Question about Janome MyLock 644D
The first needle thread keeps breaking as it is sewing, while it has material under it, it seems to work for a while but as soon as the material is finished the thread breaks. I've changed thread, changed needles but still the same problem.
  • Janome Master
  • 7,365 Answers
Could the tension be adjusted to tightly
is thread feeding off cone/spool freely
also check to see if there are any burrs on the loopers or on the throat plate
here's a tip I learned from a needle & thread expert about needle & thread compatability
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Happy Sewing
Posted on Oct 11, 2010
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
Top thread keeps breaking. Adjusting the tension does absolutely nothing. It seems as though the thread is getting caught on something inside the machine between the thread guide and thread take-up lever....
these are suggestion, if they don't help then the machine needs to be checked at a sewing machine shop
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Sep 27, 2013 | Euro-Pro Sewing Machines
My thread keeps breaking. bobbin thread seems to be alright, have changed thread, needle.
The needle thread breaks
Dec 16, 2012 | Kenmore 19606 Computerized Sewing Machine
Thread keeps breaking
Aug 17, 2012 | Singer Confidence 7469 Mechanical Sewing...
I have an xl2230.today the needle broke so i replaced with new one,and now the machine wont sew properly,its banging sometimes when it sews and the thread keeps breaking at the needle end and the fabr
try another needle
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area for lint or threads
if none of these things help then I suggest the machine get's serviced just
incase the timing is messed up
May 31, 2012 | Brother XL-2230 Mechanical Sewing Machine
Thread keeps breaking on my singer XL 5000. Seems like after i cleaned lint out of bobbin area i started having the problem
Mar 17, 2012 | Singer Quantum XL-5000 Computerized Sewing...
I keep having problems with the stitching on my machine. 1) when you sew the stitches looks normal from the top but when you turn the material over it looks like one big tangled mess. 2)When it does...
It is usually in your top threading, make sure that your thread match in bobbin and top threads. Mixing sometimes causes a problem. Also make sure that nothing is tangled. Also, check your needle and put a new one in just to be sure, then check your manual for size of needle and what kind of project you are doing. Hope this helps.
Sep 26, 2010 | SINGER 7470 Sewing Machine
Thread keeps breaking when sewing through thicker materials
When you sew any thick material on any machine the needle cannot form the loop properly as the needle comes up because the material is keep the tread tight to the needle, the only real way round it is to sew slowly.
Jun 23, 2010 | Consew 206RB
The needles on my Janome 9102D keep breaking
I had a similar problem with my machine. What I've started doing with mine is setting the stitch length at 3 and the differential feed ratio at 1.0 then I set all 4 thread tensions at 3. I thread the machine from right to left, and then when everything seems to be working okay I take scrap material to test the tension and then set them to suit the material I'm using. Right now I'm working with a twill so my settings are 4-4-5-5. This seems to have stopped the thread slipping off the bottom looper and I haven't had any more needles break. I hope this is helpful.
Dec 02, 2008 | Janome Harmony 9102D Mechanical Sewing...
Thread breaking.
it doesn't take certain needles. Make sure youre tension isn't too tight, both top and bobbin. Also I found with my Euron Pro that the thread needs to be at the back and I have to hold it kind of tight when I start or it will bunch under the plate and break. Hope this helps. Feel free to email me at DizzyAnjel@rogers.com if you need help with tension settings
Apr 20, 2008 | Euro-Pro Easy Sewlution 385 Mechanical...
Janome MyLock 644D Logo
128 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
