My sony vega tv switches av settings
My sony vega switches from av2 to av1 for no reason aftr about 10 minutes and it is very annoying. Can you help
  • 10,594 Answers
Will you specify Model number of Sony Wega TV to understand its circuitary.
Posted on May 31, 2008
I have a samsung LCD TV. it shows only AV..I can not use it as AV1 AND AV2
You can select its other 2 av inputs by pressing the AV button on its remote control.
Jan 23, 2013 | Samsung P50HP 50 in. LCD TV
The television keeps tripping from av1 channel to tv/dtv channel
Unplug av1 and see if it stays on dtv. If it does then plug the composite cables into av2. If it switches back to av2, you have a bad main board.
Nov 16, 2011 | Televison & Video
How do I switch to AV3 , AV2 And AV1 functionon the sony Bravia 40 inch HDTV
All you need to do is press the TV/VIDEO button in the top left corner of your remote. Each time you press, it will cycle through the connected external inputs, e.g. AV1, AV2, etc.
Hope this helps.
BElectric
Nov 23, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
When trying to switch from AV1 to AV2 with the
The Red, White & Yellow connectors are your composite inputs usually classed as AV3 or component. The AV1 input is a Scart connection, if you have a scart cable, connect this as your AV source & the TV will switch from AV to component.
Oct 24, 2009 | LG Televison & Video
Correct hookup from satilite receiver to dvd/vcr to tv
Av out from sat to AV1 on TV.
AV2 from tv to av in on dvd/vcr .
( if you can pick what av2 on the tv sends out set to send av1 out to record)
OR
AVout from sat. to AV1 on TV, AVvideo on sat to vcr/dvd.
The sat. system will act as a "play through" device so you can play vcr/dvd without changing the AV on the TV.
If you connect another lead in either option you may get a feedback loop causing audio "squeak" and video problems.
Post back to let me know if this helps.
Aug 12, 2009 | Televison & Video
I have an external DVD Recorder / Player attached at my TV via AV1 and an external DVB digital TV box linked to AV2. Both external units are linked togerther to enable direct recording from the external...
I have a LG tv set. When i press the tv/av button on the remote my tv shows av1, av2 earlier but now it is showing only av. So i am unable to watch my dvd player. Need help.
Jul 04, 2009 | LG 37LG30 37 in. LCD HDTV
How do I hook up my dvd player to my JVC model AV-56wp74?
just run your av leads into your AV inputs on tv,then switch tv to AV1 or AV2
May 01, 2009 | JVC Televison & Video
Sanyo 68cm. AV1 is Black and White. AV2 and normal Tv is OK
the two AV1 and AV2 have different inputs on the IC,
the first port has a disconnection,
take your tv for a check up
Mar 20, 2009 | Sanyo DS13204 TV
CANT FIGURE OUT HOW TO RECORD OFF AN 'AV' SETTING
The method is the same as for TV channels; select the input (i.e. view the desired channel), then press the record button. AV1 and AV2 usually are at the end of the channel list, and can be found by pressing the channel UP or DOWN buttons.
Aug 13, 2008 | Sony RDR-GX300 DVD Recorder
Cant See
do you have your tv set to the correct AV channel   (for a scart connection) look at the Scart port on the TV (it should be numbered usually AV1..AV2..etc..)
Then you just need to switch to the appropriate AV channel on your TV
hope this helps.....
also check in your TV manual if the av socket you are connected to is an input or an output.
Aug 23, 2007 | kawasaki 1152 System
Televison & Video Logo
120 people viewed this question
Top Televison & Video Experts
