Question about RCA L42WD250 42 in. LCD HDTV
Help rca 46inch
Rca 42 in lcd hd Menu works but no picture, no sound.DVD doesn't work either.The screen is black with unusable signal circulating all around.Changed cable to an older tv and it is working fine.Has to be TV.
  • 3 more comments
  • yomero261 Jul 25, 2008
    have same problem in this tv set
  • Shadow1021 Nov 07, 2008
    I have the same problem using HDMI cable. I tried 3 cables still same thing
    unusable signal. I'm using the composite and Screen looks really good.
    Not sure I can tell the difference between them and when the HDMI cables were working
  • Anonymous Mar 09, 2009
    Exact same problem. I have been trying to figure something out with the RCA company, but no one speaks English.
  • revlorri May 11, 2010
    I have this same problem...any solutions?
  • Anonymous Mar 23, 2014
    Viewing tv programs off of normal satellite feed ( not HD) picture is blurry. Fuzzy outlines around people and object.
I have the same problem using HDMI cable, I was able to get it working using composite or RCA
cables. I still cant get it working on none of the 3 hdmi inputs
Posted on Nov 07, 2008
The inputs on my RCA scenium dlp tv wont work.
It sounds like your talking about the ITC222 chassis series which is having a small signal board problem. Very common in the RCA ITC222 and ITC222A Chassis HDTV's
Jul 12, 2010 | RCA Televison & Video
RCA L46WD22 LCD tv (3 year-old unit)...No picture, tried unplugging for a few hours to ''re-set'' the computer...nothing, tried to view a DVD, nothing, just a black screen with the ''unusable signal''...
The back lights inverter is working because you can see the "Unusable Signal' on the screen, if the inverter is dead, yoo will see nothing on the screen at all.
If the T-CON (LCD controller) is dead, you will see just gray glowing screen with no pictures or text.
You may have problem with video processor in the main logic board (tuner, audio, source selector).
Parts for your TV:
http://www.shopjimmy.com/catalogsearch/result/index/?q=RCA+L46WD22+&stock=all&limit=100
This is going to be difficult repair since you do have a way to try out the replacement board to be sure that is the problem. RCA service person has that advantage of parts in stock to try out.
I estimate the board from Jimmy to be about $150, from RCA will be twice as much, plus labor.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 28, 2010 | RCA L46WD22 Television
42 RCA TV flashing unusable signal
Ur backlight video board it dead,must replaced.
Dec 05, 2009 | RCA L42WD22 42 in. LCD Television
HD50LPW42 screen is black with antenna inputs
It sounds to me like you have a tuner issue, I have seen this before. If you have a good picture from other sources and they have the same antenna input, the tuner is suspect.
I hope that this helps you solve your issue.
Thanks
asnowman
Aug 01, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
Picture appears for 3 sec then shows no signal
HELLO MAKE SURE ALL THE CONNECTOR CABLES ARE TIGHT ON THE MAIN BOARD IF THEY ARE OK CHECK THE INVERTER BOARD FOR DRY JOINTS GOOD LUCK
SHAUN
Apr 27, 2009 | Westinghouse W4207 42 in. HD-Ready LCD TV
"Unusable Signal"
Ok. PCB means Printed Circuit Board.
It looks similar to the picture down below. A part must have gone bad on your PC board. So, the RCA shop ordered a replacement PC board to fix the problem. It's an interchangeable part. All newer TV now have PC boards, which each one hold a different function.ebc3c7f.jpg
Mar 13, 2009 | RCA L42FHD37 42 in. LCD HDTV
Unusable signal
it was a fuse in the digital board i took it to an rca repair shop and had it fixed has been working great since
Sep 25, 2008 | RCA L46WD250 46 in. LCD HDTV
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
"UNUSABLE SIGNAL"
l have a 42 in tv rca connected from a direct satellite and i have no picture or sound tryed different connecters only black screen with unsable signal
Jan 07, 2008 | RCA HD65W140 65" Rear Projection...
"weak signal" on my RCA scenium
Hey! I have the same problem as you. But! this would happen only when I got a power outage. Unplug the TV for a couple of minutesand all was fine. For the last 5 day I have no TV. I have tried everything. All the out on the TV and I still get unusable signal. My rep told me to unplug for 24 Hours. Still didn't work. My menu option work as well and every time I put the TV on, off or if I change the input sound will come on for 2 seconde and stop. If I find the salution I will let you know. Gilles Ottawa
Jan 20, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA L42WD250 42 in. LCD HDTV Logo
511 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
