Question about Vacuums
Hello, I have an electrolux tweanclean EL7055A vacuum canister, and can't switch it on anymore. The cleaning system is working well (so the power is ok) but the command which is not directly in the canister seems not working. What I can do to test if the problem is here ?
  • fayreid May 31, 2008
    I have an electrolux 6000 series that will not stay on, if you hold switch located inside canister down it stays on but once closed it will not.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=636174
Generic problem for all Vacuums
Hello, I have an Electrolux (by 2 users)
Posted by genestep on May 31, 2008
Hello, I have an Electrolux Twin Clean EL7055A vacuum canister, and can't switch it on anymore. The cleaning system is working well (so the power is ok) but the command which is not directly in the canister seems not working. What I can do to test if the problem is here? XThis Problem has been added to the Share Your Expertise Page under "My Work Queue". OK
1 Other User Has the Same Problem Comment by fayreid, posted on May 31, 2008 I have an Electrolux 6000 series that will not stay on, if you hold switch located inside canister down it stays on but once closed it will not. Hello,
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The problem you are describing sounds to me like you have a electrical hose problem where the wires on the inside of the electrical are bad and not creating a solid signal for the power. Or you may have a bad switch and both can be repaired but the electrical hose would be the more expensive of the two (2). You can check with your local vac dealer or contact the Electrolux website or factory phone # for further assistance. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 02, 2008
How do you take apart electrolux canister vacuum EL7055 ?
Hi, it's Jeremy from Crucial Vacuum.
Below is a link to the user's manual for your Electrolux EL7055A Bag-less Canister Vacuum. It includes instructions that will aid in the disassembly of your vacuum.
http://www.manualowl.com/m/Electrolux/EL7055A/Manual/243303
You can purchase direct your replacement Electrolux parts needs from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/electrolux.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jul 17, 2014 | Electrolux EL7055A Bagless Canister Vacuum
Heppa filter keeps popping off when i turn on the vacum
Hi There, 99 times out of 100 this is due to the exhaust filter being too blocked for the air to actually get through. What happens is that the pressure in the motor increases and effectively blows the filter and filter cage clean off. If you have a look at the underside of the filter I would bet that it is very dirty and you will need to buy a new hepa filter
Oct 12, 2013 | Electrolux EL7055A Bagless Canister Vacuum
The telescopic wand on my electolux oxygen is stuck. Any ideas how to fix or trouble shoot this?
Believe it or not, dish soap and water can usually free that up. the other cure is silicone spray and heat.
Mar 13, 2010 | Electrolux EL7055A Bagless Canister Vacuum
The on/off buttons are not working anymore? Any
With your hose plugged into the vacuum, check your cord at the outlet, is it securely plugged in? There are no signs of cord damage? If so, you will need to take it to the shop,but it probably just has the wrong sequence in the power buttons.. turn on the main unit switch then turn on the hose switch to the canister, if no power, then hit the switch on the machine again, it should power up, if it does not, open up the bag compartment, and shut it again, making sure that the bag is aligned inside and the cover is closed tightly. Did this fixya? Let me know. You may need to contact electrolux for a replacement hose. they are really good about warranty service and will send yu a new hose at no charge if they determine that is the problem. Here is some contact info. Thanks, Rene(the Vacuum Doctor)
http://smallappliances.electroluxusa.com/node47.asp
Nov 13, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux EL 7001 Oxygen 3 power cord continually retracts
The button has two parts - the inner part (button) and the outer part (surrounds the button). The press the outer part to deactivate (pop out!) the inner part.
It took me a while to figure this thing out, but I was glad the vacuum wasn't broken.
May 02, 2009 | Electrolux EL7055A Bagless Canister Vacuum
Electrolux 7055
You can't repair the want cord. It must be replaced. If burned at top or bottom contacts you must also replace opposite mating connection
Apr 10, 2009 | Electrolux EL7055A Bagless Canister Vacuum
Electrolux Bagless Canister Vacuum w/Self-CleanHEPA Filter - weak suction
Unfortunately alot of people buy this model because of the electrolux name, but it is actually made by eureeka. Aerus-Electrolux is the manufacturer of the high quality machines of our parents day.
Nov 04, 2007 | Electrolux EL7055A Bagless Canister Vacuum
Vacuums Logo
412 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
