Question about Samsung RB215LASH
Does anyone know how to turn OFF the Childlock on the Samsung RB215LASH/RB215LABP Refrigerators? i have checked the manual and cannot find the answer. Sorry to bother you all. Thanks ahead of time.
Hold the button in for at least 5 seconds; it will go off.
Posted on Feb 16, 2011
Owner Manual available on line?
SAMSUNG REFRIGERATOR USER MANUAL Pdf Download.
www.manualslib.com > ... > Refrigerator > Refrigerator
View and Download Samsung Refrigerator user manual online. ... Removing the Front Leg Cover First, open both the freezer and refrigerator doors, and then ...
SAMSUNG RB215LABP OWNER'S MANUAL Pdf Download.
www.manualslib.com > ... > Refrigerator > RB215LABP
Refrigerator Samsung RB215BSSW Owner's Manual ... REFRIGERATORRB215LASH, RB215LABP OWNER'S MANUAL In the U.S. for questions about features, ... When you open the door, an item may fall out and cause personal injury or ...
Jan 12, 2016 | Samsung Refrigerators
Samsung rb215labp freezer cools but refrigerator wont cool
check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required
May 28, 2014 | Samsung RB215LASH
Samsung Refrigerator Model RB215LASH Fan motor in freezer becoming increasingly loud
Your problem here is a build up of ice in the freezer.
If you manually defrost the fridge and the problem disappears then you have found the solution.
The defrost cycle is faulty and you will need a technician to sort it out for you
Mar 30, 2011 | Samsung RB215LASH
Refrigerator cools freezer wont model rb215labp
I know that model very well and I would like to know how long you have owned it and will you or can you find someone that can perform some electrical test fo you. When Samsung made that brand they made a major mistake on the defrost heater elements. They were woven into the evaporator coil. If less that 5 years old it should fall under sealed parts warranty. When I look at a refrigerator from here there are so many possibilities of what is going on that I ask that this is not where to rate my solution. I see that you mentioned the digital controls but are they visible or gone whacked out? Sea Breeze
May 09, 2010 | Samsung RB215LASH
No, I need a manual for my samsung refrigerator. when we got it. It didn't have a manual with it and the store didn't know where it was. So we don't know how to turn the frezzer down it is set on -2, we...
Here is the complet repair manual. It has the information and more but I will need to search for a users manual. Have a look at this and let me know if this is helpful or you want me to continue my search. Thank You Sea Breeze
Aug 16, 2009 | Samsung RB215LASH
My frezer is not staying cold
. The most common problem is a bad start relay on the compressor. In rare cases the compressor may be bad. If you are mechanically inclined you can replace the relay yourself for less than 50 dollars. You will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company
Jul 02, 2009 | Samsung RB215LASH
There is water pooling inside the vegetable crisper of my samsung refrigerator #rb215lash.
Your refrigerator has a defrost drain blockage behind the evaporator in your your fresh food compartment. Some models like yours have 2 evaporators. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution in the drain will help you locate the leak and where. I do have the manual on yours and can help you solve this. Let me know, Sea Breeze
Jun 30, 2009 | Samsung RB215LASH
Samsung refrigerator freezer not freezing
I just returned the same fridge to Lowe's where I bought it using the warranty for the same problem. The temperature sensors went out, and everyone said the computer board needed to be replaced but no one could seem to get it together enough to order us one. Month later we are getting a new fridge.
Jun 02, 2009 | Samsung RB215LASH
Ice maker not working.........
Reset button on the bottem front right of ice maker
Jul 22, 2008 | Samsung RB215LASH
Samsung RB215LASH Logo
143 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
