U have a Hibatchi 42 inch projection screen t.v. And it has pink and lime green coloring on the left side. Can this be fixed? And if it can how much do the repairs usually range?
  • 5,138 Answers
You could be looking at anywhere from $225.00 and up .
TV Shops Charge $190.00 and up just on Tech Labor.
Posted on Oct 11, 2010
How do I correct pink and green bands accross HP-R4252 Plasma TV
First of all try, changing the input device to some other and see whether you see the same problem. Then connect your present input to a different TV and see. If you feel the input is ok, and it is a problem in the display, this is a case to be handled by a qualified service technician.
Jul 16, 2012 | Samsung HP-R4252 42 in. Plasma HDTV
Have sharp quos 52" screen went pink. Can still
Hi, My guess is your daughter messed it up. Go to menu and color and reset to default should fix it.
You may have to adjust color for your best viewing. Good luck.
Sep 27, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
The tv picture looks like should be wachting it whith 3d glasse
This is a very common failure on Projection TV sets. Its called a convergence failure. Here are some common symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around objects on the screen.
You can see some example photos and find a solution here on Fixya.
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Picture is fuzzy and also curves on left and right sides and has green and pink shadowing
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
Oct 17, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
A Dark Bar at the top of the screen that looks pink against white
the light engine is defective if you have black bars that look pink.
Sep 05, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Color seperation on left side of screen
You have convergence output failure. The output ICs will need to be replaced and possibly a small component like a resistor or two as well. Expect to pay a service company $350-$450 to resolve this.
michtech
Feb 15, 2009 | Toshiba 57H81 57" Rear Projection...
Color seems to be pealing up from the bottom of screen
If the screen is bouncing...expanding/shrinking you need to get a repair kit from www.TvRepairKits.com
If your screen looks 3d in color, has a stationary bow, or if you can't adjust one or more colors from the "convergence" menu you need to buy a convergence repair kit. You can get one from the same site listed above.
Hope this Helps,
Nov 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
All color guns out of alignment
Needs convergence amps replaced. Sometimes resistors burn and need to be replaced. This repair requires soldering/desoldering equip. and a trained eye, but usually can be done for 175.00-325.00 at a reputable service center. Good luck, Russmann.
Nov 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
HITACHI 42 INCH HD
Convergence Amp IC issue....originals are STK392-110..replace
W / upgrade Stk394-160E Hitachi part # CZ 01341 and check nearby resistors for overheating............................T.
Jan 07, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
