Question about Onkyo TX-SR605 Receiver
Barely hear subwoofer
Have a powered subwoofer hooked up to the tx-sr605 but can barely hear the base. Do I need a special cable.
I had the same problem initially, but going through the auto speaker setup, the receiver boosted output to the subwoofer to compensate. Seems ok now.
Posted on May 31, 2008
Where to connect subwoofer
The subwoofer has its own RCA output on the back of the receiver and needs to be plugged by RCA cable from the receiver to the sub. This would be for an "active subwoofer" with its own amplifier and crossover that needs to be plugged into the wall.
Sep 09, 2010 | Onkyo TX-SR605 Receiver
Tip
Onkyo TX-SR605 Remote Codes
Download Onkyo TX-SR605 Remote Codes
4 Digit Onkyo Remote Codes
Models: RC-682M / TX-SR605 / TX-SA605 / TX-SA8560
Have you misplaced your Onkyo TX-SR605 Remote code list / Owners Manual?
Would you like a digital, searchable, pdf version of the Onkyo TX-SR605 Universal Remote Code List Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
_________________________________________
Download Onkyo TX-SR605 Users Manual Here.
on Apr 20, 2010 | Onkyo TX-SR605 Receiver
I have a 12" subwoofer and i was wanting to know how to hook it up with out a amp or if you can even do that
They need alot of power to get sound out of them. If you hooked it up straight to the radio without an amp, you would barely hear it.
Sep 08, 2009 | Car Audio & Video
Will skw204 power sub work with my txsr605 onkyo
yes here is the manual for it.
http://63.148.251.135/redirect_service.cfm?type=own_manuals&file=SKW204_En.pdf
now you will see this picture on page 5
768816d.jpg now where it says 6 this is your line input. Now you will plug in a subwoofer cable to this and on back of your receiver to the subwoofer output. and you now must enable the subwoofer option in the setup menu of receiver i think it would be under speaker configuration.
Mar 01, 2009 | Onkyo TX-SR605 Receiver
Compatibility
so the answer is yes it would.
Hooked up to sony bravia 52" tv and can barely hear sound
You'll want to turn of the TV speakers in the Remote Menu and try turning up the volume level of the TV, which usually controls the level of the RCA outputs, as well
Feb 02, 2018 | Yamaha RX-V596 Receiver
Subwoofer not powering enough (Sounds like under powered 8inch)
get a nice monster subwoofer cable and a Subwoofer PowerCenterâ„¢ SW 200 with Clean Powerâ„¢ Stage 1 get it from like amazon and you'll definately see a difference and also put the sub in like a corner
Jun 08, 2008 | JBL S120PII Subwoofer
Dont understand
this is retarded comment .... 20 what is 20 ? this is not how we compare receivers.... you ****...
May 09, 2008 | Onkyo TX-SR605 Receiver
Tuner Omits No Sound - Onkyo TX-SR605 7.1 Channels Receiver
Make sure your receiver is hooked up to proper AM and FM antennae. Try switching to AM, scan stations. If you hear AM static and/or weak signals the problem could be antennas are not hooked up. FM has AFT which blocks out weak or noisey stations and you wont hear anything without ant.
May 06, 2008 | Onkyo TX-SR605 Receiver
Very low ouput from subwoofer preout
The problem was that some subwoofers (inluding my velodyne model) cannot process the LFE signals through the line level inputs on its amps, so the other way to run your subwoofer is to run the front left and right speaker outputs from your receiver to the speaker-level inputs on your sub, and then plug your front and left speakers into the soeaker level outputs on the sub. you have to set the onkyo receiver to "Subwoofer: No". that way the LFE signals are sent through the front speaker channels and you will get the same BASS output as if using the line-level input. O So yes it does require a bit more speaker cable, but it works fine now.
Mar 18, 2008 | Onkyo TX-SR304 Receiver
Onkyo TX-SR605 Receiver Logo
160 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
