Question about Husqvarna Chain Saw 20" Bar
Hi, I was wondering how much oil and gas a typical
Hi, I was wondering how much oil and gas a typical Husqvarna chainsaw fits in its tank. And how many tanks do you generallu need to fell down a Pine or Western Hemlock of average size.
  • Husqvarna Master
  • 2,239 Answers
Under normal working condition the saw is designed to run for approx 25/30 minutes
Posted on Jan 05, 2011
Husqvarna rancher, leaks oil when saw is off. where rubber hose meets pump, seems to fit together well but still leaks out. drains full tank of oil. any fixes or better parts.
The hose is leaking. You will have to replace the hose. You do not have to disassemble the saw in half as many seem to think. Just some of the parts that are in the way. You can insert a wire and pull the hose out from the oil tank along with the filter. It goes in and you remove only the parts that are in the way where the hose comes out.
Nov 07, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Oil pump not working
The oil pump is adjustable ( 3 position ) the adjuster screw is under the crankcase below the sprocket, there is also a filter on the end of the pick up hose, you can gently pry this out of the oil tank, there it is a grommet fit into the tank, there is also a nylon drive gear driven by the back of the drive sprocket, this may be damage and not turning the pump shaft.
Oct 25, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a husqvarna 137 chainsaw. The problem is with the bar oil. When the saw runs oil is flowing but where the rubber corner piece which allows the oil to flow out of appears to be just dripping the...
Hi marcus,
The bar and chain oil goes into the oil tank on the side. The oil for the engine is mixed with the gas before filling the gas tank.
Hope that helps.
Handy Andie
Mar 20, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 55 rancher-just put new piston ring and cylinder.saw start right up and idles.when i try to acellerate it bogs and try to stall.when I let off gas it idles fine again.I tried turning mixture...
The plastic carb mount has a hole and a slot, this is the pulse channel from the cylinder to work the pump diaphram in the carb, if you look behind the plastic plate there is a tube that fits into the cylinder under the black induction rubber, this feeds a positive and negative pressure to the carb as the piston rises and falls, make sure you have re fitted the small seal in the cylinder that seals this tube or you will have big running problems.
Let me know if you need more help.
Mar 02, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 141 oil leak
This model was notorious for leaking oil, there were a number of issues, one of which was the fit of the seals around the oil pump assembly, the inner and outer sealing was replaced by a single piece seal to make it better part no. 545037101, there were also issues with the oil tank itself, the outer half was friction welded on to the inner, some of the seams were not very good and oil would leak from there, in very extreme cases the muffler would leak exhaust gas onto the top of the tank and melt a hole in the tank.
Feb 26, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
What is the best oil/gas mix for a Husqvarna rancher chainsaw?
50:1 using fresh gas and a modern synthetic saw oil premixed in it's own container. Be sure to shake the container thoroughly just before filling the tank each time to prevent oil starvation. Don't make up more than a gallon at a time unless your business is sawing. Hope this helps!
Oct 23, 2010 | Husqvarna Garden
Husqvarna chainsaw 440e - enough chain lube?
That seems low to me. Page 15 in your manual is the only oil discussion I found. Usually there is an oil pump adjustment reference somewhere. I didn't see one beyond return it for service on page 15. Are the chain and bar hot after cutting a while? I recommend you not get a longer bar without an oiler adjustment. I think the hand of the EPA has been here.
An IPL (exploded parts list) for a 440 can be found here:
http://weborder.husqvarna.com/order_static/doc/USA/2009/I09000/I0901018.pdf
There is no oiler adjuster listed. HTH
Lou
Might be a good idea to copy the IPL,
Oct 07, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Bar oiler not working
The chain oil pump must be worn. The pump is fitted behiend the clutch and chain drive.Remove this by turning clockwise.
May 16, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna Chain Saw 20" Bar Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
