Question about Phoenix Gold Octane-R 5.0:1 Car Audio Amplifier
Please help I have a Phoenix Gold Octane-R 5.0:1 amp and two 1100w subwoofers, what it the best way to connect them so that i get the best sound
  • 109 Answers
That depends on what impedence the subs are. If they are 4 ohms each then just parallel them to the amp + to + and - to - on both of them that will give you a 2 ohm mono load which is fine for that amp.
Posted on Jun 19, 2008
I have wired everything correctly to my phoenix gold octane 2.5:2 amp and the remote terminal is not working. i have hooked up another amp to check to see if its the remote line and any other problems but...
Perhaps the PG Octane R needs a bit more power on the remote. Check if connectors are well connected to the wire. There might be some resistant present if the connection is not 100%. (oxidation?)
Jan 26, 2011 | Phoenix Gold Octane-R 2.5:2 Car Audio...
I just got 2 phoenix gold octane r 10" subs and i was wondering what kind of box and how big it needs to be
YOUR MAUAL SUGGEST PROER BOX SIZE FOR THE SUBS. IF YOU DONT HAVE ONE LOOK ONE UP ONLINE SORRY MAN CAPS STUCK.
Jun 30, 2010 | Phoenix Gold Octane-R 10/10d Car Subwoofer
I have a Phoenix Gold Octane Amp and 10d subwoofers. My friend took it out last week, and I want to put it back it, but I can't figure out where the power and ground wires go and where the speaker wire...
Ok, when you look at the amp, the power + and ground - will be on one side of the amp with another smaller opening in between them. That opening is for your remote wire from your radio. Without that, your amp will not receive the input voltage to signal it to turn on. The speakers will go into the remaining open holes. Your RCA wires will be on the opposite end of the amp.
Apr 29, 2010 | Phoenix Gold Octane-R 10/10d Car Subwoofer
Phoenix Gold Octane R 15:0.1
Go take a look at www.rodinaudio.com; go to contact info and call PG direct.
Aug 14, 2008 | Legacy 2CH 800W AMP Car Audio Amplifier
Phoenix Gold Octane-R 15.0:1
PG won't release schematic diagrams. Are the burned components resistors? If so, what are their circuit board designations (Rxyz)?
Aug 14, 2008 | Phoenix Gold Octane-R 15.0:1 Car Audio...
Amp problem, need help!!!
Sounds like one of two problems: either your subs are beginning or have gone bad, or you amp is going bad. What size power and ground wire are you using? You should be using at least a 4 gauge for both. Also what impedence are you running with the amp, ie; 4ohm mono, 2ohms stereo, etc?
Jun 19, 2008 | Phoenix Gold Octane-R 4.0:2 Car Audio...
Amp connection
Parallel would be the best way to wire them. 2 4 ohms subs to one channel wired parallel would be a 2 ohm load for that channel and if u wire them series then 2 4ohm subs to one channel would be an 8 ohm load for that channel.
May 31, 2008 | Phoenix Gold Octane-R 15.0:1 Car Audio...
Wiring my subs to my amp
bridge it and rear channel if you need to know how to bridge let me know
Feb 07, 2008 | Phoenix Gold Octane-R 15.0:1 Car Audio...
Wiring diagram
The LEd wires need a wire run from the speaker to the Fuse block in your car. The small Red wire from the LED will be the one that hooks to Swtiched 12 Volts supply on the fuse block so that your Led Turns on when you turn the keyswitch on. The Black wire goes to ground, or to a metal part of your cars body, probably the same point where your Amp is Grounded.
The Octane R10 is a Single Voice Coil or SVC.
AMP+ to Sub+
Amp- to Sub -
Use 12 guage wire.
Nov 07, 2007 | Phoenix Gold Octane-R 10/10d Car Subwoofer
Car Audio & Video Logo
113 people viewed this question
Top Phoenix Gold Car Audio & Video Experts
Mark Skinner
hoyzee1
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
