The problem is with the door switch intermittently disconnecting during operation or the door lock and switch assembly starting to go out. Make sure the door is closed firmly during operation then if the problem still persists, the only viable solution is the replacement of the door lock and switch assembly. Disconnect power then remove the clamp that secures the door gasket to the outer lip of the door opening. Once the clamp is removed, peel the door gasket part near the door lock and switch assembly off the outer lip of the door opening. Remove the screws securing the door lock and switch assembly then pull it out of the machine cabinet. Transfer the electrical wiring to the new door lock and switch assembly and install back into position. Reassemble the door gasket and the clamp assembly in reverse order of the removal steps.
You don't have
to
accept or reject and rate this post to add information
or post comments and follow-up questions. But accepting the solution
will not stop you from
communicating with the expert. You may continue communicating with the
expert as long as you need assistance regarding the issue stated herein.
The same error code appears to both top load and front load Samsung washing machines and indicates the same problem.
The lid switch is under the top cover and can be accessed by raising the said cover. Insert a putty knife blade between the top cover and the front of the machine at about 3 1/2" from the sides to release the top cover locking clips. But you have to verify first the operation of the lid switch by placing a strong magnet over the lid switch. You should hear the lid switch clicks when it activates and the machine should operate.
This is a top loading washing machine - it does not have a "door".
It has a top lid.
Thankyou for this. Do you have and instructions on dismantling the top load machine?
Like you gave for the front load.
Thaks
T
Thanx a lot for this assistance.
