Question about Kenmore 600 7962 Dryer
Runs but doesn't get hot - Kenmore 600 7962 Dryer
  • Kenmore Master
  • 17,130 Answers
You will need to check the heating coils, if electric model or the gas burner , self igniting which can be faulty or block in the pipes..
Please remove to have access to the set to check these parts out which can be the culprit.
Posted on Oct 11, 2010
Overheating
are all the tubes hot,if not then thermostat dont go open.
if all are hot see for thermocontact doesn work.
Feb 03, 2013 | 2002 Yamaha WR 426 F
1997 nissan pathfinder smells hot after running awhile
Check your valve cover gaskets, bet they are leaking and that is burning off.
Jun 27, 2017 | 1997 Nissan Pathfinder
I have a 1995 Pontiac Grand Prix SE 3.1 it runs hot , it doesn't over heats. I have replaced the thermastat flushed the Radiator and the fans are operational they comes on automatically. What else can...
remove thermostsat,drill 1/8 hole close to edge,to by-pass steam,common problem....jack-up the front of car toallow any air to purge from system,should be bleeder valve...bolt with a nut...loosen it remove air until antifreeze runs out,retighten bleeder nut,,put car back down....should fix ya
Jan 18, 2012 | 1995 Pontiac Grand Prix
My cooling fan does not work but when I unplug the switch located in the thermostat housing it runs as long as the key is on. What should I do?
You dont say under what circumstances it doesn't run. It is only suppose to run when needed i.e. when the water is hot. If it is not hot, the fan shouldn't run. When you plug it into a hot wire, it runs al the time while the circuit is hot. There is a procedure to check the switch. You will have to remove the switch and heat it in a pan of water while you observe the temp on a theomemeter. You will also have to have a VOM to see when the contacts close.
Oct 24, 2011 | 1991 Toyota Corolla
2000 mercury villager is running hot ,the other day it blew of the top hose from the radiator so I put it back on and filled it back up with fluid ,parked it on a hill and made sure no air was in it and it...
your thermostat is stuck in the closed position, replace it, anytime a hose blows off, this is usually the case, remember when replacing it that the spring part of it goes towards the motor
Jul 31, 2011 | 2000 Mercury Villager
My motor was just rebuilt and put back on by the pool company. It is hot, so hot you cannot leave your hand on it. Is this normal? should I be concerned.
Yes its perfectly normal on a hot day with the motor being air cooled. As long as the motor isnt overheating (loss of power) and has issues running your fine. Keep in mind that the motor runs by exploding gasoline and the energy that doesn't get transferred to the mower to drive it and turn the blade is expelled in heat. Same as your car engine (will get hot to the touch).
May 13, 2011 | Garden
The compressor is running and the fan is running but it is not cooling. The refrigerator runs and stops like normal. Last time we had it checked the repair guy said it was the fan not spinning fast enough...
On the refrigerator and after sometime hold the condenser to see if it is hot, if it doesn't become hot then there is no refrigerant in the system there must be a leakage somewhere or it could be the compressor which is losing compression or doesn't pump well.
May 11, 2011 | Hotpoint RLA50 Refrigerator
I have a FDL70S1 dehumidifier that runs and runs but doesn't take out any moisture from the air. I have cleaned out the filter and front screens thoroughly but it still doesn't work. The unit...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 10, 2011 | Frigidaire FDL50R1 Dehumidifier
Kenmore 600 7962 Dryer Logo
66 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
