Question about Bosch 12-Amp Formula Canister Vacuum with Hepa Filtration Bagged Vacuum
The brush doesn't turn when I tried to clean the carpet.
  • 5 Answers
I have the same problem on my 2-month old brush! It's an older model, so no reset buttons are available. Unfortunately for me, customer service was no help. I took a flat screw driver, opened the casing and started exploring. Wires were all connected and the is was turning the brush if the motor turns. I haven't fixed it just yet, but I think my problem is that the wires are cut just before entering into the long tube connecting to the vacuum (I have a canister vacuum). Even though the yellow coating of the wires were not cut through, you could tell they looked a little skimpy and sure enough, when held to the light you could tell the wires were not connected inside the yellow coating. I think this should be an easy fix enough that I can do it by myself. I recommend that you look inside your brush as well and see if it's anything obvious.
Posted on Jan 16, 2012
  • 377 Answers
Easiest fix would be to check to see if the belt is broken or not moving. If it is not broken yet not moving then most likely the brush that it turns is frozen. Follow the directions to change the belt. Once you get the brush out of the unit clean it as best you can. Spray some WD40 on the plastic tabs at the ends that hold it into the vacuum head. When reassembling, might as well add a new belt.
If you find this solution to be of help, I would appreciate a Thumbs Up rating from you. Paul
Posted on Oct 11, 2010
Buffalo12980
  • 625 Answers
SOURCE: Kirby Ultimate won't clean carpet
when you install the hose connector it trips a switch that switches the vac motor into high speed because the vac path is longer using the hose. check the belt after you remove the front. make sure the direction of rotation is in the direction of belt travel stamped in the impeller. try adjusting the head height
Posted on Aug 22, 2007
  • 190 Answers
SOURCE: the brushes do not rotate when cleaning carpet. Is
(1) Assure the Brush Control on the hood is NOT set to the OFF position.
(2) Remove the brush assembly by pulling/unlatching it from base on each side.
(3)Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism
Posted on Oct 23, 2009
  • 389 Answers
SOURCE: carpet cleaning brush noise
It's likely that one of the brush roll bearings has worn out. This is not uncommon. I think you'll find that you have to replace both the brush roll and the sole plate at the same time. Dyson sell them together as a kit.
Posted on Dec 09, 2009
ftw1952
  • 10319 Answers
SOURCE: hoover carpet cleaner brushes do not move
did you check to see if the belt came off or its stretched?
Posted on Jan 24, 2010
Samyfam
  • 378 Answers
SOURCE: the belt is not turning the brush bar when in the
DC7s have two drivebelts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar.
You can check the latter simply by removing the sole plate and looking. Unfortunately the other belt2_bing.gif is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws.
If, after removing the cover, the other belt is okay, then you have a faulty clutch. New clutches are available oneBay2_bing.gifreasonably cheaply, but again good tools and DIY skills are required.
Have a look atwww.dysonmedic.comwhich has some excellent info on dismantling and repairing a DC 07, but unless you haveaccessto such tools, and feel confident to tackle it, it's probably time tocallDyson or aVacuumrepairer.
Posted on Jun 16, 2010
Our DC41 is impossible to push on carpet. Is there an adjustment to do? Almost like there is too much suction.
See if the following information can help.
CARPETS OR HARD FLOORS
• The brush bar will always default to 'ON' (spinning) each time you switch the
appliance 'ON' and recline it for cleaning.
• The brush bar will not rotate when the appliance is upright.
• To switch the brush bar 'OFF' (e.g. for delicate rugs and hard floors):
- switch the appliance 'ON'
- recline the appliance
- press the brush bar 'ON/OFF' button - the brush bar will stop spinning.
• The brush bar will automatically stop if it becomes obstructed. See 'Brush bar -
clearing obstructions'.
• Before vacuuming your flooring, rugs and carpets, check the manufacturer's
recommended cleaning instructions.
• Some carpets may fuzz if a rotating brush bar is used when vacuuming. If this
happens, we recommend vacuuming in 'hard floor' mode and consulting with
the flooring manufacturer.
• The brush bar on the appliance may damage some carpet types. If you are
unsure, turn 'OFF' the brush bar.
Dec 31, 2014 | Dyson Bagless Upright Vacuum DC41 Animal
I have a hoover F5853-900 steam cleaner.Everytime i lift it up the brushes turn but when they are on the carpet they quit.I got told that this model does not have a belt.I really love this steam clean
The brushes are turned by a motor. No belt. It's possible the gears on the brushes have a flat spot on them which would stop them from turning under a load.
Dec 06, 2014 | Hoover Vacuums
My Bissell Pet Carpet Cleaner brushes will not turn around and heater doesn't work?
Hey you may want to check out our website for assistance in troubleshooting your machine. Here's a quick link to the FAQ page.
http://www.bissell.com/faqs/?cid=ccsocial
Jan 01, 2013 | Bissell 1770 Quicksteamer II Upright...
Brush won't spin when carpet cleaner is running
see this causes and fix it. God bless you
If the vacuum cleaner brush is not spinning, the brushroll bearing might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearing. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll assembly itself might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll itself might be jammed. Try removing the brushroll and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning the cogged belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the drive belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
Sep 27, 2012 | Vacuums
I have the Hoover, self propelled vacuum. I have only used the self propel function a few times, but our babysitter used the feature and now the vacuum only works on the highest carpet setting. The middle...
Move the carpet height control switch to a higher position if the vacuum is difficult to push. If the setting is too low for the carpet being cleaned, the brushes press against the floor preventing the vacuum from moving easily.Set to a medium-high height setting then check.Slide the "Self-Propel" button to the "ON" position if the cleaner does not self-propel. -----------
The self-propel feature operates only when the cleaner switch and the self propel button are both ON. ---------- Try this settings and check.This should help.Thanks.Helpmech.
Jun 24, 2011 | Hoover Self-Propelled WindTunnel Bagless...
EVERYTIME I PUSH THE BUTTON REALLY LOW TO ALLOW THOROUGH CLEANING IN THE CARPET, THE LIGHT DOESN'T TURN ON AND IT DOESN,T **** THE DIRT AT ALL.. IT ONLY WORKS IF YOU PRESS IT UP ONCE BUT IT DOESN'T GET ALL...
You need to replace the belt whenever the green brush indicator light goes out or is not steady. Be sure to observe the wear settings when re-installing the brush. The ends of the brush are marked with 1, 2, or 3 notches and numbers. In normal use the brush should have setting # 1 towards the rug. These settings adjust the brush for wear, and moving the bristles out prematurely will result in excess brush and belt wear.
Feb 24, 2011 | Kirby Ultimate G Bagged Upright Vacuum
On hoover steam carpet cleaner, the brushes do not rotate on low or high settings.
Follow these steps if the Brushes Fail to Spin
•If the brushes on your Hoover carpet cleaner fail to spin, there may be a problem---some sort of blockage---with the suction or with the belt that turns the brushes.
Turn the Hoover carpet cleaner over, and inspect the brush area. Debris, strings, or pet hair may be tangled in the rollers, keeping them from turning. Use a pair of scissors to cut away any obstructions in this area. Flip the Hoover carpet cleaner back over, and turn it on to see if cleaning the rollers has solved the problem.
To check the belt, turn the Hoover carpet cleaner over, and remove the bottom plate screw with a Phillips head screwdriver. Investigate the belt area to see if it is broken or has somehow slipped off. If it is broken, you can order a part from Hoover.com or from many of the other online parts stores.
When the belt arrives, simply slide it on in place of the broken belt, reattach the bottom plate and turn the Hoover carpet cleaner right-side up. Turn it on to test your solution.
Sep 03, 2010 | Hoover SteamVac F5914-900 SpinScrub...
My hoover carpet scrubber the brushes won
(1) Remove the brush block and assure the presence of the square drive pin on top of one brush. It should be about 1/4 inch square, two inches long to connect o the drive mechanism.
(2) Remove and clean the filter screen from the base, behind the brushes. Squeeze the two red tabs together, and pull down from the base. Clean the hiar/debris from the screen.
(3) Assure the Brush Speed knob on the hood is NOT set to the OFF position.
Aug 30, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
The brush wont turn
Make sure that the carpet selector is on carpet setting not bare floor. It only spins on carpet setting. If carpet setting is engaged and still doesn't work you need a new clutch assembly.
Oct 12, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Brush roll slows/stops turning
when you removed the beater brush did you clean all the lint and threads off the ends of the brush? you can unscrew one end of the beater brush plate to clean the crap off it. Inside the beater brush are two ball bearings. Use a light machine oil to lube these two bearings. re-assemble the rod and end nut. then put your brush back in the machine and note which direction the belt needs to be installed. there'll be an arrow on the motor housing.
Sep 05, 2007 | Kirby G4 Bagged Upright Vacuum
Bosch 12-Amp Formula Canister Vacuum with Hepa Filtration Bagged Vacuum Logo
217 people viewed this question
Top Bosch Vacuums Experts
Cleverer2
 John
John
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
