Question about Hotpoint HSS25GFP Side by Side Refrigerator
Fan not shutting off
We had a service call done yesterday on our refrigerator. The problem was the sealed system lost its freon. The tech installed a new compressor, freezer coil and another part. Everything works except the fan runs all the time. How do we fix this
JohnK
  • 2 more comments
  • johnancy May 31, 2008
    The one in the freezer seems to be running all the time. I am not sure if the compressor is also running all the time or not.
    Thanks
    How often does the frig go into the defrost mode?
  • Anonymous Jun 06, 2008
    MY FAN MOTOR SEEMS LIKE IT IS ALLWAYS RUNNING VIRGINIA
  • James Helmer
    James Helmer May 11, 2010
    Which fan runs all the time? The one inside the freezer compartment or the one in the back that cools the condenser?
  • 828 Answers
The freezer fan will run at all times with the exception of when the system is in the defrost mode. This is a normal condition. The air circulation fans use very little power and are of low wattage. The fan by the compressor cycles on and off with the compressor.
Posted on May 31, 2008
  • James Helmer
    James Helmer May 31, 2008
    Defrost mode on some models is every 8 to 12 hours. Some models go by the amount of door traffic ( openings and closings).
How I add freon to my water dispenser
Many of these machines, as well as some compact refrigerators, have completely sealed systems that do not have recharge ports available. This is to save money in manufacturing, as well as the fact the for the price of a service call you can probably get a new one. If your unit does not have a charge port, the service tech will need to install one. That requires him to pierce the system, recover the refrigerant, install the port, and recharge the system. It is not a DIY job. If you are certain that the problem is low refrigerant, then you're best option is get a new one.
Nov 23, 2015 | Water Filters & Coolers
Hotpoint. What kind of Freon does my refrigerator take?
Most likely r134A freon in that fridge. But Ifs leaking freon, You need to find and fix it. I replaced all sealed system on this Hot Point/ GE refrigerator, but You will need to call tech, to do it.
Jun 06, 2015 | Refrigerators
My refrigerator not cooling.
If you have a leak, R22 or Freon is no longer used and must be replaced with R407C a similar product that doesn't destroy the Earths Ozone layer.
Sealed units are replenished by using a collar with a tapered screw that pierces the pipe, it is then drained and refilled with R407C.
When the 'tap' is inserted, the pressure can be monitored inside the compressor pipes to tell if there is a leak or not.
Feb 28, 2017 | Refrigerators
My refrigerator has lost its cooling ability. The freezer gets cold at he lower half, but is not cooling at the top half. The refrigerator compartment is barely cooling. i have cleaned "vacuumed"...
I'd be willing to bet a chili-dog dinner that your refrigerant piping system has sprung a leak. Your symptom is classic for this problem.
The charge you mention is the refrigerant, commonly known as "freon".
We look for a "temperature Differential" when diagnosing refrigerant systems. The difference between the upper temperature and lower is due to a lack of or leak of "freon".
A normally filled refrigerator will more likely have a smoother temperature differential. Not as definitive a difference like you mentioned.
Refrigerant pumps into the refrigerant piping system from the compressor and fills the piping in liquid form, liquid freon, then dispersing into vapor as the heat is absorbed. That's thermodynamics 101, but don't memorize that.
There's a couple things you can try to restore the performance.
You've already cleaned the rear coil, the condensing coil, so there's really only one thing left to try and that is the cooling fan itself. Some fridges have 'em, and some don't.
If yours has one on the outside bottom the fan should be turning when the compressor pump turns on. You'll hear them running or see the blade turning.
If it doesn't have a fan outside, then you're most likely course is to get the leak fixed and recharged.
When calling for service and you suspect a refrigerant leak; make sure and ask the service company how they seal your fridge or air conditioner. Get the guarantee in writing.
I use liquid sealer installed inside the refrigerant piping. Like your car's radiator and leak sealer. Seals from the inside out. I guarantee for life, they might too.
Let me know how this turns out.
Russ
Dec 23, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ge Refrigerator not cooling. The Fridge seems to be cool, but the freezer is not keeping items totally frozen. I removed all the food from the freezer, pull out the unit, cleaned the dust and dirt from the...
This sounds like a typical freon leak, and you haven't lost much from what I can tell. Any decent AC or Fridge tech can recharge you for a nominal fee. Just be sure to shop around for the best pricing. I recommend an AC specialist since they won't overcharge you the way a Sears appliance tech would.
Mar 13, 2010 | Refrigerators
How to add freon?leak fixed but can find the nipple to add freon.
there is no nipple to add freon, but there is a service valve.. this is a sealed system, only someone with their lic should be adding refrigerant
Oct 02, 2009 | Refrigerators
True gdm-69
http://www.truemfg.com/pdf/InstallManuals/GDM/gdm_english.pdf
The above will take you to the installation manual for your unit. This is to make sure you have set up the unit to their specs.
There are multiple things that can cause a lack of cooling. Let's cover a few of them.
1: Make sure the condenser coil under the unit is clean. You have to be able to take a flashlight and see light through the coil and fins. Be sure unit is off when cleaning. Use vacuum, compressed air, or a long, stiff bristle brush and go with the fins direction so they do not bend over.
2: The termostat may be set wrong or is not working as designed. Look for the compressor and fan on the condenser to cycle off when temp is met and on when it gets too warm. If unit is running all the time, look for frozen up evap.
3: If evap is frozen up, no air can pass through so no cooling is taking place. Air can not go through a solid block of ice. Clear ice with warm water. Again, make sure unit is off first.
4: Door not sealing or closing all the way. Seal on door should have magnets that help seal them to the door frame.
5: Again, if unit is running all the time, as in #2 above, unit may be low on refrigerant (freon). If you suspect this to be the case, have a qualified tech do the repair. Make sure he locates and repairs the leak. Adding freon without the repair means he will be back to do it a second time. The system is a sealed one and you should not have to continually add freon.
Good Luck and hope this get you going.
May 09, 2009 | True GDM-69 Refrigerator
Hotpiont side/side HSS251FMB not cooling
Compressor might be working but you may have lost some freon. Continued operation with low freon can lead to other problems. This may require a service call since recharging freon can only be done by a service professional.
Apr 30, 2009 | Hotpoint HSS25GFP Side by Side...
Fridge Compartment Ice
Freon can still be used but only by service professionals. The 134a coolant is not compatable with the old freon system without changing the seals.
Apr 30, 2009 | Refrigerators
Kenmore Refrigerator: Freezer not freezing
a blocked condenser can cause a warm up situation,and after youve done this you have to wait 24 hours before making desision on out come.but other possiables are condenser fan motor slow,its fan blade dirty.defrost problem,frost on back frezer panel can be a sign of issue.evap fan moving air slow[inside fan]run time,is it running enough[thermostat controls that]if all those ok could be restriction in sealed system,that where the freon curcit.if moisture,or particles they can get caught in the cap tube[small tube to create persure so then freon expans to a gas]that should give you a few ideas.God bless ,tom
Jan 04, 2009 | Kenmore 53642 / 53644 Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
100 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
