Question about Fostex MR8-MKII - 8 -Rack Portable Compact Flash Recorder MR8MKII for PC
I just got a 2gb card for my mr-8 (the first Red One) and while I can record to it just fine, it won't read on the computer in usb mode. my 128mb cards I have work fine. Is the 2gb card not compatible with this version of the mr-8?
  • heyheybrett Oct 12, 2010
    I'm not sure what this means. How would i execute this action and what will it do?
    Problem Solver:
  • 23 Answers
Please solve the victim software counterfieting
Posted on Oct 11, 2010
Bounced trks 3&4 to 7&8 clicked on wav file button canceled says out of capacity
You have a memory problem. If you are using a flash card for memory or a CD drive or perhaps you have configured an external drive, you need to free up some space. Try deleting tracks or songs you don't need anymore.
Each song is independent on a CompactFlash
without affecting other songs. You can give a desired song name for managing recorded songs
(see pages 23 and 91).
Recorded track data is stored in a song as mono WAV files.
The MR-8mkII can convert the two WAV files recorded on tracks 7 and 8 (L and R) to a stereo
WAV file (see page 115).
You can export the converted stereo WAV file to your USB-connected personal computer, and
use the file by a music software application or make an original audio CD on the computer using
a CD burn software application. You can also burn an audio CD by using an external CD-R/RW
drive connected via the [USB HOST] port of the MR-8mkII (see page 115 and 123)
Fostex MR 8MKII Owner Manual Page 73 Fostex MR 8MKII Owner Manual Exporting Data To Personal Computer...
Are you using the auto delete feature? Get rid of data you don't need here: http://www.manualslib.com/manual/53326/Fostex-Mr-8mkii.html?page=135#manual
May 25, 2015 | Fostex Mr8 Mkii Mxl 990991 Recording...
Computer won't read my memory stick pro duo. Computer won't read my Droid SD card and I am using the adapter.
is it possible that the auto play window just isnt poping up. go to the start menu > my computer> the look to see if it shows up there. have a great dat
Aug 25, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
Pny 2gb not recognized by windows vista
Try connecting it some other computers.
If it does not work at all, spend $8 to replace it.
If it does work, then it's either the "hardware" on your computer, or the Vista "software" (wrong/missing USB device-drivers).
Apr 20, 2011 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
I have a Fostex MR-8 MKII 8-track recorder, and as soon as I turn it on it says 'card error' and 'illegal format'.My compact flashcard is 2GB Sandisk, how can I solve this problem?
First you can format the flashcard FAT-32 on your computer. If that does not help your card maybe broken or the brand is not supported. Than try to use another brand. Kingston and Transcend always make te best choice.
Feb 12, 2010 | Fostex Mr 8hd CD 8 Track Recorder with CDr
I have the Fostex MR-8 mk II without the burner. I'm having trouble as of late at exporting my finished song to a laptop computer. It's worked fine in the past. Could it be my USB cord is bad? The computer...
USB cords are cheap and can often be found even in Thrift stores... try a new one to eliminate that possibility... I will say they RARELY go bad unless they have been abused.
Remember that reading a USB stick by the computer is FAR different than transfering data from the Fostex...
MAKE SURE the driver for the Fostex in your computer is intact...
OFTEN the stupid DLL files that were working get CLOBBERED by new software and suddenly old things that used to work don't anymore... Thank MS for the stupid thing of allowing new software to change DLL's.
Jan 07, 2010 | Fostex Mr 8hd CD 8 Track Recorder with CDr
Compactflash reads error
You need to verify that your card is confirmed to work in the MR8 at this site:
http://www.fostexinternational.com/docs/support/MR8_Operation_CF_20071213.pdf
It is OBVIOUS that your card is not acceptable because it is larger than 2GB.
Dec 28, 2009 | Fostex Mr 8hd CD 8 Track Recorder with CDr
SD card problem
here is a list of compatable memory cards
http://www.4allmemory.com/index.cfm?fuseaction=search.memorySearch&model_id=42425
.. any SD or MMC card should work up to 4 gb ... so your 2gb should be ok .. i suspect that it may be damaged .. you can try formatting it in a USB card reader if you have one on your computer .. some laptops have the SD slot built in .. there was some compatability issues with memory cards for older cameras but there shouldnt be any with such a new machine .. make sure the contacts are clean and the "protect" switch (if any) is in the unprotected mode .. when you format the card it may take several minutes so give it time .. if you are going to take movies then its better to use a "high speed" SD card .. like the 133x mentioned in the above URL .. slow memory may cause missed frames or 15 fps instead of 30 fps record rates.. .
the specs on your camera do show SD and MMC compatability .but they dont show any brand preference .. .
Oct 06, 2009 | Pentax Optio 33LF Digital Camera
Computer won't read memory cards over 1 gig
Hi Mr
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jan 24, 2009 | SanDisk 2GB microSD Memory Card
    SD card
    I have the same camera, save the colour (black). As soon as I read your post, an alarm went off. I decided to re-check my User Guide (PDF Eng version, page16), for the Lumix DMC-FZ30:
    •On this unit, you can use SD Memory Cards of the following capacity (from 8 MB to 2 GB). Please confirm the latest information on the following website:
    http://panasonic.co.jp/pavc/global/cs
    (This Site is English only.) • This unit supports SD Memory Cards formatted in FAT12 system and FAT16 system based on SD Memory Card Specifications. • This unit does not support MultiMediaCard for recording motion pictures. • The reading/writing speed of a MultiMediaCard is slower than an SD Memory Card. When a MultiMediaCard is used, the performance of certain features may be slightly slower than advertised. • After recording motion pictures using the MultiMediaCard, the card access indication may appear for a while, but this is not a malfunction. • Keep the Memory Card out of reach of children to prevent swallowing.
    8MB, 16MB, 32MB, 64MB, 128MB, 256MB, 512MB, 1GB, 2GB (Maximum)
    Oct 20, 2008 | Panasonic Lumix DMC-FZ30 Digital Camera
    Cannot read Kingston 2GB SD card on my computer
    Dear,
    All just try this trick
    Connect your phone to PC and try to acces the card on PC. Now format the card but, take the backup of data before formatting the card.
    Regards,
    Rakesh Kumar
    May 19, 2008 | Kingston 2GB Secure Digital Memory Card
    Fostex MR8-MKII - 8 -Rack Portable Compact Flash Recorder MR8MKII for PC Logo
    295 people viewed this question
    Top Fostex Computers & Internet Experts
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Julie Clark
    Julie Clark
    Are you a Fostex Computer and Internet Expert? Answer questions, earn points and help others
