Question about LG WD-1045FH Front Load Washer
Lg wd model wd-12336ad fault code 9 comes up - LG WD-1045FH Front Load Washer
Why does my LG washing machine model WD(M) 16115FD show error code dE?
It appears to be a problem with the door? You can go to the following link and try their troubleshooting, hope it helps. http://www.ehow.com/how_7850983_troubleshoot-de-code-lg-washer.html How to Troubleshoot DE Code for an LG Washer eHow
Aug 10, 2014 | LG WD-16115FD Front Load Washer
Wont start machine error come up
Door open error code can also be displayed as "dOE" On non-display panel models this fault code is denoted by the light for the door lock being lit or flashing.
  • Check door is closed correctly and latched
  • Check door handle for damage or wear
  • Check door safety lock if inoperative replace door lock
  • Check door lock wiring
  • If there is a clicking sound once or twice when the Start/Pause button is pressed the main control board may be faulty
Apr 08, 2014 | LG WD-1280FHD Front Load Washer
SE is appearing on the screen of LG washing machine
LG washing machine error code SE indicates a "motor fault" although the error code also says it could be a main PCB fault. They recommend to, "try the motor first". It's vague and you really need an engineer to try and sort this one. You can't possibly justify "trying the motor first" if you are a DIYer unless you at least know how to test a motor for faults and check its connections and carbon brushes (if fitted).
Aug 29, 2011 | LG WD-80130F 7.2kg Washing machine
I need a manual in English for Model WD 1070(0-9)MD
I have the service manual of LG WD 1041-1042 front load washer, I think it's same to WD1070 you are finding.
please send email to me, I'll send the manual to you
email: tangcamminh52@gmail .com
Tang cam Minh
Jul 11, 2011 | LG Washing Machines
OE Error
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!!!!!!!!!!!!!
Jul 13, 2010 | LG WD-14124RD Front Load Washer / Dryer
Main circuit board faulty
SE is 'sensor error' This could be anything from a loose wire to a faulty Hall sensor or even a main board failure......You probably need an LG technician. Your machine sounds like it's worth repairing.. Get quotes.........Good luck...Nomess
May 30, 2010 | LG WD-16115FD Front Load Washer
Fault codes
found fault to be in motor assy
Jul 01, 2008 | LG WD-1045FH Front Load Washer
LG WD-1045FH Front Load Washer Logo
35 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
