Question about iLO Televison & Video
Remote control does not work. Changed batteries. Tried universal remote, could not find code or get any reaction from using any code. Turning on by use of TV's side buttons works fine, as does switching sources.
  • 1 more comment
  • jwilhelmcpa Oct 11, 2010
    very helpful
    The brand name is ilo, spelled lke that.
    Model no. is LCT42HA36
    No, I think I'll enjoy the exercise walking to the TV to turn it on or change source. It is hooked to cable, so volume and channel changes are controlled by cable. Thanks for your help.
    President:
  • 2,777 Answers
You may want to just get an original replacement remote. Let me know the make and model of this TV and I will see what I can find for you.
Thanks
Tim
Posted on Oct 11, 2010
  • Tim Grayson
    Tim Grayson Oct 11, 2010
    The only remote I can confirm will work with that model is either the original remote (which is $150 online, ridiculous if you ask me!) or a logitech harmony universal remote. Harmony's are actually the best remotes available, and will truly consolidate all of your remotes into one, and make all devices work together as they should. They are a bit spendy, but I found one here that is roughly half the price of the original remote for that unit. You will love this remote too, it makes everything so much easier:
    http://www.amazon.com/gp/product/B0038OM...
  • Tim Grayson
    No worries, thanks much!
    Tim
What is the correct code for URC-200 Remote Control to operate the Dish ViP722DVR?
The codes are listed on the insert that came with the remote. You need that sheet with all of the manufactures codes to make the adjustment. Try every code they list and make certain the TV or Box is energized at the time. Check the Remote batteries to see if they are in correctly.
May 09, 2014 | Universal Remote Control URC-200 LCD...
Samsung LE32C450E1W TV remote control stopped working, changed batteries no luck, turned off at power source for 30 min which fixed prob temp but has happened again and now turn off doesn't help....
Check the remote control for its infrared emission. Check it with fresh batteries. Clean the battery contacts inside its battery compartment. If these do not help you, you remote control need cleaning. If you wish to know more about how to clean and repair a remote control check this site. Pull up older posts. One among it has details.
Mar 24, 2013 | Samsung TV Remote Control
I have a UMC TV /DVD Combi the remote control i got with it no longer turns the TV on or off, so i bought a universal remote and it cant seem to find the code for the remote so i was wondering would anyone...
First of all, did you put new batteries in the remote control?
That usually solves the problem, because when the batteries get weak
the output infrared signal also gets weak.
With a new universal remote control, there is a booklet containing the
codes to use for many different TV receivers. If your specific TV model
is not listed, try using one that appears to be similar to it. If that does
not work, try turning your TV on with the new universal remote. If you
can turn it on, then you may be able to have the universal remote
program itself by interacting with your TV. Turn it on and hold the
remote so that it points to the TV set and hold it there for about 30
seconds. Then try turning the TV off and on again and try to use
the channel change feature. Try this a few times to give the TV and
the remote a chance to talk to each other. Keep the remote pointed
toward the TV.
Aug 29, 2011 | Televison & Video
Just got Dish. Afer about an hour, the TV1 remote is not being recognized by receiver, except for turning it on and off. No other function is recognized. Yes, I have it on SAT and batteries must be new....
It means that the remote does not have a compatible code for your tv. There is nothing that can be done about that, it's the way the remote was made. Either use it as is or buy another universal remote that has the codes for both units. The only one i can certify it will work is
http://www.logitech.com/en-us/remotes/universal-remotes/devices/6812
May 26, 2011 | DISH Network IR Remote Control
Remote stopped working so I cant use the tv what can I do I was trying to set the firect tv remote and could not get it to work. After I tried that the remote to the tv would not work anymore. I tried...
your best bet is going to be contacting rca and having them send you out a new remote alot of the universals have a 50/50 chance of having the needed frequency so I try to say away from them
hope this helped
Robb
Apr 22, 2010 | RCA RCU600M Remote Control
Samsung TV remote. I noticed today my TV remote wasn't working. I changed the batteries and noticed there had been some leakage from the AAA batteries. Since changing the batteries the 8 buttons on the top...
Giving you some hints. Battery leakage is one enemy of tv control and other remote control. They can corrode your battery spring contact, give contact bridges with neighboring tracks that can cause erratic behavior of your remote.
Some repairs can be done but doesn't guarantee success. First is try to clean the corrosion on battery contact = no power usually. Erratic behavior cause by contact bridging = battery leak residues.
Opening a remote control. Some have screws on its small foot. Covered by a rubber or sticker. Some are notch clip in strategic location you have to fry that one by one, opening first on its weakest side. In some don't want to be open.
Cleaning the board by a soft eraser is one way. After you open the remote. Commonly the button area where contact takes place.
If the first procedure and cleaning doesn't work. Buy new remote or use universal remote controller.
Aug 23, 2009 | Samsung TV Remote Control
My remote wont program with the code or with out them
try it again. press code search button then TV button then the code you have then OFF button.
Aug 04, 2009 | RCA Universal Remote Control
Universal remote
I CHANGED THE BATTERIES IN THE REMOTE BUT THE REMOTE QUIT WORKING.IT LIGHTS UP BUT WONT FUNCTION.Need the code,My TV is Sharp
Aug 24, 2008 | One For All URC4220 Remote Control
Televison & Video Logo
66 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
