Question about Transcend STOREJET 2.5 HI- SPEED USB 2.0.0.0 HDD CASE SILVER
Hi my trancand external hdd is not detected bt my laptop --- dell inspiron 1545 --- windows vista
  • 4,281 Answers
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Let me know if you need further assistance. Thanks for using FixYa
Posted on Oct 11, 2010
How do i switch a dell inspiron with a broken screen to a vga monitor?
Look at the "F" keys. One of them has a drawing of a screen. Press it and your external screen should work, or, plug the external screen in before youboot up. The pc will detect the external scree and switch automatically.
Nov 19, 2013 | Dell Inspiron 1545 Notebook
No display after starting, can hear the motor and see cursor but screen is blank
I think you HDD not detected. So open bios and see you HDD show or not, if not show then all power off and disconnect hdd cable and change data cable and power cable. Again reconnect and start i hope HDD detected and solve you problem.
Second option is you windows corrupt then this types of message show. lets you check both option solved you problem.
Sep 03, 2013 | Dell Inspiron 1545 Notebook
When turning on my laptop (DELL Inspiron 1545) the set up starts until I get the message 'BOOMTRG is missing, Press CTRL+ALT+DEL to restart'. Along with this, there is a yellow flashing light
This is an error message your operating system boot manager file is corrupted or missing. A clean re-install may solve the issue. Sometimes you need to format the entire HDD to install the OS. Remove the HDD from the drive bay and connect it to another pc using an external 2.5" case via usb cable and select that HDD from computer and rightclick then format. Select ntfs if needed. Untick the quick format and click OK. it takes a while to finish. After format complete remove the HDD and refit it in your laptop and re-install OS as usual. Hope this helps.
Dec 05, 2012 | Dell Red 15.6" Inspiron 1545 Laptop PC...
My Dell Inspiron 1545 laptop is not recognizing seagate free agent go 500 gb external disk. It used to work fine all the while until I used it on another system. I have tried changed the usb cable but...
check in the bios if it is showing HDD detected
.if there in bios HDD not detected then there is problem with HDD (change the HDD ) or
go in bios and ...check sata settings
.change the sata settings n then ...install again
Jun 28, 2011 | Computers & Internet
I have Dell inspiron 1525 window vista recovery reports 5 error are detected in hard drive and memory errors detected on my laptop 1. hard drive doesnt respond to system commands-critical error 2.boot...
your HDD may be corrupted, re-installing windows vista is one option. Your best bet is if you have/ can obtain a copy of windows vista run setup and try the repair wizard in the windows vista setup, the wizard automatically finds errors and missing files and replaces them therefore solving any errors in your HDD. you can also try to use the recovery wizard from your recovery disc. best of luck
May 17, 2011 | Dell Inspiron 1525 Notebook
I have a dell inspiron 1545.week before it showing time-of-date stopped. then I changed motherboard coin battery.now my laptop not booting up when I press start button the DELL logo come up on screen with...
hi
first off all open hdd screw and pulld hdd in laptop then check
if not stuck problems in hdd if stuck then check rams super drivewifi card and othere hardware
click yes for vote
Feb 22, 2011 | Dell Inspiron 1545 Notebook
Dell 1545 not detecting my harddrive
this problem to an i/o device happens mostly when itz defective/faulty..
check the following:
(to take data backups u gotta connect the hdd to another pc/laptop, for such cases a hdd-case is available in the local spare market, it'll make behave ur hdd to act as an external removable drive)....
1)if ur hdd is making any humming noise (like 'tic tic' or 'kirr kirr')..if so it is likely to be replaced..
2)check for bad connections..
3)update/flash the bios..
4)check for firmware update and or raid drivers (as applicable)..
if u r not a professional, try contacting ur system admin/vendor....
Nov 12, 2009 | Dell Inspiron 1525 Notebook
Transcend STOREJET 2.5 HI- SPEED USB 2.0.0.0 HDD CASE SILVER  Logo
140 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Josh Whitehead
Josh Whitehead
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
