Question about Sony Handycam DCR-TRV460 Digital Camcorder
Audio problems I'm transferring tapes using a firewire. I have done this several times in the past. The first tape I transferred worked fine, though I did get a high pitched sound from the computer. I moved the camera and transferred fine. When I went to transfer the second tape, same high pitched sound, moved the camera, sound continued - so I disconnected the firewire and shutoff the camera. When I turned the camera back on I received no audio and the video had vertical lines through it, eventually going to horizonal lines. I reset the camera to no avail. I bought a head cleaner (that doesn't run, which I will be replacing). Any ideas of what the problem could be and any solutions would be greatly appreciated.
  • 10,594 Answers
Video head is dirty/ clogged, use good quality head cleaning cassette. If problem still exist, go to nearest Sony repair shop, they will use Lapping tape to clean head.
Posted on May 31, 2008
I AM UNABLE TO COPY VIDEOS FROM TAPE TO PC
Welcome to FixYa!
Copying from TAPE to PC requires 4 things. The video cam where the TAPE will be played, a FIREWIRE compatible cable, a FIREWIRE card installed on your computer and a SOFTWARE that supports a firewire device that would record the video.
Unlike Digital Videos that you can just copy and paste the video file from the video cam to the computer, the tape to pc transfer is more of recording the video in from the video cam by playing it in real time while the computer is recording it.
This is a sample of a FIREWIRE card that is installed inside a computer.
An external USB version of this is also available.
This is a sample of a FIREWIRE cable.
Windows MOVIE MAKER is an example of a software that can be used to record the videos. It supports FIREWIRE devices.
Here's a sample video.
Thank you for using FixYa!
Jas247
Apr 09, 2011 | JVC GR-D270 Mini DV Digital Camcorder
Unable to switch from "Norm" audio track on old tapes
Hello, this problem is because of the nature of previously recorded signal. The recording made in an older way (mono) has a separate head and the solution for your problem can be to clean the head. This head has two functions, for control pulses and audio signal. If you need more info please advice. Arpi
Jun 03, 2007 | JVC HR-DVS3 Mini DV/S-VHS VCR
Hi how are u sir ? i have panasonic -nv-gs25 camara and i want to copy video from min dvt tape into hard disk trhough usb cable. film show result on pc but copy and paste is impossible plz help me for...
You will require a firewire cable to transfer the tape to a pc. Movie Maker should be on all later model PCs.
You will not be able to see the video like you can on an external drive. The tape must be transferred in real time. That means 30 minutes will take 30 mins to copy.
Al
Feb 12, 2011 | Panasonic NV-GS25 Mini DV Digital...
Cannot transfer tape contents to PC
To transfer video from your camera you will need a firewire cable and a firewire port on your PC. If you don't have such a port you can buy a PCI firewire port.
After you connected your camera with firewire cable you can then use windows movie maker to transfer your video.
See this for more info and photos
Feb 28, 2010 | Panasonic NV-GS400 Camcorder
Transfer from pz card shot on HD to mini DV tape
you can transfer to DV tape only by using software like Edius 6 or a similar one.
First you download the p2 card on the hard drive and then you use this program to convert the video file to DV and use the camcorder as recorder connecting to pc via firewire .
Jan 22, 2010 | Panasonic AG-HVX200A Mini DV Camcorder
Trying to transfer camcorder video to computer.
To transfer camcorder video to computer, you need the following:-
1. Firewire cable (it looks similar to the USB cable, but has very high speed capability)
2. Appropriate software/application.
If a firewire cable did not come with your camcorder then see that purchase one right away, ‘cause you will always need it for this purpose. Then you should have a video editing software like Adobe Premiere or Ulead installed on your system. Adobe Premiere is recommended for its speed.
Once you have these in place, all you need do is connect the camcorder to your computer via firewire, have your video editing application/program open, and simply playback. You will observe that the playback on the camcorder is at the same time being shown on the computer screen within the application. While the mini DV tape is playing back click on capture on the video editing application you are doing the playback from, i.e. Adobe Premiere, Ulead etc.
Sep 03, 2009 | Sony Handycam DCR-HC32 Mini DV Digital...
Sony Handycam: Tranferring footage from _tape_ to computer by USB
the easy way to transfer your footage from your camcorder to pc
is using the firewire cable or the usb. for me the firewire is better
and you can use roxio 10 to edit your video or to put in dvd.
hope that can help you
Aug 30, 2009 | Sony Handycam DCR-TRV17E Mini DV Digital...
Problems transferring entire VHS tape contents
Just continue what your doing in previous just save the remaining minutes maybe the limits was approaches.
May 18, 2009 | Diamond Multimedia ( VC500) Video Capture
Transferring camcoder to computer form
Had same problem...although manual states you can transfer via USB, it doesn't work and won't no matter how many drivers you find. What does work is a Firewire cables. You have three options but I only have tried and proven one. Options:
1. 4-Pin to 4-Pin Firewire transfer cable. The camera has a Firewire port directly below the AC Power adaptor port. This worked fine pulling the video to my PC using Windows Media Transfer. No drivers necessary...at least for Vista. As soon as I plugged in the camera, a window opened asking what actions I wanted to take. Only my HP Laptop equipped with 4-Pin Firewire.
2. 4-Pin (Camera) to 6-Pin Firewire (PC). My Laptop or Desktop not equipped.
3. 4-Pin Firewire (Camera) to USB (PC). Might work but since I couldn't pull data through Camera USB, didn't want to invest in this cable configuration.
Solution in future is buy a bunch of SD Media cards (Not SD-HC) and stop using tape. Transfer direct to PC from SD Card.
Nov 11, 2008 | JVC GR-D271U Camcorder
Sony Handycam DCR-TRV460 Digital Camcorder Logo
77 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
