Question about Haier HTF24R21 24" TV
How do we hook up cable to this tv? - Haier HTF24R21 24" TV
Tv won't read the cable when hooked to the cable wire without cable box
Hello, Mary -
Your cable TV provider probably requires all TVs accessing the cable service to have their own cable converter boxes.
Note: An extra cable converter box will probably cost an additional monthly fee.
We have AT&T Uverse as our cable TV provider and need a cable converter for each TV.
Jan 12, 2018 | Vizio VW26L 26 in. LCD TV
I have the TV above and the cable man came out to hook-up to cable TV and couldn't figure out how to get the cable box to work on the TV turner. He had to hook it up to the auxiliary jacks on the back of...
is there a coaxial cable jack in the back of tv..(if not you may need an adapter..hook to antenna)..then set the tv to ch 3 and set to cable broadcast not air. then you will use the cable box to tune to ch.
Jun 03, 2010 | RCA F20645 TV
Can we record with our sanyo drw 500 and a digital tv? If so, how do we do this?
If cable/SAT box, hook-up that box video/sound output to DVD video/sound input. If no cable/SAT box, hook-up cable from wall into antenna/cable in on DVD and tune DVD to channel wished, and hook-up DVD TV antenna out to TV antenna in. If DVD has no antenna/cable in, TV must have video/sound output. Hook to DVD video/sound input. Hope this helps.
Apr 18, 2010 | Sanyo DRW-500 DVD Recorder
Cable hook up on tv is broke. trying to hook cable up to jvc dvd
Some times you can try tapeing it on (Black tape). Thats what i had to do one time.... It worked.
Jan 25, 2009 | Curtis-Mathis CM27101S TV
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
Rca vcr
there a a bunch of different ways. 1) if you don't have a cable box hooked up to this tv,plug the main cable wire into the vcr input then the vcr outout to the tv.2) if you do have a cable box, plug the main cable into the cable box input, then the output to the vcr input, then the vcr output to the tv. put both the tv & vcr on channel 3 for this connection. [ you must have the vcr on channel 3 to record from the cable box!] 3) if you have aux line/video or source inputs on the back of your tv,you can hook up rca cables [ red, white,& yellow ] from the rca outputs on the vcr to the tv inputs.
hope this helps
wg
Feb 04, 2008 | RCA VR637HF VHS VCR
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
Hooking up wii
you can do it multiple ways. like putting the cords into the dvd then putting the dvd cords into the tv, or put it into the tv, or hook it up to satilitte and hooking up to the tv. your choice.
Dec 26, 2007 | Nintendo Wii Console
DVD VHS recorder
It sounds like your cables are connceted ok, but what you neede to do is to be able the switch from one video mode to the other so lets go through the cable and vrc conncetions again just to make sure. From your cable set top box connect your component video (RGB) video out to your TV (RGB) video in via the (RGB)cables. From your VCR connect your composite video (yellow) out to your TV composite video in withe the composite video (yellow) cable. From your VCR (Left & Right audio out)connect your left and right audio connections (White and Red) to the Audio in of the TV (Left and Right). Whith this setup you should be able to use the TV to switch between the two A/V inputs using the remote control.
Sep 03, 2007 | Philips Magnavox 27MS343S 27" TV
Female coax connector in tv bad?
If your cable converter box has audio/video connections on the back of it,you don't need to worry about using that RF coax connector. Just hook it up the same way your DVD is hooked to the TV input jack. Get a 3-wire cable (yellow-red-white)hook it to the same colors on the back of the cable box and hook the other end to an unused input on the back of the TV. Then select that input with your remote and watch TV.
Aug 30, 2007 | Sharp 27J-S100 TV
Haier HTF24R21 24" TV Logo
166 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
