Question about BenQ FP91G+ Monitor
Hi My Benq FP91G flickers with the auto syncing message around once every 60s. sometimes the power button does not work, i have to keep pressing it before it will eventually switch on. Is this worth fixing or should i bin it, thanks
    Master:
  • 644 Answers
Its worth fixing...
Its just an issue with the board.
If it happens to be the LCD panel, rather not fix it since its gonna cost u a fortune.
Posted on Oct 11, 2010
  • barry_brindi Nov 18, 2010
    Last time I checked, my FP767 is an LCD monitor. It's a good thing prices have come down, I was giving thoughts to buying a new monitor. Thanks for answering.
When I turn on my nuvi 200 it says press dot. When I press the dot it just moves around the screen to different location.
To calibrate the touchscreen on your nuvi 200 series follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To calibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position. Once unit powers on release the power button.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
//changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 09/30/2010
Oct 23, 2010 | Garmin nuvi 205 GPS Receiver
Benq FP91G 19'' fades out
Capacitor problem on the power board internal solder fix is possible.
Jan 31, 2010 | BenQ Computers & Internet
Garmin nuvi 205, sometimes it won't respond to my touch. Sometimes when I go to give it a name or address it just keeps repeating a letter, "aaaa, or jjjj. then when I touch the botton to go back or clear...
Your touch display is shorting out....BAD
Replace Unit
BUT try this first:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 series follow the steps below:
To recalibrate the touchscreen on your nuvi 205 series follow the steps below:
Does this help? Let me know. Thank you...
Nov 03, 2009 | Garmin nuvi 205 GPS Receiver
I need to reset the lamp timer on the projectore, I have read the instructions: hold exit button for 5 seconds then press auto, but nothing seems to happen, as a matter of fact the power button won't even...
unplugg it, plug it back in, turn it on, wait until the message comes up about the lamp hours, press the exit button for 5+ seconds, press the auto button to get it to zero, wait for the display to disappear. if you don't even get a display, it should already be reset. if the buttons don't work at all, there might be a problem with the button panel or an obstruction underneath.
Oct 03, 2009 | BenQ MP610 Multimedia Projector
Pc wont boot up, instead a red light flickers.
Flickering LED means power supply is overloaded with something. It might be inside of the supply, but sometimes it is something else. Try that:
1. Disconnect everything from the motherboard except power supply and power button;
2. Disconnect all power connectors from all drives;
2. Remove any cards from the motherboard so all you have is power supply and motherboard with CPU and RAM, nothing else. You can keep connected the monitor and keyboard;
3. Press Power button. Will motherboard turn on normally?
If no - check electrolytic capacitors especially around the CPU, if some of them are "popped" replace them.
If yes - connect drives and cards one per time to localize the problem.
Sep 14, 2009 | Compaq Evo D500 PC Desktop
Auto Adjust keeps popping up
Is this a computer moniter or a tuner/tv
Aug 02, 2009 | BenQ FP71G 17" LCD Monitor
Auto sync appears to not work properly
The projector does not recognise a vista display res. Change the pc to the native res of the projector for best results
May 19, 2009 | BenQ PB8250 Multimedia Projector
Power
    Try these steps!
  1. Insert a Wii Balance Board compatible game disc in the Wii console.
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
Sep 09, 2008 | Nintendo Wii Fit for Wii
BenQ FP91G+ Monitor Logo
272 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
