Question about Phoenix Gold Octane-R 15.0:1 Car Audio Amplifier
Amp connection I have a PG Octane R 5.0:1 amp and two 1100w subwoofers what is the best way to connect them so that i get the best sound?
  • Cade Austin May 11, 2010
    Depends on the number of voice coils on each speaker, and what the impedance of each voice coil is.
    Hooking two 4-ohm single voice coil speakers together is different than hooking two 4-ohm dual voice coil speakers together.
    Let me know what you speaker configuration is, and I will tell you how to wire them up
    Problem Solver:
  • 9 Answers
Parallel would be the best way to wire them. 2 4 ohms subs to one channel wired parallel would be a 2 ohm load for that channel and if u wire them series then 2 4ohm subs to one channel would be an 8 ohm load for that channel.
Posted on Jun 02, 2009
Do you plug the sub woofer outputs to another amp?
Yes, for best results. Your subwoofer should have a seperate amplifier because it has low pass filter that produces low frequency signals. It is done by connecting the sub woofer output to the input signal of the amplifier and then connecting the output signal to the subwoofer speaker terminals. Hope this helps.
Jul 01, 2011 | Car Audio & Video
Hi! I have a Jensen XA2150 Amplifier, from the speaker output I have connected a Subwoofer Sony 10 inch 1100W. Tha'ts gave me a nice bass sound, but now it's death! The amplifier have a 25A fuse,...
Have you checked the fuses inside the amp?Unscrew the cover and with the amp sitting on its back,remove the cover.You have 2-4 fuses,old round type,in there.
May 21, 2011 | Jensen XA2150 Car Audio Amplifier
I have wired everything correctly to my phoenix gold octane 2.5:2 amp and the remote terminal is not working. i have hooked up another amp to check to see if its the remote line and any other problems but...
Perhaps the PG Octane R needs a bit more power on the remote. Check if connectors are well connected to the wire. There might be some resistant present if the connection is not 100%. (oxidation?)
Jan 26, 2011 | Phoenix Gold Octane-R 2.5:2 Car Audio...
Connecting subwoofers
Good day. I take it that you have two subwoofers to connect and will explain the connections thereof. Place the two subwoofers face down and notice the connection point marked -, + on the one speaker, and the same-,+ on the second speaker. Now connect the center + and - together, leaving the two outer connection points open. The outer connection points will go to your amp. Next, take note on your amp, a "bridge" connection. It should be the outer connections on your amp. Hope this helps
Apr 10, 2010 | Power Acoustik LFA1-2000D Car Amp
The best way to hook kicker cvrs to a percesion power 2400.2 amp
It depends. Look up amp to subwoofer wiring digrams. Really just google/youtube "how to connect an amp to subwoofers"
Mar 02, 2010 | Car Audio & Video
Using JBL 4410 3-Way crossover, trying to use PG 12" Dual 4-ohm
ok, connect the amp positive to the positive end of one sub coil, take the negative of that coil, and run it to the positive of the second sub coil, then run the negative out of the second sub coil to the negative of the amp.
Mar 29, 2009 | Phoenix Gold Octane-R 15.0:1 Car Audio...
Phoenix Gold Octane R 15:0.1
Go take a look at www.rodinaudio.com; go to contact info and call PG direct.
Aug 14, 2008 | Legacy 2CH 800W AMP Car Audio Amplifier
Please help
That depends on what impedence the subs are. If they are 4 ohms each then just parallel them to the amp + to + and - to - on both of them that will give you a 2 ohm mono load which is fine for that amp.
May 31, 2008 | Phoenix Gold Octane-R 5.0:1 Car Audio...
Alpine mrp-m450 Amp won't stay on
im having the same problem with my amp, I took it to best buy and they said the amp was recieving power and recieving signals from the deck and i had everything hooked up right but that in the circuit board all the connections were blown, meaning i have a blown amp, i hope this isnt your problem but it definetly sounds like it. GOODLUCK
Nov 12, 2006 | Alpine MRP-M450 Car Audio Amplifier
Amp is on, Subwoofer works, but no sound.
here is a short test you can try, remove the rca audio cable from the amp & connect a diskman or toher audio o/p device that you can hook up with the same rca wires, turn on the amp & see if you have sound. you can also remove the speaker wires from the sub & using multi meter read the ohm's of the sub, most subs are 4 ohm. Hope this help locate your problem
Oct 24, 2006 | Pioneer GM-7200M Car Audio Amplifier
Phoenix Gold Octane-R 15.0:1 Car Audio Amplifier Logo
286 people viewed this question
Top Phoenix Gold Car Audio & Video Experts
Larry Spears
Larry Spears
Matthew Spark
Matthew Spark
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
