Question about ACE Dimplex (r) Compact Electric Fireplace (DFP36430) Heater
I HAVE A MODEL BF8000ST, THE FLAME PART IS NOT WORKING, I CHECKED EVERYTHING INSIDE AND EVEN SWITCHED THE REOSAT WITH THE DIMMER SWITCH. IS THERE A WAY TO CHECK THE MOTOR FOR THE FLAME?
Http://dimplex.com/cms/publications/7208680300r03_EN.pdf
Posted on Jan 02, 2012
Highbeam work lowbeams done fuses and relay good what next
What is year--make--model of vehicle? Right now, I'd say, check the wiring circuit to and from dimmer switch. Could be dimmer switch, itself?
With wiring diagram, you can find proper color wire from steering column to low beam, everything on, see if voltage on that wire. I'm speculating that the dimmer switch controls voltage to low beam and not ground.
Under the dash, find wiring harness that goes into steering column, find proper color wire, test. If no voltage, when there should be, I think the problem is in the steering column, either wiring circuit or dimmer switch.
Nov 10, 2015 | Cars & Trucks
Purchased a Great World Ltd electric fireplace at BigLots. Model is either SWEO71 or SWE071. The flame and dimmer features are not working. Just put it together and mounted on wall, turned on, and
don't know this model, but does it have a light bulb inside? if so change it. they are often red or orange, but any will do to test it
Sep 13, 2014 | Heating & Cooling
Where is the dimmer switch on a 02 ford
Where is the dimmer switch on a 02 ford expedition? You know how to change from low beams to high beams ????? Where you do that at is the dimmer switch . It wouldn't be the dimmer switch , both low beams would be out . Which fuse's did you check ? Did you check fuse #26 10amp ,location - central junction box - inside the vehicle fuse box. ? Do you have daytime running lamps ?
2018 02 trainer SAP version
Free wiring diagrams here
http://www.bbbind.com/free-tsb Enter vehicle info. Year , make , model an engine . Under system click on lighting ,then under subsystem click on headlamps . Click the search the button then the blue link .
Did you check the bulb ?
Feb 27, 2018 | Cars & Trucks
Dome light wont turn off. have to disconect the battery cable while it's unatended so it doesn't drain the battery.
Didn't list the year or model or car or truck or even the engine size or country it was sold new in. ( laws are different countries ) the cars and trucks are made with some differentes. the dome light can stayon because the dome switch is on. The headlight switch can be turned all the way or the dash gauges dimmer can be turned all the way up, On some model years you can turn it all the way down and the dome ligh will be out even with the door open. Some models don't turn off this way and you'll have to find the door switch thats not working. Sometimes going around and slamming each door will find the bad one as it'll blink the light or it might even start working again. If the car or truck has a hatch or trunk theirs a switch on some of them too the vans and suvs all do. The switches on some yaers ( current model till late 80's) the switch is incorperated into the door latch itself. Their hard to get too and it requires taking the inside door panel off to get to the latch and then some latches have to be removed to get to the switch thats screwed ( 1/4 turn) inti the side of the latch. The drivers door sets and resets sereravl things so just unplugging it won;t work. Removing the dome light fuse will fix it too but some radio functions might not work on certain models as the cruise control. Everythings intertwined, How much so depends on the year ands model.
Jan 19, 2011 | Ford Bronco Cars & Trucks
Why does my dimplex model bf8000st fan and heat turn off after 2 or 3 minutes? the flame lights keep working, just no fan or heat.
"Resetting the Temperature Cutoff Switch
This unit is equipped with a thermostat which controls the temperature
of the room by turning the heater on and off. The heater is protected
with a safety device to prevent overheating. Should the heater
overheat, an automatic cut out will turn the heater off and it will not
come back on without being reset. It can be reset by switching the
Main On/Off Switch to off and waiting five (5) minutes before switching
the unit back on."
http://dimplex.com/cms/publications/7208680300r03_EN.pdf
Dec 13, 2010 | Heating & Cooling
My Lutron dimmer/lights suddenly will not turn on. all electricity works throughout the house. The green light that usually is lit on the panel is not on either. any suggestions?
Indicator light is OFF.
Either dimmer stopped working or power to dimmer is off.
Check if electricity is present inside box.
Check nearby electrical plug to see if everything nearby has power.
Swap dimmer with regular switch and see if lights turn ON.
Check dimmer wires: if wires to dimmer are pushed into 'quick connect' holes on back of dimmer, these wires can get loose.
If dimmer is connected by wire nut, sometimes a wire can pull loose.
If no electricity is inside the box, and breaker is ON, then there is a loose wire inside one of the boxes on that circuit and electrician has to track back until loose wire is discovered.
Replacement parts for in-wall devices are not made.
If new dimmer is necessary, consider lighting factors:
Total wattage of lights. New dimmer has watt rating.
Type of lights. Dimmers specify florescent or tungsten (incandescent) or both.
Single-pole and 3-way. If two dimmers control same lights, one is control dimmer, other is companion dimmer.
Nov 15, 2010 | Lutron #MA-LFQHW-WH 300W White SP Light...
I recently installed a aspire rf9534ds dimmer and a 9542ab accessory dimmer in my home. Everything works, but on the accessory dimmer the amber light stays lit all of the time. On the master switch the...
I was reading one of the Lutron Maestro accessory dimmer manuals yesterday, and it showed how that little light was also a fuse that you could remove to turn off power. I didn't read exactly why it has that fuse.
You might check your manual to see if that is the same feature on your accessory dimmer.
Oct 23, 2010 | Cooper Wiring Devices Aspire Smart Dimmer...
Dimmer switch does't dim
If this is a new dimmer, please check the wiring.
If you are having a problem with wiring, re-post your question with exact model number
If your dimmer is old, the electronics inside dimmer have probably gone bad
When buying a new dimmer, watch for two things
1) is dimmer rated for enough wattage?
2) Is dimmer 2-way or 3-way
Oct 16, 2010 | Lutron 1000-Watt Incandescent Dimmer...
Dash lights quit working
I had to replace my dimmer switch when this happened to me even though I thought my dimmer switch was fine
Aug 23, 2009 | 1992 Chevrolet K1500
Code continous flashing
If your igniter comes on but no ignition, that eliminates the possibility of a bad or clogged pressure switch, high limit or flame rollout switch. Sounds to me like you have a control board, or a gas valve going bad. Could even be some loose, corroded, or faulty wiring. Before the igniter comes on the furnace does a self diagnostics to ensure everything is working, or the furnace will not make it to the igniter sequence. Inducer motor, pressure switch/s, limit controls are closed…then comes on the ignitier, gas valve opens, pilot runners and burners ignite, flame sensor detects the flame, blower comes on and all operations are working.
Hope this helps
Oct 27, 2008 | Goodman GDS80904BNA Open Flame Heater
Heating & Cooling Logo
475 people viewed this question
Top ACE Heating & Cooling Experts
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
Tim Whalen
Are you an ACE Heating and Cooling Expert? Answer questions, earn points and help others
