Question about Coleman Heating & Cooling
What is model #3815A700 called I know it is a lp gas lantern
3 Suggested Answers
  • 512 Answers
SOURCE: Converting Weber from LP to Natural Gas
On the weber model you need to purchase the natural gas model. It will cost you alot more to buy all parts needed to convert. Weber doesnt want you to convert do to safety reasons. This is why they will only tell you you can't convert. Buy the right grill and save yourself a headache.
Posted on Jan 20, 2010
SOURCE: Laars Lite 2 Coversion to LP Gas
The burner and pilot orfices will have to be changed. Also the gas valve has to be set up with a spring kit for lp gas. I purchased the orifices from Laar. and the Gas valve kit on E-bay for a honeywell valve.Laars wanted to sell a new gas valve but that's not necessary.
Posted on Jan 23, 2010
Changed maxitrol regulator to lp to much pressure
If you only changed the gas regulator for use with LP (the regulator located at the connection of the gas service) then you still need to change the orifices for all burners, top and oven. Of course I assume this model can be converted for use with LP. Some models cannot. A new range that can be converted for LP typically includes the needed LP orifices. A card with the LP orifices is typically located at the gas regulator.
May 31, 2014 | Kenmore 72132 / 72134 Gas Kitchen Range
Hi, I need to find a place to purchase a Harper-Wyman model 5853 LP gas valve. Thank you. Dave
Hello. Generally, the best local source for LP gas valves is your LP gas provider, give them a call. Also, there are several other sources including http://www.kitchenstuff.com/items.asp?Cc=HS1077, and local plumbing supply houses. J.
Jul 09, 2010 | Magic Chef 30 in. 8241RT Gas Cooktop
Jan 19, 2010 | Weber S-420 (NG)
How do i get to gas valve to install lp gas conversion kit on a ge dryer model drsr495gg7ww
call your lp provider as they often will send out a tech to do this conversion for free. after all you will be buying the gas from them.
Aug 17, 2009 | Dryers
How to light coleman lantern
Kerosene lanterns require a little more than just lighting the mantles. Go to Coleman's website and find the directions (for free) for KEROSENE lanterns. The generator on the lantern needs to be preheated with alcohol before it will actually light. Make sure lantern is a Kerosene lantern and not a white gas (Coleman fuel) type, there is a difference even though they look similar.
Aug 05, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
What do I need to do to switch over from natural to LP gas?
You will need the following Castle part #s
17003A- Pilot head assy LP gas @ $49.
17006L-Convertible Press Regulator LP gas @$29.
Give Castle Stove a call @ 800-637-9188 to make sure that is all that you will need. They were the only two parts I found on there website (www.castlestove.con) under your model # for LP gas conversion. There might be a need for a conversion kit for the gas valve.
captrick
Jul 20, 2009 | Comstock-Castle 2616HG Deep Fryer
Hi you will need a gas fitter to do this and set it up
Jun 02, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Natural gas to lp conversion kit for a Thermador GGNCV30 cooktop
Your LP gas provider will get the orifices for you just call them with the model number of your thermador. They have gotten them for me many times.
May 07, 2009 | Thermador SGS36GS Gas Cooktop
I need a service manual for Atwood 2001 series RV LP gas detect
Call one of the motor home supplier and you will be able to get it.
Mar 30, 2009 | RTO Atwood Water Heater - 6 Gal LP
Flames are extremely uneven and high
okay, DO NOT USE THIS STOVE ON LP GAS.
It's not intended to be used with LP gas, because LP gas requires a smaller orifice than natural gas. Call your propane supplier IMMEDIATELY...DO NOT USE THIS STOVE UNTIL IT IS CONVERTED TO LP GAS (if it's even possible)...this is extremely dangerous and you could hurt yourself if you continue to use LP gas on a stove that was designed to run on natural gas.
Dec 06, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Heating & Cooling Logo
188 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
