Question about Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive
HDD is not getting detected on vista PC - Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive
  • 3,083 Answers
First thing to try, is to plug it into a different usb port, and see if it will be detected that way. To make sure the hard drive is good, try to plug it into another known good computer. The cord could also be bad, or a solder joint could be cracked on the hard drive. The usb drivers could be failing, in which case you can go into Control Panel, Hardware, and USB ports, and right click, delete them, and restart windows to have them reloaded. Other than that, the usb hub could be faulty in the computer.
Make sure your bios is set properly if it has to be adjusted in some respect.
Here's some things to check out in this web blog about the same type problem:
http://answers.yahoo.com/question/index?qid=20071019234649AAd5EMB
Good luck, and hope this helps.
Posted on Oct 11, 2010
Trying to install vista 32 bit on my Gateway DX 4720-03.Vista won't install because it can't see Hard drive. How do i disable ahci or sata mode in the bios or is there a work around to install Vista32.
Vista will have the drivers necessary to identify SATA/AHCI controllers, built-in by default. It would not be necessary to turn the AHCI mode 'off' or to 'ATA' mode (unless you get a 7B or inaccessible boot device BSOD). Check if your system has a RAID configuration, in which case there may be a 3rd party supplied RAID driver that you need to install first. Also, check if the HDD cables are connected properly & the HDD is detected in the BIOS (System setup screen) first.
Mar 16, 2010 | Gateway DX4720-03 PC Desktop
Im instaling windows xp in Acer Aspire but it
latest laptops do not have compatability
with xp. if you want to install xp you will have to use third party software for accessing hdd & installing XP
Nov 09, 2009 | Microsoft Windows XP Professional for PC
Laptop shows only 4gb ram & 300 gb hdd
This is the limitation of a 32 bit (x86) Operating System. A 32 bit OS can detect upto 3GB RAM only.
You may either try installing the x64 Bit of XP Operating System or Vista Service Pack 1 or 2 for 32 bit Vista Operation System to resolve the issue.
After installing the SP 1 or 2 of the Vista OS in the Computer, the OS will detect 4GB RAM.
Good Luck!!!!!!!!!!!!!!
Oct 12, 2009 | Acer Computers & Internet
My new portable hdd is not getting detected on my xp
Your USB ports may be version 1.1
You need a USB "Y" cable.
The USB Y cable uses two USB ports on your laptop and the third plugs into the external HDD.
Check RadioShack or maybe the vendor has a USB Y cable.
This will work!
Sep 08, 2009 | Computers & Internet
HDD not recognized whe installing fresh Windows XP!
Hi...
If your HDD will not recognized during installation you need to check if your HDD is detected. Try to look at your BIOS if it is detected. IF the HDD will not detected you need to replace the cable, try to use the other slot of your SATA or IDE ports.
Regards
ICmanServer
Jul 31, 2009 | Dell Vostro 1400 Intel Core 2 Duo T5270...
I've got BIOHD-3 NO BOOTABLE DRIVE (HP Diagnostic test)
if it cant detect ur HDD ... then check for jumper settings. ...
Jul 04, 2009 | Computers & Internet
Hello, I have Sata HDD it was working fine before few hours and now its saying No Bootable Device Detected -- Insert boot disk and press any key.I had Vista Installing.I tried installing RAID Drivers...
Have you gone into your computers BIOS settings to make sure that your HDD is configured and that it is recognized? My room mate has a computer that just "looses" it's HDD in the BIOS and forgets that it existed. To get into your BIOS, more than likely you'll hold down the "delete" key or the f12 or f10 keys when you power up the computer and it'll ask you if you want the additional settings options, or it'll just pop into your BIOS. You'll look through it (Be careful!) and on the 2nd screen most likely you'll see options to set a boot order. You'll want to make sure that your HDD is listed in here or else the computer is not looking for it to boot from. You'll probably want to have your floppy first, and CD 2nd, and leave your HDD for 3rd for booting options. Depending which version of Vista you're installing, it may not support RAID. Microsoft only saves that for it higher end/priced OS's that the corp's are willing to pay for so they feel like they're getting their money's worth.
Jun 09, 2009 | Acer Aspire 5315 Notebook
It is not detecting the OS/partition on my HD
Take a look here: http://blog.atola.com/restoring-factory-hard-drive-capacity/
If that does not help please write your hdd model (Usually on a sticker on top of HDD)
What size is the partition the installation detects?
Jun 01, 2009 | Microsoft Windows Vista Ultimate Upgrade...
Hard drive detection
You should not need a driver for it. Assuming you are using XP or Vista, the disk should be supported directly by the OS.
Have a look at external HDD troubleshooting.
Jules
Apr 22, 2009 | Toshiba 120GB USB 2.0 Portable External...
Unable to login in my computer
try setting your bios to defaults when you get in that bios screen.make sure to save it and then exit.you may also need to reinstall windows os .vista or xp etc.
Mar 04, 2009 | HP Hewlett Packard Smart Buy- dc5750...
Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive Logo
56 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Josh Whitehead
Josh Whitehead
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
