Question about Blaupunkt Santa Cruz MP36 CD Player
How to remove a blaupunkt santa cruz mp36
Does anyone know how to remove the blaupunkt santa cruz mp36 cd player from my corsa?
  • Anonymous Mar 13, 2014
    Blaupunkt Key West MP36 Car CD Player
I'm afraid its a little bit late for corsamad11 but I've just spent hours finding that too much messing about taking a Blaupunkt Santa Crux MP36 in and out of your dashboard will almost render this great quality radio almost useless. Not being securely fixed in the dasboard.
The radio is held inside the mounting bracket by a metal strip each side which are supposed to spring closed to secure the unit. When the two keys are inserted each side of the radio they are supposed to push out these metal strips and at the same time hook onto each side of the radio behind two little lugs. This may work a few times but thats about all. The metal strips don't spring closed and the removing keys don't hook on the unit to pull it out.
Fiddle about with the keys inserted in each slot and at the same time try to push the unit further inside the dash. When this is achieved the mounting bracket lugs can be straightened out and the bracket can be removed with a narrow screwdriver as installed.
Just a very poor and flimsy design on a much loved radio.
Posted on Apr 26, 2009
Code come up first time ever 0000
that is due to the fact that you probably changed the car battery.
you will need to input the code.
If you do not have it, you will have to remove the car radio and post here asking for unlock code, provide the barcode number on the left side of the radio.
Aug 26, 2013 | Blaupunkt Santa Cruz CD31 CD Player
How do i change the startup volume on my Blaupunkt santa cruz mp34 car cd player/radio
If you are talking about the "auto volume" function. It should be in the same area as the vol, bass, treble, etc. It will only be a choice of on or off. hope this helps.
Aug 25, 2011 | Blaupunkt Car Audio & Video
I have a Blaupunkt Sevilla MP36 & there is a beep every 30 seconds. HOW DO I FIX THIS? it's driving me crazy!
Has this radio just been fitted into this car as it looks as though it is a VIN coded radio .
This means it has to be electonically linked to your vehicle ...and this is usually a job for the Main Dealer or a Radio Decoding Service
If not then try entering the Security Code
Jun 29, 2011 | Blaupunkt Sevilla MP36 CD Player
Need 4 digit code for a aftermarket blaupunkt radio with warranty number B692400168 serial number 69001114. It is a SCR 475 cassette player.
This is an older Blaupunkt with a different type of Security Code system.
Try here for free further advice and code ....CLICK HERE
Apr 21, 2011 | Blaupunkt Santa Cruz CD31 CD Player
Problem for Blaupunkt Bermuda MP36 Car CD Player. I was getting the error CD error when I use to insert the mp3 cd in the CD player. I complained and was asked to reset it by disconnecting the battery...
The fault was explained earlier, please check your MP3 format. play a normal cd to see if it detects, if so try with another recognised MP3. if not clean your head after opening the set. try again or it is possible that your optical is faulty or the RF signal processor IC is defective. Check this out. Good day
Jul 12, 2010 | Blaupunkt Bermuda MP36 Car CD Player
How to reset Blaupunkt Bermuda MP36 Car CD Player?
dissconect the power wire on your car baterry for three minits and connect it back
Jun 12, 2010 | Blaupunkt Bermuda MP36 Car CD Player
Blaupunkt sevilla rmd168 turns itself off and wont come
Have you disconnected your battery or any fuses recently as it looks as though it requires a code to be entered.
May 11, 2010 | Blaupunkt Sevilla MP36 CD Player
I have bought a 3 audio cd box set for my blaupunkt santa cruz cd player and it wont play any of the discs it just says 'CD ERROR' all other cds work fine.
There is obvioulsy and incompatability problem with the type of CDR that the cd's are and your head unit, Try making a backup copy of the CD's and try them in the player. This should resolve your problem
Jul 11, 2009 | Car Audio & Video
Blaupunkt Santa Cruz MP36 CD Player Logo
714 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
