Question about Marantz CC-4000 5-Disc CD Changer
I have a Phillips AS655 Stero System and the display panel doesn't work anymore. I assume I need to purchase another panel/card (??). Who would I purchase from (not being a Techno sort of person) Chris
2 Suggested Answers
budgie140
  • 501 Answers
SOURCE: Philips as655 no display of graphics on tuner etc
Ive found with the AS655 Ive been working on,the lights will come on after about2-5 mins of use.this isnt a fix,just a comment.
Posted on Jul 21, 2010
Plugged in my emachine LE1938 to my dell without the DVI cable, screen displays 'no signal'. Shouldn't the monitor work without the DVI cable?
The DVI cable transports the display signal from the video card to the monitor.
I think what Ron is asking is if you used a different cable to connect the monitor to the computer. (I'm assuming you used an old 15 pin monitor cable or whatever those old cables were?)
Without getting into your BIOS:
So on your computer, you probably have an onboard video card (a video card built into the motherboard itself), and a dedicated video card (probably where you're seeing the DVI out).
It may be possible that you have the on board video card (with the traditional connection) disabled, when the dedicated video card is plugged in.
This isn't rocket science, so don't worry. Phillips head screwdriver is all you need.
Pull the side panel off your computer (assuming it's a tower... if not, it's the top panel). Once you have it off, you'll see that video card plugged into a slot on the motherboard, with 1 phillips head screw holding it in place (inside, near the back, where the DVI port is).
Pull the screw, and the video card should come out. From there, the BIOS should recognize your card is missing, and thus revert to using the onboard video card.
Sep 02, 2012 | eMachines E-machines flat screen CRT 17"...
What GB memory card does work in a C310 digital camera. My printer dock does not work anymore except to charge my camera and I thought I could get a memory card and print the few pictures I take at a...
The C310 will accept SD cards up to 2GB in size and SDHC cards up to 32 GB. 1GB SD cards are getting hard to find, but 2GB cards should work just as well.
BTW, FixYa doesn't have an online store.
Jun 21, 2011 | Kodak EasyShare C310 Digital Camera
HI...I HAVE THE REFRIGERATOR SAMSUNG TWIN COOLING WITH TWO DOORS, DSTH 1, THE FREEZER IS WORKING NORMALY IN - 18 *, BUT OTHER SIDE, NO...I'M PUT IN 3 *, BUT ALL TIME IS 14 * SOMETIMES 15*, 16*...SO , MY...
You need to defrost the fridge side cooling coil behind rear panel on inside of fridge side.
Open with phillips screwdriver and use hot air blow dryer.
This will make fridge cold and water work.
But you will need to purchase new fridge to solve problem. No fix will ever make this work. System is complete garbage.
Dec 26, 2010 | Refrigerators
I am tryin to remove the factory radio from a 2000 Nissan Altima and install an aftermarket radio. but i cant seem to figure out a way to get the trim panel around the radio and HVAC module out. And i can...
  • disconnect the negative battery cable from the Altima's battery.
  • 2
    Pry up the trim panel surrounding the gear stick. The trip panel is held in place by plastic clips that will disengage when the panel is pried up. Use a flat-head screwdriver to pry up the panel. The panel doesn't need to be completely removed, just pried up enough to reveal two Phillips screws along the bottom of the radio trim panel.
  • 3
    Remove the two Phillips screws along the bottom edge of the radio trim panel, just above the gear stick. Remove the two Phillips screws from above the radio. Remove the ashtray.
  • 4
    Pry the radio trim panel loose with your fingers or a flat-head screwdriver and remove it.
  • 5
    Remove the four Phillips screws holding the radio in place. Set the screws aside for use later. Slide the radio forward and disconnect the wires from the back of the device.
  • 6
    Slide the cage included with your new stereo into your dash adapter. Slide the stereo into the cage and dash adapter.
  • 7
    Connect the wires from the dash to the back of your new stereo. All stereos have slightly different connections methods, so refer to the owner's manual accompanying your new stereo for the proper connection procedure.
  • 8
    Slide the stereo and dash adapter into the dashboard. Use the previously removed Phillips screws to mount the stereo in place. Replace the radio trim panel and gear stick trim panel. Reconnect your battery.
  • If you are putting a aftermarket stero make sure you buy a stero harness that plugs into the cars harness, on the back side of the harness you just installed will have open wires to conet to your new stero. If you cut the wires from your car to try to splice it to the new raido it can cause problems with the electrical system includeing making the transmission shift or act funny. you can pick the harness at wall-mart, car auido, best buy, or any car auido place.
  • Dec 22, 2010 | 2000 Nissan Altima
    Had dead battery in 2002 honda civic got jump now word CODE in radio display
    try disconecting the positive terminal of the batery for sevral minets (5-10) this will reset the brain box memory for the stero aswell as for the car it self.
    what caused the batery to go dead in the first place?
    things that i can think of :
    1) left headlights on over night
    2) bad altenator not charging batery
    3) battery is old and not taking a charge anymore
    4) new stero installed incorectly and drainging the batery
    have you resently installed a new stero or amplifyer?
    is the turn key igntion system hooked into the amp/stero antena lead so that thy are shut of when the ignition is?
    of note: new streo >theres a blue wire marked ant that goes to the amplifyer if not there you need to find the orange accsesory wire coming from the turn key igntion>check for power when ignition is in the on & off states could be yellow in some cars but is usaly orange if this wire has on and of state controled by the turn key igntion this would be the wire to tap into for the amplyfire and the radio main power
    check your radio's instaltion guide for code errors
    its posible that when hooking up the jump it was done incorectly and blew up the radio
    ie postive and negative where fliped
    hope this helped :)
    Feb 24, 2010 | 2002 Honda Civic
    May 22, 2009 | Marantz CC-4000 5-Disc CD Changer
    No display with AGP card installed.
    If one of the components are not porperly connected or has faluire...the system boot up is halted with some beeps...You need to check whether the RAMS a properly fixed...processor cooler can be losened...
    PLEASE RATE ME AS "FIXYA" <blue boxes> for my help
    Jun 02, 2008 | ASUS CUV-NT (CUVNTWOTVWOV) Motherboard
    USB conection problems
    Sorry, not compatible with Vista and no plans to develop compatibility
    Nov 11, 2007 | Philips FWM779 CD Shelf System
    Marantz CC-4000 5-Disc CD Changer Logo
    Top Marantz Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Electro Med Services...
    Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
