posted by CodexSearch on May 31, 2008
Just replaced battery in Timex Expedition Indiglo Digital Watch, but now I notice the beeper doesn't work at all. My guess (which may be wrong) is that I need to reset the watch. Label inside watch says "after battery insertion, short AC pad and battery (+) to reset. Can't find the AC pad. Help!!
Comment by CodexSearch, posted on Jun 01, 2008
Gee, with "expert advice" like "search Google..." who needs you guys! I found your site by searching Google for an answer to this question.
Best Solution
posted on Jun 07, 2008
How to reset the "Short Reset Pad/VDD(+)" on a Timex Ironman . First, orient your watch face down (with the watch belt buckle opposite you), the new battery in and latched. Second, on the right side battery hold-down latch you will see a small metal circle (~1 mm diameter) with a black dot in the center. Take a small paper clip and touch this metal pad to the metal battery hold-down latch for about 1 second. This will reset the watch.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 06, 2008
I have a Timex Digital Heart Rate Monitor 585 (product code T5C351F5)m, which has the same Short AC Pad and battery +ve message. There is an arrowhead pointing to the pad. It's a raised metal platform - a bit different to some of the Ironman's mentioned above. Here is a pic...
Solution #4
posted on Jul 21, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
turn it over, take the back off, you'll see a small metal 'peg' sticking out to the right of the battery, take a paper clip and touch the peg and battery at the same time.
then, put the sticker back on the batter, or a small piece of scotch tape
Suggest a new solution for this problem
Post a New problem for Timex Advanced Data Link 53722 Wrist
Email this problem
Email this problem
Can you Help with these Watches problems?
Timex Advanced Data Link 53722 Wrist Watch
Timex Expedition sports watch -...
Hi I have some lap times in the... Answer This...
installed new battery and now...
I just installed a new battery... Answer This...
Repair Service
Find Watch Repairman Near You:
