After i do the factory reset, auto search channel fail to active.
  • 597 Answers
Try to unplug the cable that leads to the antenna, turn off your television, unplug it and allow it to rest for about 30 minutes, then turn it on and plug back the antenna to it, then you try to auto search channels.
Ensure your cable is receiving signals from the antenna. Try to use the cable on another television.
Take care
Posted on Oct 11, 2010
I have a 32inch Olivia tv model 432S12 I can not get the tv to auto scan channels. How do I get to reset my channels or reset factory settings.
1st unplug your TV.After 5 minutes turn it on and see if it prompts you to set up the TV with a setup wizard of some sort. This will probably include an auto scan of channels. If that doesn't work explore all options in the menu to see if there is a reset of some sort. And if all else fails, read the users manual.
Jul 01, 2015 | Televison & Video
How do I get my local channels back after pushing reset and auto channel scan?
and what was the point of factory resetting .check input setting it has to be air or antenna
Apr 27, 2015 | Televison & Video
Auto channel has quit working due to an error
Factory Reset your TV. Then follow through setup again. If you cannot auto channel search, then your tv tuner is toast. Time to invest in something new
Jan 19, 2015 | Sceptre X37sv-Naga 37 in. LCD Television
Auto Channel Search does not find any channels
Do a hard reset to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
If a hard reset do not help you, its main system control memory IC is faulty, and should be replaced. Contact any service technician.
Nov 09, 2014 | Insignia NS-24LD120A13 24in 1080p LCD HDTV...
Why can I only tune in one channel
Tuner fault. Check and replace it. Do a reset to this TV first, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 07, 2017 | Televison & Video
Digital channels are not being saved during auto program.
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
Jul 11, 2017 | Sony BRAVIA KDL-40V3000 Television
Olevia 232 s12 Accidentally hit factory reset. now no channels in list. how do I get my channels back?
You'll need to reprogram the channels.
Typically this is found under the settings in some sort of auto program section of the menu.
On most newer televisions, the setting is found under a 'Channel' section.
Just select auto program and your source, whether it be an antenna or a cable source.
When the auto program is completed, you'll have your channels back.
Mar 05, 2011 | Olevia Televison & Video
No channels
i had the same damn problem for 3 long hours but i found a solution i have olevia 32 inch tv (720). all you gotta do is go to menu>setup>tv>auto channel search> cable> standrad search
Sep 21, 2007 | Olevia LT32HVE 32 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
