Question about Hobart Ovens
I need the wiring diagram for a hobart electic oven model cn 90 with 3 elements ,, there are 4 power wires ,, how do i hook the elements up
bigg t
  • 640 Answers
SOURCE: HOBART AM14F wiring diagram
I can tell you where the wires need to go.What are you trying to hook up on the dishwasher?
Posted on Feb 23, 2008
  • 68 Answers
SOURCE: Hobart HEC40 208V to a 240V source
The only difference should be the elements. Consider installing a buck-boost transformer. It may be cheaper.
The Hobart part number for the 240 volt element assembly is --
# 342170-00002. Your local Hobart can get you a price.
Posted on May 03, 2008
MNTECH
  • 1543 Answers
SOURCE: GE J BP27G R1AD Oven Not Heating Fully
Hi Jeff. You should have a wiring diagram with the range. Check for an envelope on the back of the range, inside the back splash, or taped to the inside side wall of the range if you remove the lower drawer. That all being said, first check to see if the start or stop time knobs on the timer have been pushed in (and possibly turned). If the clock runs, it will clear this out within 12 hours, but on these old ranges often times the clock no longer runs. Make sure these knobs are turned until they have "popped" out or you won't get the necessary voltage where you need it. Secondly, when a bake element burns out, it can cause damage to the electrical contacts in the oven selector switch (part number WB22X5122 ) which can be tested with an ohm meter if you can find the electrical diagram. Also, the oven thermostat (part number WB21X5320 ) can be damaged in the same way. Unfortunately, these parts for these old units are not very cheap.
The little bit of heat you are getting in your oven now is most likely only from the 120 volts going to the broiler element when in Bake. During Bake, your bake element should get 240 volts (until thermostat is satisfied). Setting to Broil should give 240 to the broil element.
Posted on Dec 14, 2008
danforddan1
  • 192 Answers
SOURCE: wiring diagram blodgett sho-e convection oven
I dont know much about Blodgett ovens other than how to bake in one and that are top of the line. I use to live next to the factory where they are made. On beautyful Lake Champlane Vt. Go here http://www.blodgett.com/convection_full.htm
you can contact them by phone.
44 Lakeside Avenue, Burlington, VT USA 05401
Toll Free: (800) 331-5842 Phone: (802) 860-3700 Fax: (802) 864-018
how about that. please rate me Thanks
Posted on Apr 22, 2009
  • 250 Answers
SOURCE: Oven wiring diagram or help?
I suggest you post this under Inglis to have a better chance of having an answer
Posted on Jan 26, 2010
Dont have oven service manual eb965611-01 to distinguish terminal lead hook up for broil element
unplug power. open oven door. unod screws holding element in place. pull straight to you. unplug and remember color cod to each terminal or place new element right under old one and replace it wire for wire. if not able to do that either write down or take photo of wiring.
Nov 22, 2014 | Ovens
Electric Phases for Hobart Oven
you must understand this : your electric oven must be indicate if it is a single phase( use 3 wires for 230 2 hot wires + 1 Neutral see the diagram like dryer? you must sure about this. Normally any appliance for home are single phase NOT 3 phase.
2) If you electric oven, say 3 PHASES( use 4 WIRES, 3 hot wires+1 Neutral wires) this for industrial application +comercial 270266c5-a0ad-44dc-9f40-e963255d47f5.jpgNOT for home
However if you system is 3 phase you must need to install 3phase transformer.ba1c9d4d-85e3-4744-8ce5-2f25c6e34ad3.jpg
Jul 18, 2013 | Hobart HEC501-240V Electric Oven
How do yo hook back up the oven glow bar wires without putting them in the wrong place.
If you are concerned about the two electrical wires that connect to a replacement heating element, don't worry. It's AC, the heating element is just a big resistor, and the wires are electrically interchangeable. Just make sure the connections are clean, the wires aren't mechanically stressed, the metal terminals aren't too close to the metal parts other than the heater connections, and the wire insulation won't be in direct contact with the heater.
If you have more than two wires, or you are talking about a mechanical issue like how to mount the heater element, you'll need to post back with the model number and a more detailed description of the problem (for electrical issues, include the wire colors). Many ovens have a copy of the wiring diagram somewhere inside the back of the oven - this will show what color of wire goes where electrically.
Dec 30, 2010 | Ovens
LOOKING FOR A WIRING DIAGRAM FOR A HOBART HR7
looking for a wiring diagram for hobart hr7 rotisserie oven
Nov 10, 2010 | Hobart HR7E Electric Single Oven
Need to change oven from 440 3 phase to 220 single phase hobart cn90 oven
It can be done with a transformer, 480/ 240 single phase transformer to get the lower voltage. Then the oven will require some wiring changes to get all the elements and controls connected to two hot wires instead of three. The transformed will be sized to the wattage rating of the oven. This is a only basic description of what needs to take place.
Sep 05, 2009 | Hobart Ovens
I bought a Hobart VC4ED from the military and it is in great condition. All records I can find indicate that the oven is primeraly sold in australia, the info steets show a 415/50/3. 12.5 kW hook-up. We...
ONLY, If you care to replace ALL the elements, The control circuit may have a transformer with mulitple taps to suit 220.If not, the control circuits will have to be changed to suit. 200V
Sorry for the bad news.
Jun 07, 2009 | Hobart HEC501-208V Electric Single Oven
Mar 08, 2008 | Hobart HEC501-208V Electric Single Oven
Feb 23, 2008 | Ovens
Bake element in smaller oven replacement
I always unplug oven or turn off power make sure though it will bite ya and hard after turning power off if you do it at the breaker turn stove top on make sure it don come on remember its 220volts and it hurts open oven door remove all racks.Then remove the screws mounting element to oven pull gently towards you (you may have to lift the front up a little) pull old element out until you see the spade connector (plug ins with the wires attached) remove these should be two of them be careful not to let wires go back into the cabinet put new element in hook wires back up to wires push back into the hole and put screws in turn power back on and test. this can also be done by taking the back off also and doing the same thing in the oven.hope this helps ya
good luck
Dec 07, 2007 | Ovens
Ovens Logo
136 people viewed this question
Top Hobart Ovens Experts
Dan Webster
Dan Webster
joneable
Level 1 Expert
Gil Shultz
Are you a Hobart Oven Expert? Answer questions, earn points and help others
