Question about Kirby G4 Bagged Upright Vacuum
I need a diagram on how to assemble gearbox / drive neutral pin pulled out
  • 377 Answers
If you go to this URL http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039 almost at the bottom of the page you will see articles having to do with repair of your unit. I think, since you are getting into the unit that deep, you should be able to find some help in these articles. Paul
Posted on Oct 11, 2010
How do you replace the drive/neutral lever (foot pedal) if it falls off? (The yellow and gray lever that you step on to put it into drive or neutral.) Not sure what happened but it just fell off. Now I...
The pedal assembly must be replaced,( part # 558401S), as it has a gear pressed to it which has come loose. The handle, switch plate, and upper motor cover must be removed first. To remove the plastic switch plate, remove it's screws and insert a flat screwdriver into the rectangular slot in it to pop it of. Four screws hold the motor cover in place. Next the switch button must be removed. The Techdrive assembly can be removed by removing the three screws on the bottom. Drop the drive down, and unhook it's belt from the gear on the end of the armature shaft. The pedal assembly can be removed by removing the remaining screw from the bottom of the drive unit. The N/D pedal has two parts - the pedal itself, and the shift cam. Observe carefully how these units fit together. After installing the new pedal and replacing the screw and washer to secure it, re-install the drive unit. The shift must be in the Drive position to install it, and replace the belt. Be sure to line up the arm on the drive unit so that it engages the slot at the base of the handle pivot and re-install the other items
Feb 28, 2011 | Kirby G5 Bagged Upright Vacuum
I have a Kirby G5 and need to replace the gear drive shaft, as the lever inside fell off and the shaft came out. (Common problem by the sound of it.) How do i remove the actual gearbox itself. I have...
I have never touched a Kirby vacuum before and my wife had the same issue. The neutral/drive pedal just fell out so I figured I would give it a shot to see if I could fix it and quickly figured out the 3 screws in the bottom plate for the drive unit wasn't the answer.
I was able to figure things out out after I found a parts list with diagrams at the follow web site and address:
Vac Parts Warehouse.com
http://www.vacpartswarehouse.com/category-s/2821.htm
The two parts involved are:
13. Bracket Cam Assembly Neutral Drive Pedal 557689A
16. Kirby Pedal Cam For Neutral Drive G6 558499A
Here's how to get to a point that you can get these two parts in/out of the machine.
- Remove bag and fill tube from handle and main unit
- Remove floor nozzle assembly
- Remove the handle via the two screws at the handle fork plate (these have loctite on them so needed a socket wrench with torex bits to get them out).
- Remove the plastic rear scuff plate vie the screw with the power cord anchor and screw by the Pedal Cam For Neutral Drive. Note release plastic tab in slot in the center and lift from the back and then over the base where the handle attaches.
I did not do this as I removed the the power drive assembly so I could figure out how to put the dive assembly back together. The pressed on arm that drives the cam assembly had pulled of the pedal shaft so this also made it easier to fish out the parts and experiment on positioning the arm in the right spot . I found the arm and a spring washer inside.
I assume at this point you could loosen the screw (don't remove it, it's the only one with a star lock washer on it) on the bottom plate that attaches the Bracket Cam Assembly and slide the Pedal Cam out and a new one in if you can get the part and replace it. The part was 16. Kirby Pedal Cam For Neutral Drive G6 558499A at Vac Parts Warehouse.com. The one listed on the website said it was for a G6 even though the parts listing is for a G5 so I don't know....
To continue to disassemble and take the power drive assembly out:
- Remove the 4 screws from the Cover Shell assembly - the metal top part. You do not need to remove the hinged Headlight Cap that is attached to it.
- Remove the 4 screw from the bracket assembly that has the handle attachment and forward/reverse switch. It attached by two wires. I only disconnect one and swung it to the side.
- Snap off the the on/off switch and disconnect from the Actuating Rod Foot Pedal to Power Switch.
- Remove the 3 screw from the bottom plate of the power drive assembly.
- Remove the drive belt.
- The power drive assembly will now drop out the bottom.
I just put the spring washer and arm back on the shaft and reassembled. I'll see how long that lasts before before buying the new part.
Have fun.
Aug 08, 2010 | Kirby G5 Bagged Upright Vacuum
Brushes stopped working
(1) Assure the Brush Control on the hood is NOT set to the OFF position.
(2) Remove the brush assembly by pulling/unlatching it from base on each side.
(3) Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism.
(4) Remove and clean the intake filter. One the base of the cleaner, behind the brushes, squeeze the two red abs together and pull the panel down to access the screen. Clean the hair/debris off the screen and reassemble.
Mar 10, 2010 | Hoover F6207-900 Steam Cleaner
My model F5906-900 --- problem is the brushes have stoped working... I pulled the brush assembly out by holding the two tabs, and all seems clean and the brush assembly rotates easly... onced the brush...
Mar 10, 2010 | Hoover F5906-900 Upright Steam Vacuum
THE NEUTRAL/DRIVE LEVER HAS COME AWAY FROM THE HOOVER AND SOME OF THE INSIDES HAVE ALSO COME AWAY. I WOULD LIKE TO KNOW HOW TO PUT IT ALL BACK TOGETHER
I dismantled the cover, withdrew the gear drive assembly and found the bits that had come loose. The mechanism that selects neutral or drive had come away from its shaft. I simply put it all back together and tightened everything back up. Works a dream again.
Jan 10, 2010 | Kirby Heritage II Vacuum
BRUSHES NOT TURNING
Dec 31, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
I was steam cleaning the stair landing and the steam cleaner slipped off the landing a few inches and the brushes haven't worked since
Please remove the brush assembly by pulling down from the bottom of the cleaner. There is a drive pin to the brushes, approximately 1/4 inch square and two inches long that connects the brush to the drive mechanism. You may have broken the pin off, and need to replace the brushes.
Oct 12, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Kirby G6 clicks while in neutral
Bracket cam assembly (see and buy HERE). It is worn so it does not disengage gears completely. On the part listing you will also find the instructions on how to replace it.
Rocky
Jul 29, 2009 | Kirby G6 Bagged Upright Vacuum
Drive lever
that bracket is worn.....[ part number 557689 A ]...but is tricky to reassemble....
May 20, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
134 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
