Question about HP DeskJet 882c InkJet Printer
My printer for some reason is no longer functioning. I plug it in, and it shows that the deskjet is there, but that it is offline. I tried deleting it and then reinstalling it, but after I deleted it, it refused to even recognize that something was being installed. I would plug the usb drive in and my computer would make that noise like it was getting new software, but nothing would happen, and I can no longer even see that the deskjet is an option now. It works fine with my roommates computer though, using the same set up with a usb, she has no issues.
  • HP Master
  • 17,129 Answers
It seems that there are errors in your registry that has made your operating software failing in executing the detection as there are still roots of the printer drivers present in the system.
So I would advice that you restore your system to an earlier set date where the programs were in order. Once done repeat to see if the driver can be reinstalled. If not use a registry cleaner to check, or you will need to reinstall OS as your PC has some malware/virus.
Posted on Oct 11, 2010
What's your problem? my computer says the pritner is offline. how do i turn it onlnie?
There could be several reasons for the printer to show offline in Printers folder.
Click on the link below and follow the steps to troubleshoot the issue.
HP Print Diagnostic Utility
Regards,
Suhail
Oct 18, 2011 | HP Deskjet F2210 InkJet Printer
My Printer HP DESKJET 2360 is offline. I tried to unplug the cord then plug it again but it wont turn on.. Please I need your help..
if the printer is showing offline on your system but printer is on, then the data cord may be defective, the wire which is connected between your pc & printer. u need to replace it. while replacing make sure both pc & printer are turned off from mains. if the printer is not showing on indication(light) then there may be fault in power supply of your printer. get it replaced.
Aug 19, 2011 | HP Deskjet D2360 InkJet Printer
Use Printer Offline: Error Processing Command
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Jun 07, 2010 | HP DeskJet 6540 InkJet Printer
HP deskjet D2300 series printer is showing offline .Power is already given to the printer.
check that the printer is turn on, if on turn it off and on again, secondly check by double clicking the printer icon on your pc start bar i,t will open a pop/dialogue box, click on file and see if the offline is tick if so disable the tick.
May 26, 2009 | HP DeskJet F380 All-In-One Printer
Hpdesk3745 printer dose not function properly on my win.vistahome
Hi, Whenever you encounter such problem plug off your printer and restart your computer and then plug on it. It will work.
Apr 06, 2009 | HP DeskJet 3745 Printer
Printer won't print says it's offline
hi friend
this is very common problem for f300 series PSC
just delete the printer from printers and faxes and reboot the machine it will install printer again
there is funny thing abt this series it is saying offline when powered on and connected but when you disconnect iit will say "offline-use printer offline"
please try my solution and rate it
thanks
Apr 04, 2009 | HP Deskjet F340 All-In-One Printer
Nothing happens when i tried to print from my computer the status is offline what is wrong
same thing, woring one minute, next minute, offline. cords plugged in , no reason i have found but it happens all of the time
Sep 02, 2008 | HP DeskJet F380 All-In-One Printer
Hp deskjet f340 series keep showing offline
hi,
follow the steps:
>unplug the usb cable from the back of the printer
> go to the printers folder inside the control panel
> right click on the printer icon and then click on delete.
> if the printer icon is deleted and if there are no more printer icons related to your printer, plug the usb cable back to the printer and wait for few minutes while it automatically installs the driver.
NB: if you are unable to delete the printer icon. then right click and click on "pause printing" and then again right click and clear the documents in queue. if it is done then delete it.
if you are unable to clean the documents in queue, then
click on Start-->Run, type "services.msc" and click ok.
Double click on print spoolers and then click on "Stop" and then click on "Start". Restart the computer. then try to delete the printer icon.
Thanks and regards,
Agnel
Feb 29, 2008 | HP Deskjet F340 All-In-One Printer
Open Questions:
HP DeskJet 882c InkJet Printer Logo
55 people viewed this question
Seeker5211
Seeker5211
