Question about Jandy AQUALINK RS TELELINK KIT
Spa not heating up. Aqua link says Heater offline. How do we fix that?
    Top Expert:
  • Jandy Master
  • 5,080 Answers
Turn off aqualink turn off heater then turn on aqualink then turn on heater it should recognize it also make sure red 4 pin connector is plugged in
Posted on Mar 05, 2016
SOURCE: SPA Filter on while Spa is Heating
you have one jandy valve ( the suction valve in front of the pump) that is not working right when you press spa mode. have someone watch the valves to see if they move when you press spa mode and heat inside the house. if the one in front of the pump does not move and the switch is in operating mode then that valve is bad and will have to be replaced.
Posted on Aug 06, 2009
  • 990 Answers
SOURCE: I have an aqualink rs
If the Aqualink is calling for heat then the problem is most likley in the heater. Without more information I can't tell you much more but if nothing has changed in the last couple of days. Before you call anyone be sure to clean your filter and baskets. The heater need a set amount of pressure to run and if things are dirty it won't get that pressure. Good luck.
Posted on Mar 13, 2010
Testimonial: "The burner is lighting but won't stay on, more than a minute or so. I tend to think the problem is water flow, like you say. Thanks...DC"
Daniel S
  • 4323 Answers
SOURCE: The spa heater says the
Hi
1. Turn off the power to both the pool/spa control system and the heater unit.
2. Remove the front panel door from the front of the heater to access the raceway.
3. Run the wires from the pool/spa control system through the opening, Thermostat is located on the lower right or left hand side of the heater.
Please check this link for more details---
Jandy LXI 300 POOL HEATER Manual
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 21, 2010
  • 44 Answers
SOURCE: Have a Aqua link control. The pump is suppose to
You may have a bad "spa side remote"When the 4 button remotes get water inside, they can send Fantom signals to the system. To test it you can unplug the remote and see if the problem goes away. Open up the outside control panel and unplug the black plug on the top of the board (which is just right of the red 4 pin connector). If that doesn't fix the problem, you may have a problem with the" Freeze protection" circuit,which turns on equipment when the temp sensor shows near freezing temps.
Posted on Oct 13, 2010
  • 5 Answers
SOURCE: I have a Aqua link
its most lke a problem called ghosting which mean your spa side remote will turn system to spa mode or turn other thing on such as the blower or heater will come on without manualy turning it on to fix this problem open up outside control panel and unplug the four connection wire hooked on a red bar plug tape the ends after unplugging so nothing will get shorted also turn of breaker as well so guarnting no shortage
Posted on Feb 01, 2011
How do I wire two seperate Heaters to a jandy Aqua link rs 2/6?
need more info on why you have 2 heaters if for the same body of water hook them up parallel and the firemans switches go from each heater to 1 and 2 pins on the big plug if set for pool and spa then pool to 1 and 2 and spa heater to solar to turn on
May 17, 2016 | Jandy Pool & Spa
Heats to only 72 degrees
make sure heater is set to 104 degrees aqua link controls temp
Jan 03, 2014 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Need to know wire gage
Copy following link:
http://waterheatertimer.org/Color-codewire.html
Add comment and say if each is wired separately, and how many volts.
Apr 13, 2013 | Aqua Flo Spa Or Hottub 1.5 Hp Jet Dual...
I have a Aqua link RS4, now 13 years old. The pool will switch to the spa mode by itself, no human intervention. Any thoughts.
Jan 28, 2011 | Jandy AQUALINK RS TELELINK KIT
Heater doesn't heat all the way the spa
if aqua link turn heater all the way up then see if works ok
Dec 29, 2010 | Jandy Laars Lt 250,000 Btu Heater
SPA WILL NOT HEAT PAST 94 DEGREES. i HAVE IT SET TO 103 AND IT HAS NOT MOVED PAST 94 DEGREES FOR OVER 1 HOUR EXACTLY WHAT BUTTONS SHOULD BE LIT ? IN OTHER WORDS IS THE AIR BLOWER LIGHT SUPPOSED TO BE...
if hook up to the firemans switch turn heater all the way to 104 degrees if using 4 pin connector for aqua link to heater set spa temp to 104 and make sure on aqualink spa heat is enabled and 104 degrees
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
Copper coils of aqua pro corroded and leaking on heater
Replace coil. This damage is a result of a continually low ph and alkalinity condition or an extremely high level of chlorine. Test water frequently
Aug 07, 2009 | RTO Aqua Pro Systems Pro 600 60,000 BTU...
Series 2 esc 325p won't get above 85 degrees on full throttle
if using a aqualink and hooked into pins 1 and 2 on long plug turn heater all the way up and let the aqua link control heat
Feb 17, 2009 | Teledyne Laars Pool & Spa
Jandy AQUALINK RS TELELINK KIT  Logo
123 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
