Question about Hitachi 43FDX01B TV
Hitachi 43FDX01B Hello, i finally had a chance to check my email and found your response. I really do appreciate your help with this one, it has been a pain. You suggested disconnecting the CRT anode. do I run the set and do checks with the anodes disconnected?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Noooooooooooooooooooooooooo way call repair tech
Posted on Aug 03, 2008
Why is so hard to get the user manual for my hitachi 43fdx01b if you are the expert solve this for me thank you my valid email address is drasanji@gmail.com
Hello
I've send the user manual you asked for. Go to your mail and download it. It is an Adobe Acrobat Document.Ok.
Jul 26, 2011 | Hitachi 43FDX01B TV
My Hitachi 43fdx01b has no picture it started to get dimmer and dimmer every day for about a week and then no picture just sound, Any help would be appreciated
Ur tv projection bulb that in ur tv right now?The bulb in the tv right now been in used for 1 1/2 or 2 years in use?The tv been watching like every day like 4 or 5 hours a day?The bulb life span is over,must change the bulb.
May 29, 2010 | Hitachi 43FDX01B TV
I have a hitachi 43FDX10B ultrascand HD rear
well it seems to me that you need to call the manufacturer to see how to reset the pixels for that tv. it seems someone has taking a magnet or something like that to the tv screen
Nov 29, 2009 | Hitachi 43FDX01B TV
Red and green waves...double vision ...how old...how valueble...hitachi 43FDX01B
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 05, 2009 | Hitachi 43FDX01B TV
Convergence on Hitachi 43fdx01B not working
ik04,ik05:stk392-110(replaced with:stk392-150)resistors:rk46,54:1,5ohm.,rk42,50:2,2ohm.,rk58:3,3ohm.,rk62:1,8ohm..try make order in "MCMelectronics".,partstore.,bdent.
Jul 09, 2009 | Hitachi 43FDX01B TV
Hitachi 43FDX01B green is out of whack
The green is not adjustable in the customer menu because it is considered the 'master' color. It is adjustable in the technician mode however but if it is curved it won't even adjust properly that way either. The problem is the convergence ampifier responsible for green convergence has failed. The convergence output IC's need to be replaced.
May 27, 2009 | Hitachi 43FDX01B TV
Is the Hitachi 43FDX01B TV 1080i or1080p ?
The Hitachi 43FDX01B TV is 1080i per the specs on page 63 of the Operating Guide.
Dec 07, 2008 | Hitachi 43FDX01B TV
Hitachi 43FDX01B (convergence) problem
Convergence IC's must be changed to start repair..original...
STK392-110 sub to Hitachi upgrade STK394-160E.....PART #
CZ 01341...you need two....
Next, take a critical look at the B+ feed resistors near the IC's..
check for over-heat / damage......usually 2.2 ohm 2 watt......
Let me know....................T.
Jan 03, 2008 | Hitachi 43FDX01B TV
Purplish-reddish flicker on Hitachi
It seems you might have cold solder connections on the picture tube socket or on the picture tube drive board. If your not a tech please call someone to assist you with repair as you can be seriously hurt by the HI voltage insiode this set an or cauae more problems with the set. Good Luck
Aug 03, 2006 | Hitachi 43FDX01B TV
43fdx01 hitachi
possible convergence overdrive from the IC's. This will cause the symptom you describe. ....accordianman
Jul 17, 2006 | Hitachi 43FDX01B TV
Hitachi 43FDX01B TV Logo
43 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
