My monitor is not supported vga, message comes out of range
    President:
  • 2,185 Answers
If the message says Out of Range, then your computer's motherboard is high end and thus needed a higher monitor specs like that of an LCD monitor.
Please let me know if you find this advice useful or if you needed further assistance.
Posted on Oct 11, 2010
Lg flatron L222ws
your refresh rate is not supported, lower the refresh rate, try to enable vga mode, or enter in safe mode and uninstall your vga drivers ans reinstall it. i have done that when i had the same trouble.
Jun 17, 2013 | Computers & Internet
Tip
Fixing 'Out of range', 'Format not supported' message
When the video card signal exceeds the frequency allowed for the monitor, the following error message may occur:
Sync out of Range, Out of range, Format not supported
SOLUTION (FROM HP):
To avoid the message, lower the resolution or vertical frequency of the video card.
Reboot the system and use the VGA mode to force the video card driver to lower its resolution. Follow these steps.
1. Shut down and restart the system.
For consumer systems such as HP Pavilion desktop PCs, push the Power button once.
For commercial systems such as HP business desktop PCs, hold down the Power button for five seconds.
2. Immediately after seeing the HP/Compaq logo screen, press F8 at system startup to initiate the bootup menu.
3. Scroll down to highlight Enable VGA Mode , and press ENTER .
4. After Microsoft Windows completes its bootup process, access the Display Properties and select a desired resolution, which is compatible to the connected monitor. Reboot
Resolution adjustment:
From Microsoft: http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/display_change_screen_resolution.mspx?mfr=true
and here:
http://www.helpwithpcs.com/tipsandtricks/changing-screen-resolution-win-xp.htm
and here:
http://www.videojug.com/film/how-to-change-screen-resolution-in-windows-xp-and-windoiws-7
on May 21, 2010 | Computers & Internet
Monitor not connecting to tower. it is plug in to the tower. but shows that it is not connected.
three things can be the issue here:
1. No signal from the tower (VIDEO CARD)
2. Bad cable or bent pin on the d-sub 9-15 pin vga connector.
3. Bad signal board inside the monitor itself.
Things to try:
1. another computer.
2. check the signal cable for bent pins.
3. check the video card in the tower.
Before you "think its a bad monitor" you always want to assume the computer first as computers are 9 times out of 10 why the monitor is not coming on such as BIOS errors, Bad video card, bad power supply etc etc.
PLEASE BE CONSIDERATE! When rating and leaving positive feedback for your free answer today.
May 27, 2010 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
An Out of range box
frankr2327
If you are getting this message this means that you are connecting a device to the monitor and/or a connection that is putting out a signal that is not supported but the monitor. You may also need to look at the cable you are using. Example I have an XBOX 360 with the official VGA cable when I use it to connect to my monitor it works fine. However I have been testing cables to get a setup for my PS3 as I have not been able find an Official one from Sony. So when I connect my RBG to VGA cable to the end of my RGB XBOX cable then to my monitor I get an Out of Range message. So something with the cable is case a problem with the signal to not to be sent properly.
Note with monitors they have a safety feature that they would turn off if they got a signal they did not properly support and/or not read properly. This has always been there they just not got where they would show you a message. Plus with monitors getting bigger they have stopped supporting lower resolutions so you may see this issue more often when hooking up older devices. I my self still have a 15 and 17 inch on my work bench for toubleshooting.
Hope this helps clarify things. Feel free to reply back with what device you are having trouble with.
Issken
Dec 30, 2009 | Envision Computers & Internet
When i plug my computer in to the vga port i get a message on the screen saying out of range
That message is usually a sign that the computer is set to a high resolution, and the monitor doesn't support it.
You can go to the Settings and change it to a lower resolution
Don;t forget to rate this answer if it helps
Dec 12, 2009 | X2Gen Computers & Internet
My ViewSonic computer monitor keeps displaying a Vga Not Support Message upon booting then the message Out Of Range comes up on a completely dark screen. Need Help
It sounds like the computer is trying to use a resolution that the monitor cannot handle. Boot into safe mode by pressing the f8 key during boot up and select safe mode. Once booted, right click on the desktop and select properties. In settings lower the resolution by moving the bar to the left and reboot.
I would move it all the way down, you can then move it up a step at a time once you are in normal mode again.
Hope this helps
May 02, 2009 | ViewSonic VA721 17" LCD Monitor
Problem with lcd 22'' tv come monitor connection
firstafal youtell that detials you working to onborad vga are addan vga tell ok aftar you insttall that display drivers
Nov 25, 2008 | Samsung Computers & Internet
Signal out of range
1: Signal out of range meas the monitor can't handle the input refresh rate. lcd and Tft monitors usually supports 60 and 75Hz refresh rates.
2: The Resolution you are using to view the desktop is too high, this number is depending on the size of the lcd monitor.
a 15" lcd usually runs with: 1024x768 with 60hz
a 17" lcd usually runs with: 1280x1024 with 60hz some of them supports 75hz.
a 19" lcd usually runs with 1600x1200 or higher.
I recommend reading the user manual if you have it, or checking the information on the manufacturer's website.
3: As a solution turn on your computer and after it passes the bios screen press F8 and select VGA mode.
This will enable 640x480 (standard vga) resolution and 60Hz refresh rate, after windows boots up you can change thease nmbers , and windows automatically asks for turning to 800x600 60Hz.
If you want to change the resolution go to: Right click on your desktop, select properties , select settings tab, and adjust the resolution on the bottom of the window.
Hope this helps, good luck.
Nov 10, 2008 | Kogi L7CH Monitor
What does out of range mean on my asus lcd monitor i am trying to hook up my ps3 through my vga port
Out of range is comes when the monitor is not working with the cpu. May be you are not connected it well . and you can see the message out of range when the operating system is shut down.If it shows message when the cpu running please connect the vga cable into the graphics card port.
Apr 29, 2008 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
