units switched off.
Switch both units on.
  1. Press the right arrow 7 times (Left top jog knob on game controller)
  2. Press "A" button 4 times (Green button)
  3. Press "up" arrow once to set to 1080i
  4. Press "up" arrow once again to set to 720p.
  5. Press "A" to store setting
Sep 12, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony bravia klv-32t400a hdmi input through x-box and p.c gives error reading - unsupported signal! check device output. both are on 1080p using hdmi to hdmi cable v1.3 why no vidio, only audio
Mar 19, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia
I have purchased KLV-40W400A Full HD but I am not satisfied with the picture quality. When the issue was raised sony is putting blame on Tata Sky and vise versa.
Kindly suggest.
Jun 19, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Bravia KLV-S40A10 HDMI input
I agree with your solution and you are correct in that you lose very little quality by using component instead of HDMI. there are A/V receivers that transcode HDMI inputs to component; as far as I know that's the only other option
Dec 25, 2007 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Computers & Internet Logo
229 people viewed this question
David Payne
David Payne
