Question about JVC AV-28-BD-5-Bl 28" TV
Jvc tv no power
No power to set
Relace capacitor 926, 1.50 from radio shack
Posted on Jun 10, 2008
Hi there I have a jvc tv 'LT-42X788' when I power on the cbc sign comes on I here a click and screen shuts of there's a blue light that came on when I power on it stays on any help thanks
@Thomas Scissons
"JVC LT-42X788 display fault..."
Hi Thomas.
Please pick one:
Power supply board (possibly a blown capacitor):
A TV-tech can repair at reasonable cost, less than a new set.
The main board itself has a control / display section fault:
The screen / panel is shot:
Beyond economical repair - renew set.
Hope this helps.
Oct 16, 2017 | JVC Televison & Video
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from
Jan 18, 2016 | JVC Televison & Video
I have a jvc jlc32bc3002 tv power on jvc come on screen but no rosta and picture
Try a hard reset to this set, and check. If it do not help you, a main board replacement is necessary. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 24, 2015 | JVC Televison & Video
Jvc tv wont turn on it only displays" retreiving data"
If it displays something it is on, try to remove power from the set and a BOX if being used for a while and then power both back up.
Dec 14, 2012 | JVC Televison & Video
JVC tv stuck one channe
I would either call JVC to see if known issue or to inquire if set has a lockout feature that kills remote and all button features----other possible reason in main board with all micro functions has a problem.
Aug 27, 2012 | JVC LT-32P679 32 in. LCD TV
Will not always power up, just clicks and power light flashes. Vertical retrace lines at top 2" of screen. Keeps shrinking and goes completely away after about 5 minutes.
The JVC sets are well known for this type of problem, the tv has a vertical deflection issue needs a few small parts and a touch up on the vertical ic, causes the set to shutdown. I recommend a tv technician for the repair.
Jan 14, 2011 | JVC AV-27750 27" TV
Digital input not working and greyed out on the menu.
Most JVC TV's with HDMI and Digital Input have an optical sensor inside the case to sense if someone is trying to bypass the hardware encryption. My JVC was exposed to sunlight prolonged sunlight and triggered this optical sensor which disabled my HDMI ports. This may be the same situation for you.
Turn the TV on, and enter the Service Menu. Select 2 for Self Check. Then turn the TV off, and after the fan turns off, unplug the power cord. Reconnect the power cord, turn the TV on, and the HDMI port is re-enabled.
Here's how to get to Service Menu:
Before entering the SERVICE MENU, confirm that the setting
of TV/CATV SW of the REMOTE CONTROL UNIT is at the
"TV" side and the setting of VCR/DVD SW of the REMOTE
CONTROL UNIT is at the "VCR" side. If the switches have not
been properly set, you cannot enter the SERVICE MENU.
1) Press [SLEEP TIMER] key and while the indication of
SLEEP TIMER 0 MIN is being displayed, press
[DISPLAY] key and [VIDEO STATUS] key (Fig.2)
2) The SERVICE MENU screen of Fig.1 is displayed.
3) Verify what to set in the SERVICE MENU, and set
whatever is necessary (Fig.1).
Refer to the SERVICE ADJUSTMENT for setting.
4) Press the [BACK] key to return the SERVICE MENU.
Dec 12, 2010 | JVC AV-56WP74 56" Rear Projection...
JVC 36
Hi Dave: "My JVC 36" TV will not power on and has a blinking power light."
That means that the protection circuit has started because a fault had been detected.
If this happened after a power surge it is likely a faulty PSU board.
Try first leaving the set unplugged from power outlet for few hours, this will drain power, reset the protector, and fix problem related to accumulation of electrostatic charges on PSU power capacitors.
If unplugging does not work, that means that there is an internal fault.
If this happened after a power problem of some kind, that means that probably one of the capacitors on powr board had blown, and must be replaced.
The TV must be tested by a technician to find the fault.
Jan 05, 2009 | JVC AV-36D303 36" TV
Jvc tv av-32d502 timer light is flashing will not turn on
Hello, I am a tv tech. I worked on a JVC AV-32D502 today. Problem: led flashes / no power or picture at all. Same as trobertson52's set. The microprocessor is bad in my machine. trobertson52, if your sets' relay does not click when the power button is depressed you most likely have the same problem or the standby power circuit is at fault. That circuit supplies +5 volts to the micro.
Edtal you have a different problem with your machine. Your machine is going into shutdown. A number of circuits could cause this and would need to be looked at by a technician to determine exactly which circuit is at fault. High voltage transformer (HOT) \ Vertical Circuit \ Power supply are the most likely causes.
Sep 25, 2008 | JVC AV-27020 TV
Big screen tv repair
There is a short in this TV set somewhere. The TV set is trying to come on but because of the short, the power supply shuts down. No if it is not the over current shutdown, it could also be the main power supply with an over voltage shutdown protection mode. These are solid state TV sets and should only be worked on by trained techs. Good Luck
Sep 28, 2007 | JVC AV-56WP74 56" Rear Projection...
Televison & Video Logo
108 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
