Question about Omron Automatic Blood Pressure Monitor Options Large Adult Cuff Fits Arms 13 To 17
I have omron arm blood pressure monitor, wehre in Digital display - numbers are not showing properly. It gets cut. where should I get it repaiers i Ahmedabad, India. Or what is the solution to get it repaired
I HAVE A OMRON MANUAL BP MONITOR MODEL HEM 432C. THE DISPLAY IS NOT COMING PROPERLY. I WANT TO GET GET IT REPAIRED. PLEASE LET ME KNOW THE NAME AND ADDRESS OF THE DEALER IN THANE OR MUMBAI.
Posted on Nov 30, 2010
Hi, I have Omron HEM-780 , it is not measuring my blood pressure, showing error, even I replaced the new battery , please let me know how to rectify the problem.
found this on page 21 Monitor did not detect pulse rate Remove the arm cuff. Refer to "Applying the arm cuff" on page 13. Wait 2-3 minutes. Take another measurement
http://www.quickmedical.com/downloads/omron-hem780n.pdf
Dec 01, 2015 | Omron Health & Beauty
Omron problems
That is most likely caused by the ribbin cable coming loose or going bad at its connection
Jul 18, 2014 | Omron HEM 780 Automatic Blood Pressure...
Digital blood pressure monitor (distributed by Longs Drug) does not operate. New batteries installed. result high pitch hum
I guess you got a faulty device. BP monitor's should be accurate as they measure our blood pressure rate. I use Omron Health monitoring systems. I suggest you to try some other pharmacy, for such products.
Jul 17, 2012 | Omron Automatic Blood Pressure Monitor...
Insturctione how to use omronHEM432CN2
Taking your blood pressure is easy with the lightweight and convenient Omron HEM432C blood pressure monitor. Simply wrap the cuff around your arm and squeeze the bulb to begin inflation. In seconds, your blood pressure and pulse readings are displayed on the large digital panel. The Omron HEM432C has been tested, evaluated and proven to meet the rigorous safety and accuracy standards set by independent organizations.
Dec 05, 2011 | Omron Healthcare Omron Hem432cn2...
What is the m button for
Hope this helps you out
Sep 19, 2011 | Health & Beauty
Omron- HEM712C- why does the\r\ncuff opens,when trying to take pressure.
It's likely due to either improperly seating the cuff over your arm, or the cuff being sized to small for the circumference of your arm. First make sure that the cuff is set up properly, the "hook" end of the velcro needs to be facing away from your arm. Once you double the cuff back, make sure that it is not so tight as to be cutting off circulation. If this occurs the force of inflation will cause the velcro to separate. It's also possible that the package included to small of a cuff. If so the manufactor has a largercuff here. http://www.omrononlinestore.com/JHI/guid.569520918/~/productID.4509/US/details.html
Mar 13, 2011 | Omron Healthcare Omron Hem-712c Automatic...
My Omron HEM-712C digital blood pressure monitor is pretty consistently showing my pressure at 140-155 /80-95, but when my blood pressure was taken at a medical appointment yesterday, it was 92/63 -- a...
First, I do not believe there is any accurate way to measure blood pressure without having a valve installed; not a practical alternative.
The standard method using an arm-cuff and stethoscope is highly dependent on the person doing the measurement. Once my hearing started to fail, I had to go to a digital meter and found after three of these which failed and comparing my current Samsung to three different methods; manual, an elaborate 'calibrated' digital on a stand and another 'calibrated' cuff-type during an examination by a professional, none of these agreed better than 10-15 mm and the worst was 25-30 mm apart.
Using the average of those 'profis,' my current wrist-type digital measures about 10 points low on both systolic and diastolic so I just ignore the absolute numbers and use it only to determine relative deviations. For that, mine is repeatable enough.
Sep 16, 2010 | Omron Automatic Blood Pressure Monitor...
Where is omron bp monitor service center in india my bp monitor doesnot get enough preesure and shows no 50 on the screen.
call rehman on mobile no: +91-8754414889 for all your query of omron or other make of blood pressure monitor service problems
Jan 19, 2010 | Omron Automatic Blood Pressure Monitor...
When the pressure comes up on the monitor the top number was reading EE. It did it three times. I can't find the instructions. The machine is an Omron model: 741CREL. Thanks.
EE=Cuff under-inflated=not inflated enough. While cuff is inflated, keep pressing START button until pressure reaches 15-20 mmHg higher than the pressure when it stops and displays EE. Make sure at least 5 min allowed between readings.
Feb 21, 2009 | Omron Automatic Blood Pressure Monitor...
Omron Automatic Blood Pressure Monitor Options Large Adult Cuff Fits Arms 13 To 17 Logo
399 people viewed this question
Top Omron Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
jay kaye
jay kaye
Are you an Omron Health and Beauty Expert? Answer questions, earn points and help others
