Question about Canon imageCLASS® MF6550 Laser Printer
My mf3240 show paper jam, I removed it and red light still blinking
  • thanhpham2 Oct 12, 2010
    I try it, did not see any paper stuck. Reconnect cable still does'nt work.
    No paper stuck at sensor (under paper tray). still not work.
  • Canon Master
  • 3,530 Answers
Disconnect the printer & turn it off. Go to the printer settings in control panel & make sure it is selected as default printer & also purge any print jobs. Reconnect, this usually happens when the computer had an error when trying to send a job to the printer. This should hopefully sort you out.If this fails, uninstall & re-install the driver.
Please do get back if everything fails. There is a possibility that your sensor is getting a wrong signal. I that's the case, you need to clean the paper sensor with canned air. It may have accumulated paper dust.
Posted on Oct 12, 2010
    President:
  • 1,932 Answers
Please try this
1. Turn off your printer.
2. Pull off all plugs attached to your printer back.
3. Remove the paper tray to look for the sensor located underneath the printer.
4. Get a flashlight and look closely. The sensor is located in a small hole, just above the small plastic "lever" (looks like a small hockey paddle) on the left side of the gray rubber roller.
5. There may be a tiny paper shred stuck inside and this may cause the sensor to detect a paper jam.
6. If it is there remove the paper
7. Return all cables and start your printer and that's it.
Thank you
Posted on Oct 11, 2010
Why does the data light blink then paper jam light goes on even with no paper in it
Most likely when you removed the paper jam a small piece of paper got jammed under one of the sensors. This is a very common problem. It is also possible depending on the model that you have dislodged one of the flags that activates sensors for paper travel. Check the back of the printer in the fuser area as these are the most commonly damaged sensors.
Sep 04, 2014 | Lexmark E Office Equipment & Supplies
Tip
Canon ImageClass MF3240 paper jam fix
The Canon ImageClass MF3240 continues to show "paper jam" error even if someone followed all the possible fix to remove the jam. After clearing the paper in all access doors (both front and back), the printer still gives the paper jam error. Also, if you have tried restarting the printer several times to no avail and the red light keeps blinking, here is the fix to what is most probably been causing the paper jam problem of Canon ImageClass MF3240.
1. Turn off the printer and pull out all plugs and power cord that is attached to your printer.
2. Remove the paper tray at the bottom and let the printer lie at its back so that you can see underneath.
3. Get a flashlight and look closely for the sensor located underneath the printer. The sensor is located in a small square hole, just above the small black plastic "lever" (looks like a small hockey paddle) on the left side of the gray rubber roller. Move the lever so that you can freely look closer on the hole.
4. Notice because there could be a tiny paper shred stuck inside and this causes the sensor to detect a paper jam.
5. Get a small tweezer to remove that paper out.
6. Next, let the printer stand normally and return the tray back.
7. Re-plug all cables and start your printer. That's it!
on Jan 07, 2010 | Office Equipment & Supplies
Printer hp deskjet 840c blinking green and red light why
Depends which red blinking light. I assume the red light is the resume light. The green light is the power light. If the Power and the Resume light are blinking alternately, then you have a paper jam somewhere in the printer. remove the paper jam and you should be fine.
Mar 18, 2011 | HP DeskJet 840c InkJet Printer
My canon mf3240 printer jamed, then a b5 paper size error message
You must be set you machine from program key
1> press menu>paper size>A4/Letter/set OK
after print or copy your requirement size.
Dec 12, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Cannon imageclass mf3240 laser printer paper jam
Hello there,
Hope I could still share with you this fix because this is where you need to look at when you think you have done everything to remove the paper jam.
You can also click on this link for this trick.
http://www.fixya.com/support/r3827902-canon_imageclass_mf3240_paper_jam_fix
Sep 08, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
Paper jams on Canon MF3240
Start with the paper itself. Make sure it is in the machine properly. Here is a short guide on a few things to check:
http://cincinnatiprinterrepair.com/paper-jams
Jun 17, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
Canon MF3240 Paper Jam - No Real Jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Dec 18, 2008 | Canon imageCLASS MF3240 All-In-One Laser...
Canon imageCLASS® MF6550 Laser Printer Logo
82 people viewed this question
old marine
old marine
