Question about Maytag Performa PAV2200
Maytag machine not spinning
Hi, my maytag performa will not spin. Machine will empty water at start of spin cycle but no spinning happens at all. there has been a high pitch squeak at last stage of spin cycle but since the spin won't work this has stopped.
thanks
maree
@ maree_gorry@hotmail.com
  • 1 more comment
  • ihalfpint2 Jun 17, 2008
    Machine will wash and rinse but when it comes time for spin cycle the drum will not spin. I've checked the belt, lild, water level.
  • Anonymous Feb 02, 2009
    My Maytag washer fills, washes; but fails to spin at all during the spin cycle. I removed the inner and out tubs for cleaning and the spindle spun just fine during a test run. After reassembling the the outer and inner tubs, the machine fails to spin again. I used to be able to 'give the tub' a push and it would spin. The motor operates in the spin cycle and the belt appears to be acceptable. One note: I have disassembled the bottom components of the machine and the 'needle bearing' is not a complete assembly. It is a 'washer' and the 'exposed needles' and another 'washer'. Could this bearing problem be the reason my machine fails to spin the clothes damp day. Thank you for you time and cooperation in this matter.
    My Maytag washer fills, washes; but fails to spin at all during the spin cycle. I removed the inner and out tubs for cleaning and the spindle spun just fine during a test run. After reassembling the outer and inner tubs, the machine fails to spin again. I used to be able to 'give the tub' a push and it would spin. The motor operates in the spin cycle and the belt appears to be acceptable. One note: I have disassembled the bottom components of the machine and the 'needle bearing' is not a complete assembly. It is a 'washer' and the 'exposed needles' and another 'washer.' Could this bearing problem be the reason my machine fails to spin the clothes damp day? Thank you for you time and cooperation in this matter.
  • 868 Answers
You have a stuck brake.My advice is leaving this one alone and lrt a tech. fix it.HINT:99% of this same problems your having I have fixed without replacing 1 part,so see if your repairman can do the same.This is a PERFORMA and is know way Maytags design.Except one thing ,the name on the front panel.
Posted on Jun 01, 2008
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
Maytag Performa agitates, but wont spin corectly.
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 07, 2010 | Washing Machines
I have the same problem , the water filled then stopped working ,
sounds like your timer burnt out or is sticking somtimes giving the top of the controll box a firm smack will get it freed up
Jun 28, 2009 | Maytag Performa PAV2200
Maytag performa washer grinding noise
Sounds like the water pump is going out on it. The part runs about $80 and should only take about 45 minutes to install.
Jun 25, 2009 | Maytag Performa PAV3200
Performa washing machine not spinning
you will most probably find that the inside of the belt that runs on the pulley has been breaking away bit by bit and if the pulley stops where there is a bit missing it may not turn when the pulley starts to turn.
Just a thought as it has happened to me a few times
The odor is most probably burning rubber as the pulley spins on the belt
May 26, 2009 | Maytag Performa PAV2200
Unbalanced washing machine
there may be shipping bolts that you have to remove.read your instructions 2 see
Jan 02, 2009 | Maytag Performa PAV2200
Maytag Performa - Loud Noises during Spin Cycle
This washer is JUNK!!!!!! We have the same washer (2 1/2 years old) and same problem. Tried to replace the bearing myself, no luck. So I called a repair man to come out and look at it. As soon as i told him the model number, they would'nt even come out. Very common problem for this washer. We are on our way to Sears to purchase a Kenmore.....GOOD LUCK
Sep 07, 2008 | Maytag Performa PAV2200
Maytag Washing Machine Stops after wash cycle...
sounds as if you have abad contact in the timer
advance the timer to a different spin cycle and see if it spins
then bo back to where it stops
if it will spin in the other spin cycles but not where it stops the the timer will need to be changed
Apr 21, 2008 | Maytag Dependable Clean Top Load Washer,...
Whirring noise in spin cycle, 7 year old machine
Checking the pump woulb be the first step. The pump bearing get worn and begin to sqeal. If the pump is alright then the problem could be the spin bearing.
Oct 19, 2007 | Maytag Performa PAV2200
Washing Machines Logo
480 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
