Question about Riso Office Equipment & Supplies
We have a cr1610 riso duplicator. It has a lot of small belts that convey the master paper into the waste box. They look like small rubber bands. The office supply says they can't get them anymore. This is a perfectly good machine, it only needs the belts replaced. Can you help?!!! thank you.
  • 81 Answers
SOURCE: Riso GR 375 How to change language
turn machine on .. then press the "8" and the " * " at the same time to enter user mode...
user mode 17 changes language
Posted on Jul 07, 2009
SOURCE: Printer paper feed wheel rubber band is broken
I had the exact sazme problem above and managed to successfully fix the probelm using an old mountain bike inner tube. I removed the cover to gain access to the paper feeder and removed it by first moving the white retaining clip on the right hand side towards the centre. Usign a flat headed screw driver I then freed this end from the black housing. Then, noting the orientation of the bar I then gently pulled it out of the gearing procket at the left hand side. This freed the bar from the printer. To get the required thickness of rubber I used four 2cm pieces cut from the inner tube and put them in place of the broken rubber. Re-assembled and worked first time and ever since. Hope this helps.
Posted on Sep 03, 2009
  • 76 Answers
SOURCE: Have riso cr1610 - prints for few copies, stops,
Ink overflow. Fit new squeezy gear in drum.
Posted on Oct 08, 2009
  • 17 Answers
SOURCE: error E16 RISOGRAPH CR1610
E16 indicates a motor lock with the inking motor. Disassemble the ink pump unit and check for proper rotation of the inking motor itself. This error is caused by a current overload.
Also, remember to try powering on the machine while holding down the reset key to clear all error codes first.
Posted on Mar 30, 2010
  • 10865 Answers
SOURCE: Iam working in RISO duplicator
Hi acs..... Here is the phone number to the company's customer service center.
To contact RISO's Customer
Support Center, simply dial
1-800-942-7476.
Call them and tell them that you need the parts list and what ever else you need their assistance with. Joe
thanks for choosing Fixya!
Posted on Dec 04, 2010
Riso cr1610 cannot cut master and it shows me e25 error code, what must i do to clear code
Replace light absorbing sheet (Black strip) on Drum screen sheet & also clean master position sensor , master loading sensor
Jun 19, 2014 | Riso Office Equipment & Supplies
Error code T01-521 on RISO RN 2130
I have an RP3105 with this error code. Next to the magnetic clamp that holds the master in place is another lever mechanism that lifts the master to present it to the waste master mechanism. This has a small white plastic wheel which is engaged to make it move. On my machine the wheel had broken in half. I superglued the two pieces together and everything works perfectly
Feb 04, 2011 | Office Equipment & Supplies
Riso ? One Stripe in the middle.
Yes you are right. The 'stripper finger' is not lifted enough so it scratches the master.
I know this problem from a GR. But the procedure should be nearly the same for your machine. Behind the back cover you will find a small rubber roller. Diameter 12mm (1/2") or so. This roller runs at the excentic curve of the drum. You might find that the rubber is worn of and so the finger cannot be lifted enough any more. You have to replace it.
(Hint: For a fast momentarily solution you may fix it by several windings of adhesive tape.)
May 04, 2010 | Riso RZ390 Duplicator
I have a Riso CR1610 and one of the drums leaks like the devil whenever I use it. Any ideas?
your drum seals are worn out you need to call for your technician to replace the seal or replace the drum unit.
Apr 22, 2010 | Riso RZ220 Duplicator
Error E16 RISOGRAPH CR1610
Feb 13, 2010 | Sharp AL 1631 Copier
No Ink going to the drum
Good day, there are several reason why theres no ink comming inside the drum. These are the following reason why:
1. Loose rubber O-ring in nozzle of your pump unit.
2. Broken inking hose.(hose size 12 & 10)
3. Clog from ink filter between the nozzle and inking hose.
4. Malfunction on pump motor.
You should verify all those item by dismantling those parts. Just replace any of those parts your drum will surely pump ink again.
Posted by: RommelF
Dec 03, 2009 | Riso RZ220 Duplicator
My rizo 220 wich cannot pull a muaster roll
Normally when this model does not feed the master,there is a drive band jump off it place n the master drive unit.To correct this open the front panel of the master making unit and check that all the drive bands is in place.I am working 10 years with Riso and this machines is the best I ever worked with.
Nov 26, 2009 | Riso RZ220 Duplicator
A05-304 error & Top section of page cutting off
the thing might be down to an old master stuck to the drum this could cause the faint copies and the missing print.. pull the drum out check under the master.this would also cause the paper to jam on exit. the error is for no master eject check the calmp is free where it grips the master and also the path for the master eject to the waste bin
Jun 12, 2009 | Riso RZ220 Duplicator
Riso
probably needs a new adf stripper pad.. the first little rubber pad on the bottem of the inside of the adf
Aug 11, 2008 | Riso RZ220 Duplicator
54 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
